RE: Contra Rotating Propeller Drive for f3a 2m Pattern Planes    Gallery
Logged in as Guest
Users viewing this topic: pfloyd, SanJoseDale
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: Contra Rotating Propeller Drive for f3a 2m Pattern Planes
Page: <<   < prev  27 28 [29] 30 31 32 33 34 35 36   next >   >>
Login
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/1/2012 9:10 AM
Hans Meij
Score: 100
Last Login: 5/19/2013
Status: offline
Hi Brenner,
Thanks for the suggestion.
I do not exactly know how it should look like, but think it looks OK.
Hide Signatures
(in reply to Brenner)
       Post #: 701
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/1/2012 3:15 PM
vbortone
Score: 100
Status: offline
Hans,
I am planing to use contra in the Gaudious. The Gadious comes with positive (up) motor thurst. It is more common to see a little negative (down) thurst. Just would like to know how you set up yours?
Vicente "Vince" Bortone
_____________________________
Hide Signatures
(in reply to Hans Meij)
       Post #: 702
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/1/2012 5:39 PM
Hans Meij
Score: 100
Status: offline
Hi Vince,
Have flown the Gaudius now for two years. This first thing two years agoI thought that this uphrust could not be right so I eliminated it. Could not fly straight up any more.
With any apply of power it strongly pulled to the belly. So back to what the designer has intended it to be. And he was right (offcourse) So yes it needs the upthrust.
Has to be something with the thrustline be way above wing and stab.
In general I think that the thrust down is wrong in F3A models.
Thrust down compensated by to much angle between wing and stab, compensated by a downline mixer to avoid veer to canopy in downlines is a wrong solution.
The Gaudius needs this upthrust. For the Contradrive exactly the same amount. No sidethrust however.
Hide Signatures
(in reply to vbortone)
       Post #: 703
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/1/2012 7:13 PM
servari
Score: 100
Status: offline
Hey Brenner, Hans,
I probably had the same problem with my 13 XL. Rotor was cracked and I thought that some dust had gone inside the motor and damaged it.
After sending 13 XL to Hacker they told me that the motor had overheated.
They suggested to take a 14 XL with electric part only(without gearcase).
I opened the belly a bit more and did 2 openings on the top of the fuselage.
After about 65 flights, ( setup : 2X22X20  9,89 ratio) with outside temperature 22 °C,  Max motor temperature was 53 °C (127 F) and very often  about 40 °C . Now flights are awesome.
I hope it will be cool enough. Before,  the 13 XL motor was way hotter and was very long to cool.
Good flights
Vincent ...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 704
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/1/2012 7:47 PM
Brenner
Score: 100
Last Login: 5/17/2013
Status: offline
Hey Vincent,
Wow, with that setup you must be getting huge power. I'm running a 13XL with the 10.33:1 gearset, and it's been on the edge as far heat rise is concerned. I'm definitely going to cut more cooling holes.
Brenner ...
Hide Signatures
(in reply to servari)
       Post #: 705
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/2/2012 1:46 AM
OhD
Score: 100
Last Login: 5/20/2013
Status: online
quote:
ORIGINAL: Hans Meij
Hi Vince,
Good news. I've been measuring and measuring and wondering if I screwed up when I took the right thrust out of my Gaudius and accidentally created upthrust because it is definitely there. Glad to hear that it is supposed to be that way and more importantly flies right that way.
Thanks for making me feel better, Jim O
Hide Signatures
       Post #: 706
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/2/2012 1:50 AM
vbortone
Score: 100
Status: offline
Just curiosity. Where you got the CG? That will help me a lot.
Hide Signatures
(in reply to OhD)
       Post #: 707
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/2/2012 6:05 AM
Hans Meij
Score: 100
Status: offline
Just before the wingtube. Here the Gaudius thread with lots of info:
http://www.rcuniverse.com/forum/m_9293446/mpage_5/key_/tm.htm
Hide Signatures
       Post #: 708
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/4/2012 7:22 PM
Brenner
Score: 100
Status: offline
I received a shipment of Contra front and rear props from APC yesterday, and the first thing I did was go out and fly them.
