RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)    Gallery
Logged in as Guest
Users viewing this topic: Jonde
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Page: <<   < prev  116 117 [118] 119 120 121 122 123 124 125   next >   >>
Login
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 5:29 PM
lazyace
Score: 100
Last Login: 5/22/2013
Status: offline
I"m thinking this is a tread for the DLE 20 not for batts , but I might be wrong
_____________________________
charlie AMA 8916
WACO brotherhood #67
Hide Signatures
(in reply to Woody218)
       Post #: 2926
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 5:42 PM
Woody218
Score: 145
Status: offline
Without batteries, the DLE 20 is just a nice little paperweight.
AMA #21855
Gravity always wins...
Hide Signatures
(in reply to lazyace)
       Post #: 2927
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 5:59 PM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: lazyace
It looks like a thread with good data you NEED to run your DLE20...if you even have one.  Bet you do not.
I never met a engine I did not like !
Hide Signatures
       Post #: 2928
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 6:32 PM
dutchy50
Score: 101
Last Login: 5/23/2013
Status: offline
Thanks for explaining the reason why!
I`m using one 4.8v x 2000 mAh NiMH for ignition and 6v x 2000 mAh NiMH for Rx and digital servos, this is in a 1/7th scale P-51 Mustang, 20cc.
dutchy50
Hide Signatures
(in reply to Heritage rider)
       Post #: 2929
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 6:52 PM
hairy46
Score: 183
Status: offline
I am way behind on this tread, So is the DLE 20 a keeper? How have they been doing in the air?
Hide Signatures
(in reply to dutchy50)
       Post #: 2930
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 7:05 PM
desertdog
Score: 100
Last Login: 8/18/2012
Status: offline
For me, I love it, and doubt I will ever purchase a glow engine again.
Hide Signatures
(in reply to hairy46)
       Post #: 2931
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 7:06 PM
Woody218
Score: 145
Status: offline
The DLE 20 is for sure a keeper!!
AMA #21855
Hide Signatures
(in reply to desertdog)
       Post #: 2932
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 7:10 PM
SpinnerRow
Score: 152
Status: offline
quote:
ORIGINAL: desertdog
I'm about to sell two glow planes and buy another 1.20 sized plane and DLE 20. I love this little motor!
"Hey!!! That tree was NOT there when I took off!!"
Hide Signatures
       Post #: 2933
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 7:14 PM
desertdog
Score: 100
Status: offline
Ditto, I have been waiting a long time for a gasser like the dle 20cc. It is so user friendly, it's shocking at first.
Hide Signatures
(in reply to SpinnerRow)
       Post #: 2934
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 7:15 PM
iflywhenican
Score: 100
Last Login: 5/15/2013
Status: offline
quote:
ORIGINAL: Woody218-RCU
quote:
ORIGINAL: SpinnerRow
You'd swear the CEO of A123 Systems was posting and he just found out I slept with his daughter!
Did you?
No, but I did stay at the Holiday Inn last night.
If you have to bend over more than once, it wasn''t a good landing....
Hide Signatures
       Post #: 2935
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 7:32 PM
sandyjain
Score: 100
Status: offline
quote:
ORIGINAL: Slats!
Sandy, Would you just run a Y off the pack to get the pump powered?
I ditto what is said above. I too use 2 batts in a 50 and 30cc but for the 20 1 is more than Enuf. I use 2 switches and a diode for the ignition. On a normal flying day I manage 4 flights and the recharge is 800 mah I.e. 200 per 8-10 min flight. Hence even the 2300 I use is an overkill. I am now planning to use a smoke setup on that 1 batt !!!
Yes I would do something like that. My batt has a deans connector. So I have made a lead that has dean one side and futaba connectors on the other side. One connector goes to the Rx. The other has a diode inline and goes to the ignition. I will now add one more for the smoke.
Cheers....
Sandy Jain
Hide Signatures
(in reply to Slats!)
       Post #: 2936
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 7:34 PM
skyriter
Score: 100
Status: offline
Those of you that are running A123 batteries and using a diode to run the ignition... are you running with just 1 diode or 2. Have saw info that indicated both cases. I am setting up a Seagull Extra 260 with a DLE 20 and am planning on using just 1 2300 A123 to power both RX and Ign. The battery has 2 leads and will be using 2 switches , rcxel ignition cutoff etc.
Bruce
Hide Signatures
(in reply to iflywhenican)
       Post #: 2937
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 7:37 PM
hairy46
Score: 183
Status: offline
Thanks that gets me up to speed on the DLE 20 Jody will hear from me soon!
Hide Signatures
(in reply to skyriter)
       Post #: 2938
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 7:46 PM
sandyjain
Score: 100
Status: offline
I use a single 2100mah A123 pack for everything, if I have to recharge after a couple flights, so what? I can charge the pack in 15 minutes...
Now if you were on F L Y I N G G I A N T S . C O M. they would be jumping all over you because you said 2100mah and A123 in the same sentence like they did with me. I called a 42% 2600 LiFe battery an A123 and you would have thought I called the pope Adolf Hitler!. There is too much cork sniffing going on on that site. I've never been able to bond with those guys over there!
