Demon
CT, USA Status: offline
Larry, Thanks for the compliment! My JKA planes were all built as per the JKA instructions (including all of the Strapping Tape and dowel-spar reinforcments), with one exception: I use EconoKote or TowerKote covering instead of the recomended Packing Tape for covering. Then that is scuffed with 000 Steel Wool and painted. The Zero pictured is painted entirely with gloss Rustolium paints(Dark Hunter Green, Smoke Gray and Black). The Rustolium colors are fuel proof and can be used as-is with no clear coat. Rustolium metalic colors, flats and satins are NOT fuel proof! Only the gloss colors are. The P-47 was originally painted with 21st Century Olive Drab topsides with Rustolium gray primer undersides and Yellow Rustolium tail with a coat of Krylon Acylic Satin Clear. Most of the 21st Century Olive Drab on the wing chipped off in numerous midairs. So, those areas were repainted with Testors SAC Olive Drab and cleared with the Krylon Acrylic again. Not all Krylon clears are fuel proof - ONLY their Acrylic Gloss and Satin clears are. They also have Enamel and Laquer clears that ARE NOT fuel proof. Hope this helps, D
< Message edited by Demon-RCU -- Apr 12 2002 9:23PM >
_____________________________
Darin Bellis RCCA 426
