Corsair scale guysneed your help!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Corsair scale guysneed your help!
Page: [1]
Login
Corsair scale guysneed your help! - 6/28/2010 6:19 PM
nauticom
Score: 100
Last Login: 5/23/2013
Status: offline
Hi guys:
My question is: what is the distance between rivets on a full size Corsair.
I had started out to use 2 1/2 inches and scaled that to one-half inch for my 1/5 scale Ziroli Corsair. They look to far apart.
At an air show yesterday, I saw a couple WWII era planes and their rivets were 1 1/4 " apart, which would scale down to 1/4" for my ZCorsair.
Help,
BobM
_____________________________
Bob Masterson
Corsair Brotherhood # 60
Hide Signatures
       Post #: 1
RE: Corsair scale guysneed your help! - 6/28/2010 6:48 PM
F3A1
Score: 100
Last Login: 5/22/2013
Status: offline
Bob,
I am sorry to say there is no simple answer to your question. The rivet diameter and spacing vary all over the airframe and even on the same panel. In general 7/8" is common and with the smaller 1/8" rivet in areas of reinforcement it can be 1/2" spacing. The rivets are no closer to the panel edge than 1 1/2 times of the hole diameter. You really could write a book about the subject.
Also the Corsair is noted to be the first production aircraft to use spot welding as a means of constructing the aluminum skins to the panel reinforcing structure. In other words the fuselage skins are riveted to the airframe only (usually) around the perimeter of the panel and spot welded to the fuselage formers within that panel. All of those skins can be replaced as a panel from factory jig drilled replacement panels. I hope this made some sense and helps.
Lex
http://www.BrewsterCorsair.com
Hide Signatures
(in reply to nauticom)
       Post #: 2
RE: Corsair scale guysneed your help! - 6/28/2010 8:02 PM
rwright142
Score: 100
Last Login: 5/19/2013
Status: offline
Bob,
You just got the best answer you will ever find on the subject. Check out Lex's website and you'll understand what I mean.
Good seeing you still on the forum Lex!
Richard Wright
Admin, Corsair Information Forum
http://f4ucorsair.freeforums.org
In the works: 1/6 Scale F4U Corsair
CORSAIR Brotherhood # 39
Hide Signatures
(in reply to F3A1)
       Post #: 3
RE: Corsair scale guysneed your help! - 6/28/2010 8:15 PM
cpt nj
Score: 100
Last Login: 4/26/2013
Status: offline
The Corsair was unique,  the panels were mostly spot welded and had few rivets.
Hide Signatures
       Post #: 4
RE: Corsair scale guysneed your help! - 6/28/2010 8:22 PM
nauticom
Score: 100
Status: offline
Lex:
WoW:
Your web site is inspiring.
I'm of the WWII era; growing up a few miles from Willow Run bomber plant in MI; seeing those planes fly over our farm starting at daylight 24/7 so low you could almost touch them.
But Corsairs are my modeling passion.
Thanks for your info. I think I will go with 1/4" spacing on those flat rivets, seems close to scale.
Bob Masterson
Hide Signatures
(in reply to rwright142)
       Post #: 5
RE: Corsair scale guysneed your help! - 7/9/2010 12:18 AM
nauticom
Score: 100
Status: offline
Lex:
Again, thanks for your informed reply.
I have another question.
Here it is:
I am building a Zorili GS Corsair 93" WS, etc. On the full scale bird, the right wing had a spoiler added after early manufacturing, around 42 or 43 to the -1A and all subsequent builds. This spoiler was added to assist in eliminating left wing tip stalling on landing.
I have put my guess as to size of this on my build. I saw a full scale -1D at Oshkosh a couple years ago and was about 6" in width( works out to be about 1 1/4 " on model).
My problem is the piece I built seems way to large depth wise. I guessed it was about 3" deep full scale at the wing leading edge, which translated to around 1/2" on the build. Just looks way to big.
Question does anyone know the depth on that thing as measured from the leading edge of a full scale -1A so I can scale this thing more close to what it should be. I guessed it was 3" deep, which scaled out to 1/2".
Much thanks for your help
Read more: http://www.rcuniverse.com/forum/m_3109744/mpage_287/key_/tm.htm#ixzz0t7k51h2D
Bob Masterson
Hide Signatures
       Post #: 6
RE: Corsair scale guysneed your help! - 7/10/2010 4:05 AM
F3A1
Score: 100
Status: offline
Bob,
PM sent.
Lex
Hide Signatures
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