It's simple. A123 are lithium Iron phosphate with the phosphate in nano form and come only in 1100 or 2300 mah capacities. All others are Lithium Iron Phosphate and may come in other capacities. A123 claim unto 60C discharge and 5C charge rates. I will be careful not to take this for granted for the non A123's. BUT for Rx, ignition use we never require more than 5C discharge and IMHO 1or 2C charge is good enuf for most of us. Hence regular LiFe ( non A123) are gud enuf for our use. I am personally using both A123 and the much cheaper Chinese LiFe - incidentally both 2300 mah - for more than 6 months now and find no difference.
Cheers....
Sandy Jain
Hide Signatures
       Post #: 2939
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 7:54 PM
sandyjain
Score: 100
Status: offline
quote:
ORIGINAL: skyriter
Bruce
Bruce I am using exactly the above - DLE20, seagull Extra 260, single LiFe 2300 mah, APC 17x6 @ 8800 RPM AND I use only 1 diode 1N4001 for the ignition. This drops the voltage by .9V to 5.7V - do not worry about the peak charge voltage of 7.2V as it lasts for A very short while. I use a double switch with charge jacks from sdshobby.net.
A typical flight of 8-10 min. Uses 200 mah.
Cheers....
Sandy Jain
Hide Signatures
       Post #: 2940
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 8:05 PM
skyriter
Score: 100
Status: offline
Thanks for the info. I was planning on using the 1N4007 diode.. Think the voltage drop is the same.
I am planning on using a Jtec pitts muffler (if it ever comes... you know customs). Want to quiet it down a little.
Bruce
Hide Signatures
(in reply to sandyjain)
       Post #: 2941
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 8:19 PM
Woody218
Score: 145
Status: offline
The only difference in diodes like the 1N4001 through 1N4007 is their reverse voltage rating. Since we are not subjecting these diodes to any reverse voltages, the 4001 is entirely adequate.
AMA #21855
Hide Signatures
       Post #: 2942
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 9:05 PM
a1pcfixer
Score: 168
Last Login: 8/16/2012
Status: offline
quote:
ORIGINAL: sandyjain
Better explained here;
http://tinyurl.com/4fj8cjb
But injecting facts for a knowledgable argument is gonna ruin the fun!
Let's all have a good;
Click to see fullsize image.
Click for fullsize
Jim L.
Learn from the mistakes of others.You won,t live long enough to make all of them yourself.
Hide Signatures
       Post #: 2943
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 9:28 PM
vinmech
Score: 100
Last Login: 5/20/2013
Status: offline
I run a World Models .60 sized PetieII P-51 with this Dle 20cc and love it. I use a 2200 ma 6v Nimh, Syssa Ibec and one switch to run 7 servo's, including retracts and ignition!
I am running a 16x10 Master airscrew classic at about 8400 rpm's. This set-up is just under 10 lbs. It scoots and is a blast to bore holes in the sky with.
I maidened a Showtime 90 with this same motor for a buddy today. That is a sweet combo! Half throttle or so hovers, tracks like it is on rails, definitely a keeper!
It is also a 1 battery set-up much like mine. Don't know it's weight, but was lighter than the P-51 by about a pound or so. He had a 16x6 on it, to small. Told him to get a 17x6, should hit the sweet spot.
Seems everyone is coming out with a Dle 20 cc conversion here, I think glow will be relegated to 40 size and below very soon!!
Hide Signatures
(in reply to a1pcfixer)
       Post #: 2944
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 9:30 PM
SpinnerRow
Score: 152
Status: offline
quote:
ORIGINAL: a1pcfixer
quote:
ORIGINAL: sandyjain
I'm enjoying the cork sniffery myself. The little cry icon thingy looks better like this:
Hide Signatures
       Post #: 2945
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 9:32 PM
SpinnerRow
Score: 152
Status: offline
quote:
ORIGINAL: vinmech
Oooooo, I'll have to try that prop. It will take dings better I'm sure.
Hide Signatures
(in reply to vinmech)
       Post #: 2946
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 9:44 PM
ghoffman
Score: 163
Status: offline
quote:
ORIGINAL: vinmech
I have now sold all my glow stuff and will never go back.
Hide Signatures
       Post #: 2947
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 10:12 PM
desertdog
Score: 100
Status: offline
I'm with you.
Hide Signatures
(in reply to ghoffman)
       Post #: 2948
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 10:57 PM
Woody218
Score: 145
Status: offline
AMA #21855
Hide Signatures
       Post #: 2949
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/12/2011 11:25 PM
brenthampton79
Score: 105
Last Login: 5/17/2013
Status: offline
Got to fly my gp extra 300s kit .60 with the dle on it today and it flew really good I am very pleased and this is the begining of the end for glow engines for myself as well I think. The plane flew like it was on rails and the dle performed effortlessly, I need to tune her a little more, had a little miss but this is the second tank of fuel in it so, im not complaining. I figure I'll just break my engine in while im flying it
N802KC AT-802A Work
N66EC Pitts S1-S Fun!!
Hide Signatures
       Post #: 2950
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.609RCU1