They seem to fly well. I flew them back to back with a mixed set of 22x22 rear and 22x20 front props, and the performance seemed very similar. The noise profile was also very similar. Both sets were pretty quiet in the air. Currently I'm flying with a set of tired 25C packs from last year, a 13XL motor, (with new bearings and rotor..) and a 10.33:1 gearset, and with this setup the performance we more than acceptable.
I have fresh packs on order, so I won't try different gearsets until I get them, but based on what I see now, I think there's quite a bit of headroom in the system. I didn't measure motor current, but I only took 3400 mah out of my packs for an AMA Masters flight with negligible throttle management.
I'm expecting to see a significant performance boost with new packs, another boost with a 10.15:1 gearset, and even more performance with a 9.89:1 gearset, so my final setup will reflect an appropriate tradeoff between performance, throttle management, and mah draw from my packs.
Brenner ...
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 709
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/4/2012 7:48 PM
Hans Meij
Score: 100
Status: offline
Hi Brenner, very nice. Looking foreward to give them a try.
Hide Signatures
       Post #: 710
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/5/2012 6:45 AM
OhD
Score: 100
Status: online
Great day flying today in Arvin. The day started overcast, windy, and cold but ended up warm and sunny with light winds. The highlight was the sound of the new APC props on Leon's Contra with the Neu motor. It is the best sounding pattern plane I have ever heard. It has been awhile since I heard the stock props and it will be interesting to hear the difference side by side but this sounded like a real airplane. There must be something in the lower rpm but I also thought I could hear a sound like a twin. I suspect the props were not turning at exactly the same rpm but man it sounded good. I would hope that someone can measure the rpm with a strobe and we can find out what they are turning but it will be hard to improve on what I heard today.
We ended the day sitting in the sun, telling war stories from the old days and were amazed at how Chip could remember all the dates and places. Then again he is so young he doesn't have near as much to remember as the rest of us.
Jim O
Hide Signatures
       Post #: 711
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/5/2012 9:02 AM
Malcolm H
Score: 100
Status: offline
But Brenner,
The APCs don't look nearly as sexy as your carbon props!
Malcolm
Hide Signatures
(in reply to OhD)
       Post #: 712
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/5/2012 11:57 AM
jnred123
Score: 100
Status: offline
What he said
Cheers
Greg
Hide Signatures
(in reply to Malcolm H)
       Post #: 713
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/5/2012 2:37 PM
mups53
Score: 105
Status: offline
 Brenner what's the weight difference between the APC's and Mike's CF props? Isn't weight in the nose with the Contra an issue for balancing? Thanks, Mike
F3AUnlimited Customer Service
1 800 591 2875
Hide Signatures
(in reply to jnred123)
       Post #: 714
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/5/2012 4:13 PM
Brenner
Score: 100
Status: offline
Hey Mike,
Mikes Props are 50g +/- 5g. The APC props are 90g, so you have about an 80g difference considering both props.
This does shift the CG, so anyone wanting to use APC props will have to be able to shift their packs around to compensate. In my own case, I just wanted to get a quick impression, so I didn't worry about changes in the CG, and in my experience, Contra powered planes seem to be quite tolerant to a foward biased CG. Anyway, the plane still few great.
What I'll probably be doing is moving my battery tray rearward so that I can play around with CG, because now I have new Dave Snow Spark wings as well, so the proper CG needs to be re-determined.
Brenner ...
Hide Signatures
(in reply to mups53)
       Post #: 715
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/5/2012 6:28 PM
OhD
Score: 100
Status: online
Hey Brenner,
You didn't say what sizes you got from APC. Where do we go for more info?
Jim O
Hide Signatures
       Post #: 716
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/5/2012 7:44 PM
gmr1948
Score: 100
Last Login: 4/27/2013
Status: offline
Brenner,
The APC site lists a 20.5x 20.5 @ 4.34 oz and a 20x22.5 counter rotating @ 4.09 oz. If these are the props you are referring to, the weights do not agree. Gary
Hide Signatures
       Post #: 717
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/6/2012 1:37 AM
Brenner
Score: 100
Status: offline
Hey Gary,
The actual weights, as measured on my scale, are:
Front Prop: 89g
Rear Prop: 97g
I'm only guessing here, but maybe someone at APC weighed them while still in the packaging. I weighed my props in the packaging, and the numbers are close to what you are reporting.
