RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)    Gallery
Logged in as Guest
Users viewing this topic: Guijs
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Page: <<   < prev  109 110 [111] 112 113 114 115 116 117 118   next >   >>
Login
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/28/2011 12:38 AM
jedijody
Score: 309
Last Login: 1/15/2013
Status: offline
Here's a couple of tuning articles for you, one written by me and one from Pe Reivers.
For break-in, use the same prop you want to fly the plane with normally, there is no need for a lighter loading propeller for break -in. Fly the plane in a manner that creates load on the engine to build up some heat followed by an unloaded sequence that allows the engine to cool down. By that I don't mean you need to fly like your plane is on a Yo-Yo string going up and down constantly but regular aerobatic sequence flying similar to IMAC basic and intermediate sequences do a very good job of heat cycling the engine in the air. Most important though is that you make sure you have adequate cooling air flow into and out of the cowl so the engine can cool down when you do throttle back. Some light 3D is fine but refrain from doing any high RPM, low air flow maneuvers like, hovering for extended periods,  flat and knife edge spins, they generate lots of heat very quickly.
Here's a link to Pe Reivers' website, his forum pages are a goldmine of useful information. http://www.prme.nl/
Click to see the file in new window.Attachment.pdf Click to see the file in new window.Attachment.pdf
_____________________________
Now go outside and play
Hide Signatures
(in reply to spete2000)
       Post #: 2751
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/28/2011 12:54 AM
blhollo2
Score: 204
Last Login: 6/12/2013
Status: offline
i fixed my engine stutter problem, it was as you said the stock spark plugs are horrible, i got a new ngk 6cm plug and vroom its good!
Hide Signatures
(in reply to jedijody)
       Post #: 2752
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/28/2011 1:20 AM
jedijody
Score: 309
Status: offline
Gotta have a good glow plug!
Hide Signatures
(in reply to blhollo2)
       Post #: 2753
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/28/2011 1:59 PM
airborne2.4
Score: 105
Last Login: 6/16/2013
Status: offline
LOL
If you think you can or think you can''''t, you''''re right.
Hide Signatures
       Post #: 2754
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/28/2011 2:09 PM
wvrcracer
Score: 100
Last Login: 11/18/2012
Status: offline
Finally got to try the CM6 plug-made starting alot easier. this is how i imagined it should start. Now-if i can just get the d*** snow cleared out
Hide Signatures
(in reply to airborne2.4)
       Post #: 2755
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/28/2011 4:20 PM
spete2000
Score: 100
Last Login: 6/10/2013
Status: offline
quote:
ORIGINAL: a1pcfixer
{Post #1}
-OR-
The sticky [Newbie to Gas General Information] top of this gas engines forum, near to last msg in that thread.
Hi Jim, and thank you for the information. That will definitely help when I break it in.
Steve
Hide Signatures
(in reply to a1pcfixer)
       Post #: 2756
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/28/2011 5:04 PM
spete2000
Score: 100
Status: offline
Hi Jody,
At some time, you had compiled a list of the DLE 20 engines specifications, dimensions and parameters that was quite complete. I have a friend, and, myself who would like to peruse that list, but I have searched and not found it. Would you please post that list again, or at least show a location, address, or post number so that I can reclaim that information?
Thanks again, Steve
Hide Signatures
       Post #: 2757
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/28/2011 5:28 PM
microdon2
Score: 110
Last Login: 6/20/2013
Status: offline
wvrcracer - Just back from a flying session in deep snow. I brought a shovel out to the field with me - good thing, too, cause the snow was 18" deep over the entire field. Had to stop three times to catch my breath just trudging out to my flying spot (about 1,000 feet from the parking lot). I dug a clearing about 15'x15' as my "base camp". Worked great! The snow here is still a bit compactable, though (just got 18" two nights ago), so you have to be careful to do smooth landings and takeoffs. Anything "bouncy" will put the plane RIGHT into the snow. I had one "flip" today, which bent a ski. Now have to figure out how to reinforce skis without adding too much weight. But smooth landings are SO cool.
Hide Signatures
       Post #: 2758
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/28/2011 6:02 PM
jedijody
Score: 309
Status: offline
quote:
ORIGINAL: spete2000
Hi Jody,
Thanks again, Steve
Post #1 in this thread.
Give credit to a1pcfixer for it's completeness and organization. it's all the information I originaly posted and and ton of other stuff from others. Thanks Jim!
Hide Signatures
       Post #: 2759
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/28/2011 6:12 PM
a1pcfixer
Score: 168
Last Login: 8/16/2012
Status: offline
quote:
ORIGINAL: spete2000
Such a list of all that info is embedded in Post #1.
Jody contributed a bunch to that, but I complied all that data from the many users in this thread.
Look in Post #1 under; [Basic Info] and under [Dimensions] , plus other sections of it.
There's possibly more & better info in that, than what's in the manual(s).
Jim L.
Learn from the mistakes of others.You won,t live long enough to make all of them yourself.
Hide Signatures
       Post #: 2760
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/28/2011 6:17 PM
a1pcfixer
Score: 168
Status: offline
quote:
ORIGINAL: microdon2
wvrcracer - Just back from a flying session in deep snow. .................Now have to figure out how to reinforce skis without adding too much weight. But smooth landings are SO cool.
It is indeed a lot of fun to fly off the snow. Planes jump into the air!
There's a thread I started here on RCU about such;
http://www.rcuniverse.com/forum/fb.asp?m=10205699
As to your ski's, think about these, might be what ya need;
http://www.maidenusammp.com/products.htm
Jim L.
