RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Page: <<   < prev  33 34 [35] 36 37 38 39 40 41 42   next >   >>
Login
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/4/2010 6:39 AM
captinjohn
Score: 247
Last Login: 5/22/2013
Status: offline
Nice & lite.....right?   Capt,n
_____________________________
I never met a engine I did not like !
Hide Signatures
(in reply to w8ye)
       Post #: 851
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/4/2010 6:58 AM
av8tor1977
Score: 665
Last Login: 5/23/2013
Status: offline
Actually, I was surprised once when I weighed that particular mount. If I remember it was something like 7 + ounces....
AV8TOR
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to captinjohn)
       Post #: 852
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/4/2010 7:05 AM
captinjohn
Score: 247
Status: offline
When I said nice & lite....I was thinking total weight of airplane ready to fly!!!   Capt,n
Hide Signatures
(in reply to av8tor1977)
       Post #: 853
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/4/2010 3:34 PM
a1pcfixer
Score: 168
Last Login: 8/16/2012
Status: offline
Gary,
A couple ideas to increase prop-to-ground clearance on your U.S.
Larger dia wheels
Create a block of wood to put between the fuse & the L-G (1/2" or thicker)
Make it about 3/8" longer in front of & behind L-G. Harden the groove the L-G sits in, then when finished, drill some lightening holes in the L-G groove.
For just a few ounces weight you'll be able to increase your prop-to-ground clearance.
Jim L.
Learn from the mistakes of others.You won,t live long enough to make all of them yourself.
Hide Signatures
(in reply to ghoffman)
       Post #: 854
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/4/2010 5:04 PM
somiss1
Score: 100
Status: offline
I think that,as more people run this engine, that we will have good choices for airplanes for this engine. Right now, it's a run what ya brung situation. I also think that it is going to be put in airplanes that are not exactly what people think that the engine could handle. It's all about the way you want the airplane to fly-pattern, 3D, sport are just for cruising around. The beauty of this is the cheap operating cost. No more 20-30% nitro fuel or waiting for the hobby shop to open in order to buy fuel. And, you don't need $130 servos!
Hide Signatures
(in reply to a1pcfixer)
       Post #: 855
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/4/2010 5:32 PM
ghoffman
Score: 163
Status: offline
I just can't get over the performance difference between this and the previous 20cc engine I had on it.
Hide Signatures
(in reply to somiss1)
       Post #: 856
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/4/2010 6:19 PM
ahicks
Score: 669
Status: offline
Maybe this engine, and others like it that are sure to follow, will drive some prop technology that may help what is sure to become a problem in planes being used with them - ground clearance? I get the 3 blade idea that helps out here, but seems like whenever dealing with those, I'm paying a certain very noticable performance penalty?
Jus thinkin....
Hide Signatures
       Post #: 857
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/4/2010 7:39 PM
guinnb
Score: 105
Last Login: 1/23/2012
Status: offline
quote:
ORIGINAL: ahicks
Jus thinkin....
Our problem with model engines and 3-4 blade props is their RPMS. We all know they look cool but the problem is the props start hitting the turbulence/wake of the preceding prop and loose efficiency rapidly. Most scale planes only turn 3-4 blade props up to 2700 rpm or so although turbo props might go beyond this a bit (been a while since I've flown a King Air , mostly of my time is in a Bonanza with a McCauley 3-blade prop driven by an IO 550). Maybe someone more knowledgeable can chime in here....
www.3dorbust.com
Hide Signatures
(in reply to ahicks)
       Post #: 858
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/4/2010 8:47 PM
airraptor
Score: 130
Status: offline
The reason full scale planes run a 3,4,5,6,7,8 blade prop is ground clearence. They have alot of hp in most planes and to run a two blade prop would require a large 2 blade prop. If they could get the ground clearence to fit the prop then they would run in to problems with the tips going super sonic.
You should never fly a 3 or 4 blade prop on a model unless need the clearence on the plane, ie: ground or prop to fuselage (multi engine).
Some model planes run them to keep noise and rpm down when the have alot of hp that can be wasted and helps in keeping a constant speed in the down lines (pattern/imac).