Brenner ...
Hide Signatures
(in reply to gmr1948)
       Post #: 718
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/6/2012 2:40 PM
gmr1948
Score: 100
Status: offline
Brenner,
I spoke with APC this morning and they re-weighed the props. The website numbers currently displayed are incorrect. Should be 3.1 oz and 3.35 oz.
Gary
Hide Signatures
       Post #: 719
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/7/2012 5:54 AM
Passport1
Score: 100
Last Login: 5/4/2013
Status: offline
Here is a brief explanation as to why we might be hearing a sound difference.
The primary source of propeller noise comes from supersonic tip speeds. Swept or elliptical tips help reduce prop noise. Keeping the prop tips subsonic is highly recommended both for efficiency and noise.
A secondary source of propeller noise is propeller blade resonance. The natural frequency of the blade (or resonant rpm) depends on the density, stiffness and damping of the propeller material. Hand made carbon blades are typically lighter, stiffer and have less damping than glass/nylon props. These factors contribute to a higher resonant frequency in carbon props that is very lightly damped. As a result, carbon props tend to be louder than glass/nylon props. Much like a ceramic tuning fork vs. one made from lead.
Hope this better explains it.
Chip
Hide Signatures
       Post #: 720
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/7/2012 10:30 AM
servari
Score: 100
Status: offline
Hey Brenner, Dave,
New wings and anhedral stab on the Integral  ?
Is anhedral stab to make knife flight easier ?
Could you please tell me why this new aerodynamic setup.
Vincent ....
Hide Signatures
       Post #: 721
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/7/2012 3:11 PM
Brenner
Score: 100
Status: offline
Hey Vincent,
The primary reason for new wings and stab is to reduce weight. Both the wings and the stab are built up, so there is about a 150g savings in weight.
As far as performance goes, the thinking behind the anhedral stab is that it will marginally increase the effective rudder side area when the plan yaws, hopefully acting as a sort of yaw damper. I'm still evaluating this, so I'm not making any claims yet.
The wings are Spark wings. The intention here is keep the airflow attached out the near the wing tips at high angles of attack, making snap rolls easier, and making spin entries much more controllable. The wing does both of these things, so I can definitely make claims in this regard.
Also, the wing chord thickness tapers out towards the wing tips more aggressively than the stock Integral wings, which reduces drag and increases the speed range.
Brenner ...
Hide Signatures
       Post #: 722
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/7/2012 9:29 PM
servari
Score: 100
Status: offline
Hey Brenner,
Thank you very much for your explanations. It's really interesting. Do you think it is possible to do a spark wing and a stab for my Integral  ?
Vincent ...
Hide Signatures
       Post #: 723
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/7/2012 10:33 PM
Dsnow
Score: 110
Last Login: 5/9/2013
Status: offline
Hi Vincent, fitting the parts to the Integral is no problem, shipping is. I built the wing and stab panels Brenner is flying and basically hand delivered the parts to him so no shipping was involved, but to France built components would be very costly. I do have kits for the wings and stabs that I’ve sent internationally without too many problems. Here is a build thread showing how they go together, http://www.rcuniverse.com/forum/m_10841584/tm.htm . The wing you will save the most weight, typical weight ready to fly 14 oz but with very good wood – 3/32” wing sheeting 14 to 15 grams each – we have built several Spark Evo wings at 12 oz.
Dave Snow
Hide Signatures
       Post #: 724
RE: Contra Rotating Propeller Drive for f3a 2m Pattern ... - 4/9/2012 6:58 PM
servari
Score: 100
Status: offline
Hi Dave,
I saw your built thread. It's really awesome!
I think it will be too difficult for me to build it though, because it looks like it takes some skills and tricks to build the elliptic wing and stab from scratch.
Do you have any idea of what it would cost to ship the whole set to France ?
Thanks a lot
Vincent ...
Hide Signatures
(in reply to Dsnow)
       Post #: 725
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.125RCU1
