David Cutler
CA, USA Status: offline
[QUOTE]David, do you have the Hitec Radio or were you just suggesting it as an option?[/QUOTE] Yep! I use the Eclipse + Spectra. It does everything I want, and I get a lot more flying in from having the Spectra. In answer to your next question:- Yes, it can be programmed to give a crow situation, but it takes a lot of programming, and can only be done using two switches, if you want to retain the throttle channel as a throttle (i.e. not a glider) The fact that there are 5 programmable mixes (as opposed to 3 on the tracker) makes it possible. Mike, from Hitec, in here, will show you how, I'm sure. As for the rest of the set-ups I need, they are all very simple on the Eclipse. -David C.