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
(in reply to guinnb)
       Post #: 859
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/4/2010 9:05 PM
NM2K
Score: 161
Status: offline
quote:
ORIGINAL: airraptor
Or, they could keep the small diameter prop, but increase its pitch instead of going even larger with the diameter or adding additional blades. People use large diameter/low pitch props for 3D because their engines won't pull extra pitch, not because extra pitch won't move more air.
Ed Cregger
"Practice makes prefect"
Hide Signatures
(in reply to airraptor)
       Post #: 860
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/4/2010 9:45 PM
ahicks
Score: 669
Status: offline
Isn't using a lot of pitch like that kinda like using a 3 or more bladed prop? You're controlling the load on the engine sure enough, but at what cost to efficiency? We're going to the time/trouble/expense to put this extra power on board, only to toss a (large?) percentage of the extra power overboard because we can't handle it with the current prop designs? (Like one of today's computers running Dos 4.0?)
To illustrate my point maybe, is this not like putting a 10-12" pitch prop on a Cub? We've controlled the load on the engine, but what are the chances of using the the speed envelope a 10-12" prop was designed to run in with this airframe?
My point is it would be nice if propeller technology were to improve/advance to the point we could hold efficiency and reasonable ground clearance without resorting to high pitch or 3+ blades, or way too tall to appear scale gear. It's not just this 20cc engine either. The 25% planes w/30-35cc engines are running into the same thing - only to a little lesser degree. What got me started with this was visualizing an 18" prop on a .60 size airframe. FWIW
Hide Signatures
(in reply to NM2K)
       Post #: 861
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/4/2010 10:16 PM
NM2K
Score: 161
Status: offline
quote:
ORIGINAL: ahicks
To illustrate my point maybe, is this not like putting a 10-12'' pitch prop on a Cub? We've controlled the load on the engine, but what are the chances of using the the speed envelope a 10-12'' prop was designed to run in with this airframe?
My point is it would be nice if propeller technology were to improve/advance to the point we could hold efficiency and reasonable ground clearance without resorting to high pitch or 3+ blades, or way too tall to appear scale gear. It's not just this 20cc engine either. The 25% planes w/30-35cc engines are running into the same thing - only to a little lesser degree. What got me started with this was visualizing an 18'' prop on a .60 size airframe. FWIW
I agree with all of your points.
Today, our model airplane engine technology is becoming similar to what has happened in automotive drag racing some years ago. Drag racers have produced so much extra power with their engines that now the trick is in finding ways to get the power to the ground. Not producing more horsepower. Ditto with model airplanes, although we are only on the cusp of this phenomenon.
Ed Cregger
Hide Signatures
       Post #: 862
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/5/2010 12:04 AM
ghoffman
Score: 163
Status: offline
quote:
ORIGINAL: ahicks
The yellow Ultra Stick is the 60 size!  This engine is light enough to balance the plane perfectly with the servos in the tail, and a 10 oz tank at the CG so it does not change much empty to full.
Hide Signatures
       Post #: 863
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/5/2010 1:08 AM
SpinnerRow
Score: 152
Status: offline
quote:
ORIGINAL: ghoffman
quote:
ORIGINAL: ahicks
Yea, thats one of the planes I want to put this engine on as well.
"Hey!!! That tree was NOT there when I took off!!"
Hide Signatures
       Post #: 864
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/5/2010 1:54 AM
ghoffman
Score: 163
Status: offline
OK, I just got 15 pounds, 2 oz of thrust with the Vess 16-6:
Hide Signatures
(in reply to SpinnerRow)
       Post #: 865
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/5/2010 2:06 AM
Kostas1
Score: 330
Last Login: 5/14/2013
Status: offline
*OMG*
<==**Check my gallery for more pictures**
Club Saito member #706
Hide Signatures
       Post #: 866
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/5/2010 2:14 AM
ghoffman
Score: 163
Status: offline
Yes, that is 6.8 Kg!
Hide Signatures
(in reply to Kostas1)
       Post #: 867
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/5/2010 2:37 AM
scosby
Score: 100
Last Login: 10/12/2012
Status: offline
ghoffman, What are the chances of seeing some video of the Ultrastick with the 20?
