Bearing lubrication
Tower Hobbies
Logged in as Guest
  Printable Version
EASYTIGER'S NEW F-22 Raptor 70mm EDF
Seller:  EASYTIGER
Details:   $199.00   |  11/12/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> Artes Jet >> Bearing lubrication
Page: [1]
Login
Bearing lubrication - 7/24/2003 1:29:07 AM
Rudeboy
Status: offline
Hello,
How much fuel/oil mix needs to go through ceramic bearings in a KJ-66 engine?
I was told 6 milliliters per minute at full throttle... is this correct?
This seems very little to me, but then again, I am new to turbines, so I'm not an expert...
What is the danger when you pump too much fuel through the bearings (except for flames shooting out of the exhaust:p)?
I mean, how easily do these bearings start to skid? They are preloaded, so that should take care of it...
_____________________________
Revver Brother #33
...I think it needs more power...
       Post #: 1
Re: Bearing lubrication - 8/27/2003 2:13:18 PM
digitech
Status: offline
[QUOTE]Originally posted by Rudeboy
Hello,
[/QUOTE]
if you are new
isnt there a usermanual?
normaly you can use plain turbine oil they are all ok even if they say you cant mix them with fuel
however castrol tt also does the trick or any good outboard motoroil to mix
if i look around i dont see many problems in mixing they almost all mix to 1:40 or (5/6% oil in fuel)
i have 3 wren engines all of them run nicely and i burned more then 150 liters by now without any problems
to much fuel pumped:
welll i guess you have a ecu that wont let you do this
if this does happen it is mostly the priming sequence or you have a wetstart
it could damage your engine or run it extremely hot
also if the start is to slow you will see the temp go very high
if the pumpstart then comes in rapidly you will have also some flames coming
i suggest the next time you do a posting you may add:
ecu brand
rc used
battery,s used
pump used
and weather conditions sometimes
reg Sandor
Sandor Kruise
Dealers for:JetCat,Graupner,Futaba,Fei-Bao,Pro-Lynx,Airpower,Jets-munt,Xicoy,Jet-1A,Composite-ARF.
"Home of the Pro-Lynx Gears"
(in reply to Rudeboy)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU2