Hide Signatures
(in reply to microdon2)
       Post #: 2761
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/28/2011 6:35 PM
ghoffman
Score: 163
Last Login: 6/19/2013
Status: offline
I will be using them on my DLE-20 Ultra Stick combo on Sunday!  On Saturday, some guys are going to pack the snow with snowmachines for the Club's "Frozen Fingers Fly In".
Hide Signatures
       Post #: 2762
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/28/2011 6:51 PM
microdon2
Score: 110
Status: offline
a1pcfixer - Those Maiden's are the skis I'm using! (and bending). They are good skis, but even they aren't (evidently) designed to take the stress of an entire plane nosing into 18" powder. I'll reinforce and let Maiden know, in case they might want to upgrade their product. And that's for the link to the Winter Snow Fliers thread - I'll contribute!
Hide Signatures
(in reply to ghoffman)
       Post #: 2763
Warren
Score: 100
Status: offline
quote:
ORIGINAL: ghoffman
I will be using them on my DLE-20 Ultra Stick combo on Sunday!  On Saturday, some guys are going to pack the snow with snowmachines for the Club's ''Frozen Fingers Fly In''.
Any pics? Ultra Stick 60?
How did the balance come out?
Warren
AMA 19909 - LSF 8170 LVL III
Hide Signatures
       Post #: 2764
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/28/2011 7:15 PM
spete2000
Score: 100
Status: offline
Hello a1pcfixer and Jody,
Thank you both for getting the address to us. I've read so much about the DLE 20 for so long, I couldn't recollect where I had seen everything at. Or, it could be because of maturity, and mental development. In any case, thanks again for the information. It is great.
Steve
Hide Signatures
       Post #: 2765
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/28/2011 10:16 PM
a1pcfixer
Score: 168
Status: offline
Jody & Steve,
You're welcome!
Steve - also look at the top of this page (pg 111) as Jody listed more tuning info & 2 links (files) as well.
Jim L.
Hide Signatures
       Post #: 2766
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/29/2011 2:36 AM
bolkow
Score: 100
Last Login: 6/6/2011
Status: offline
My DLE 20 in the Ultra Stick 60 did not require any extra weight. 2000mah 5 cell reciever battery behind the servos,10oz tank in front of the servos, 2000 mah 4cell beside the fuel tank, ign in the old fuel tank compartment.
No trim change required from my previous setup with OS 91.
Flies like a rocket. I now have three hours on it. Love it!
Hide Signatures
       Post #: 2767
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/29/2011 3:24 AM
Silverwing
Score: 100
Last Login: 4/20/2013
Status: offline
To Jody or who would like to answer,
What is the best oil and mix ration for the DLE20 and 30
Tom
Hide Signatures
(in reply to bolkow)
       Post #: 2768
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/29/2011 3:25 AM
Silverwing
Score: 100
Status: offline
Ratio, LOL
Hide Signatures
(in reply to Silverwing)
       Post #: 2769
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/29/2011 3:47 AM
Warren
Score: 100
Status: offline
quote:
ORIGINAL: bolkow
Cool - Thanks for the feedback!
Warren
Hide Signatures
       Post #: 2770
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/29/2011 4:12 AM
jedijody
Score: 309
Status: offline
quote:
ORIGINAL: Silverwing
Tom
32:1, I use Stihl HP Ultra, there are many other suitable oils that can be used.
Hide Signatures
       Post #: 2771
bolkow
Score: 100
Status: offline
Also, MAS 16x8, wood prop. Vertical forever. Oil,Penzoil @ 32-1. Idle 1840, max RPM 7860.
Hide Signatures
(in reply to Warren)
       Post #: 2772
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/29/2011 4:39 AM
Silverwing
Score: 100
Status: offline
Recorded and many thanks!
Hide Signatures
       Post #: 2773
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/29/2011 7:56 AM
spete2000
Score: 100
Status: offline
Hi Silverwing,
I use Stihl, HP ULTRA, 32:1 for my DLE 20
Steve
Hide Signatures
       Post #: 2774
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/30/2011 5:14 AM  1 votes
bcchi
Score: 650
Status: offline
quote:
ORIGINAL: Antique
Xu Liang changed the ignition for the DLE 20...It has a goofy curve compared to the older ones...There was NO probem with the advance curve on the original ignitions, why it was changed is a mystery...A small gasser will run just fine with spark set at 28 BTDC and NO curve in the ignition....The new curve changes abruptly, not linear like the original...You don't NEED any curve at all....Most ignitions will be at
full advance at 4000 rpm anyway..
Bill Carpenter has confirmed this with the new ignition....Anyone thiinks they know more about ignitions than he does is kidding himself...
The goofy curve makes the rpm change just when you don't want it to...
The only thing a curve does is change the position of the throttle stick at a certain rpm anyway...
Your turn Bcchi
Go away,
Got to fly today.about 40F,no snow,no wind,low humid and blue sky and Sun.Nice day in Jan in Wyoming.Had a friend with a new DL 20 at the field today .Started right up ran good but had fuel leaking out around a engine mounting bolt. He pulled the engine and fuel coming out into mounting bolt hole. Pulled the rear cover and a few pin holes in machined area of the case one of the larger ones went clear through and into the engine mounting hole. Poor QC.I was not he seller,or I would have gave him a new engine. He will call the seller onMon.
Time for JB weld.Flew my 20 a bunch cannot believe power of this litter gasser. Has a Bowman ring ,RCEXL iradium spark plug and my new little light weight ign with Syncro spark TC. Will idle at 1500. 17x8 APC.8100.
They say 12 to 20 below F on tues mourn.
Go away BCCHI
Hide Signatures
(in reply to Antique)
       Post #: 2775
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.000RCU1
