Brenner
Score: 100 Joined: 7/23/2007 Last Login: 5/17/2013 From: Bridgman,
MI, USA Status: offline
Hey Bem, I will do my best to answer your questions. The current version of the Contra Drive that we sell today is our new VIII design. We have enough parts in stock to make about fifty units. The prices are as follows: Contra Drive (Includes 10ml of Rheolube 374A Grease, one gearset, Hub Puller, user manual, and tools ..) $1,000 USD Adapter Manifold (Neu f3a and Hacker C50 Motors supported ..) $100 USD Carbon Fiber Propellers (22x18, 22x20, & 22x22 front and rear available ..) $100 USD each Replaceable Gearsets (includes planet gears, bearings, ring gear, and driveshaft - 9.89:1, 10.15:1, 10.33:1, 10.56:1 available ..) $200 USD There are approximately 90 Contra Drive Units in circulation right now. APC props are available from us, or direct from APC. They are $45 USD per set, and I believe the sizes are 20x22 for the rear, and 20.5x20.5 for the front. I just flew a new Contra Powered Wind S Pro with a Neu f3a motor at a contest in Chicago this last weekend, and I highly recommend it. When I first flew it, it didn't "lock in" like my Integral would, but after I ironed the bubbles out of the black monkote on the leading edge of the wing, and adjusted the trim out of my stab, it locked in perfectly. The rolling performance is the best of any plane I've flown, and the speed range is very broad. Initially I think I had a little trouble picking up visual cues from the mid wing-arrangement, but now I don't have any problem at all. (These problems weren't all that bad, because I was still able to cop first place in Masters in Chicago..) However, in my view the absolute best thing about this setup is the way the Neu motor is working. I'm running a 9.89:1 gearset with 22x20 front and rear props, and I am drawing from 3,000 mah to 3,500 mah for an AMA Masters schedule, (similar to P13..) and the motor and controller is running "ice-cold". I measured the motor case temperature with an infrared thermometer, and the temperature immediately after a flight is 46C. (115F) (This is with a 25C ambient temperature ..) Based on my experience with my Contra/Hacker (13XL) powered Integral, this is about 500 mah less per flight, and about 30C less heat rise. It's a little hard to directly attribute these performance improvements to either the plane, or the motor, because both are changed from my Integral, but the Wind S Pro does have a lot of extra venting around the nose that directs air over the case of the motor, and it is definitely a much less "draggy" design than my Integral. All in all, I am extremely pleased, and if anyone asks me personally for a recommended Contra setup, this is it. Brenner ...
Hide Signatures