Steve
Hide Signatures
       Post #: 868
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/5/2010 2:55 AM
ghoffman
Score: 163
Status: offline
Sure, give me a few days!  I might borrow an on board camcorder too!
Gary
Hide Signatures
(in reply to scosby)
       Post #: 869
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/5/2010 4:09 AM
saintcreed
Score: 100
Status: offline
ghoffman
Got what you got in thrust today. Only I was running a 17 x 6 APC prop at 87-8800 rpm's, with idle down around 1770-1801..Surprised me to say the least. Was only expecting something around 13-14 pounds of thrust...If I knew how to get the pictures out of my Kodak program on to this forum I'd show everyone the pictures of everything I've just stated...All this with only 33 ounces of fuel through the engine..
Only problem so far with the engine is that coming down from high throttle to idle...the rpm's only drop down to around 3200 rpm's then after about 30-45 seconds the engine drops down to the 1770 idle..anyone have any ideas...needles are or have been set so from 1770 to full throttle the transition is smooth...when it does drop down to the 1770 it's not a gradual slow down from 3300 to 1770, it happens in a matter of 3-5 seconds and just sets there idling away.. Almost like someone switched a switch....Thinking it might have something to do with the timming in the ignition modual. Jody mention earllier in this thread about the special ignition to let the engine idle at a lower rpm. Anyone else having this occurance.
It's not as quick in the spool up as my YS 140, but reasonable and will get better with break in. ...The 8 pound 4 ounce Extra 260 this is going on will be a happy camper..
I think it was wrongway that mentioned the harmonics around 25-2700 rpm's...he was right...around those rpm's the monokote sounds like someone is beating on it with drum sticks...then it smooths right out..
If this engine has a good life span with no real issues, I will definetly get another one or two...
Hide Signatures
       Post #: 870
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/5/2010 5:11 AM
a1pcfixer
Score: 168
Status: offline
quote:
ORIGINAL: saintcreed
ghoffman
Yep. I'm seeing the same thing!
Blip the throttle real quick will also bring the high idle back down.
Maybe Jody has an idea of why & a fix?
Jim L.
Hide Signatures
(in reply to saintcreed)
       Post #: 871
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/5/2010 5:28 AM
w8ye
Score: 318
Status: offline
This is usually indicative of a rich setting on the low speed needle
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 872
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/5/2010 6:18 AM
saintcreed
Score: 100
Status: offline
RE: NEW DLE 20cc Gasser! - 10/5/2010 2:28 AM
w8ye
That's what I thought also, but that isn't it...as a rule, not written in stone, rich low means a lag in the transition or loads up and dies, which I do not have. Also with a rich low needle, why after a few seconds it idles right down to 1770 and just set there ticking over, One would think rich low it wouldn't set there with that low of an idle and not flood out and stop running.I'm more than open to any thoughts. Always said to my men that two heads are better than one at times. Sometimes we over think things that are right there in front of us...that's why I was leaning towards the ingnition module and the so call preset timming for the low idle...this isn't my first gasser and I've never had one act quite like this from high to low throttle setting. I checked the timming from the factory and it was at 29 degrees.
Like I state open to suggestions or ideas...I don't walk on water yet therefore I don't know everything...that and they haven't put 6' of dirt over me so I'm still learning..
My first gasser using just one flight battery pak...2300mAh A123. 2 switches, Iso switch on the ign, along with a voltage reducer. Range check on the ground with and without the engine running checked out fine...Futaba 9CS 2.4 radio. and a 608 receiver.
Hide Signatures
(in reply to w8ye)
       Post #: 873
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/5/2010 7:08 AM
rhd-RCU
Score: 100
Status: offline
I have seen the same thing in a glow engine. Needles are wrong.
rd
Hide Signatures
       Post #: 874
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/5/2010 7:15 AM
captinjohn
Score: 247
Status: offline
My guess is that you wanted a smooth idle & set it too lean.  If not...it must be the ignition timing curve.  I do believe some of these small gassers have carbs with too big of venturi.  Put a smaller carb on & they may run great....with some loss at top end rpm.   Capt,n
Hide Signatures
       Post #: 875
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.488RCU1
