RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Page: <<   < prev  219 220 [221] 222 223 224 225 226 227 228   next >   >>
Login
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/24/2012 2:56 PM
w8ye
Score: 318
Last Login: 5/19/2013
Status: offline
Expected to be in stock about the middle of July
http://www.valleyviewrc.com/estore/dle-35ra-gas-engine.html
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to bgw45)
       Post #: 5501
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/24/2012 3:10 PM
acdii
Score: 155
Last Login: 5/18/2013
Status: offline
What is the 35cc equivalent to in the 4 stroke range?
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
(in reply to w8ye)
       Post #: 5502
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/24/2012 4:46 PM
Falcon32
Score: 105
Last Login: 5/15/2013
Status: offline
Thanks W8Ye Will use 32:1
Falcon
I’d rather be twiddling my thumbs.
Hide Signatures
(in reply to w8ye)
       Post #: 5503
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/24/2012 10:38 PM
bgw45
Score: 113
Status: offline
Thanks, w8ye, for correcting me. Could what my wife says about my listening be also true about my reading?
Hide Signatures
(in reply to w8ye)
       Post #: 5504
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/24/2012 10:51 PM
tailskid
Score: 199
Status: online
Still can not get the throtte to work smoothly (as easy as the choke)....anyone help? It takes both hands to move the throttle from idle to full!!!!
Jerry
PS I pushed from the bottom and pulled from the top and it is getting a bit easier, but no where near what it was.
Click to see fullsize image.
Click for fullsize
# 93 in Club Saito
Carl Goldberg Ultimate Brotherhood # 12
Hide Signatures
(in reply to bgw45)
       Post #: 5505
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/24/2012 11:09 PM
tailskid
Score: 199
Status: online
quote:
ORIGINAL: microdon2
tailskid - try taking the throttle plate off. Maybe you pushed the axle a bit and the plate is binding inside the carb throat. And, as Twin Flyer said, I've also pushed the throttle arm down too far before tightening, causing binding between the arm seat and the carb. I doubt you bent the throttle axle.
Here are some pictures of the carb closed...it doesn't look like there is any evidence that the plate is binding but I may be in error.
Thanks for the advice microdon2!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
# 93 in Club Saito
Hide Signatures
(in reply to microdon2)
       Post #: 5506
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/25/2012 4:39 AM  1 votes
microdon2
Score: 110
Last Login: 5/14/2013
Status: offline
tailskid - did you try removing the throttle plate to see if it made a difference? It's very easy to get off and back on, btw.
Hide Signatures
(in reply to tailskid)
       Post #: 5507
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/25/2012 4:47 AM
tailskid
Score: 199
Status: online
No I haven't...but I'll try that next....thanks microdon2!
# 93 in Club Saito
Hide Signatures
       Post #: 5508
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/25/2012 4:54 AM
tailskid
Score: 199
Status: online
Took out the throttle plate and it made no difference Maybe I did bend the brass - but that is hard to believe.....do you think a 'normal' 2-cycle lawn mower dealer could fix it?
Jerry
# 93 in Club Saito
Hide Signatures
       Post #: 5509
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/25/2012 6:21 AM
mach2
Score: 125
Last Login: 5/12/2013
Status: offline
If I remember right, that is an old post....but im glad he dug it up, because I DIDNT KNOW ABOUT A DLE 35R!  Ive gotta look that up!
ALSO! valleyviewrc.com as the DLE20 on sale for $245. And they give you a free prop with an engine purchase...
70" Revolver, DLE20
67" Goldberg Edge 540, DLE20
Hide Signatures
(in reply to bgw45)
       Post #: 5510
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/25/2012 6:30 AM
mach2
Score: 125
Status: offline
well I just checked on it. It better have a way better power to weight ratio since it costs what a DLE55 costs.....
Most 30cc planes Im looking at can be hovered with a 28cc engine with no problem. The extra cost will probably keep me away from the new 35R. If im spending that much, Ill spend a few more bucks on the plane and get an 88" 50cc plane and the DLE55.
It makes sense that the cost is a wash with the addition of a pitts muffler, but Ive never even considered buying a pitts muffler because they are ridiculously  priced. I did by one for 20 bucks used once...
And the way the muffler is mounted on the 35R makes it to where the engine cannot be moved back at all. The Goldwing MX2 needs to have the DLE30 moved back for the spinner to meet up with the cowl ring well. The firewall has to be opened up to slide the carb through. Also, I dont mind the look of either DLE 20 or 30 mufflers.
Just my personal opinion. But its always good when companies make more options. Id like to see a DLE 15, and a DLE 75 or 85
Jeremy
70" Revolver, DLE20
Hide Signatures
(in reply to mach2)
       Post #: 5511
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/25/2012 9:01 AM
grosbeak
Score: 140
Last Login: 5/16/2013
Status: offline
Lesson learned: Anything loose can get sucked into the engine.
See the whole story at DLE 20 won't stay running.
MAAC 83386
Stetson Flyers, Ottawa
Hide Signatures
(in reply to mach2)
       Post #: 5512
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/25/2012 5:51 PM  1 votes
FOOPED
Score: 105
Status: offline
tailskid chances are you twisted the shaft and being flat in the middle for the throttle plate makes it essenctric and will cause binding. I sent you a PM. Hope this will help.
Hide Signatures
       Post #: 5513
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/25/2012 8:21 PM
tailskid
Score: 199
Status: online
Thanks for the email Fooped...I'll check it out!
# 93 in Club Saito
Hide Signatures
(in reply to FOOPED)
       Post #: 5514
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/27/2012 8:05 PM
Falcon32
Score: 105
Status: offline
Hi Guys
I would like to ask one more question.
I have replaced the ignition unit to the rcexl one without the funny advance.
On checking the timing with the rcexl ignition tester I get around 36-38 degrees.
I don't think the original sensor will give me enough movement to change that by much.
Will I need to fit the new sensor that came with the ignition unit and set it at 28 degrees.
Falcon
Hide Signatures
(in reply to w8ye)
       Post #: 5515
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/27/2012 8:17 PM
w8ye
Score: 318
Status: offline
When checking the timing, you must turn the crankshaft in the direction that the engine normally runs for the spark plug will fire when the magnet comes out from under the sensor no matter which way you turn the crankshaft.
Original AMA #31261
Hide Signatures
(in reply to Falcon32)
       Post #: 5516
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/27/2012 8:48 PM
Falcon32
Score: 105
Status: offline
Thanks w8ye.
I'm OK on the method, just need to know if I need to re time it to 28 degrees with the standard (not the No4) ignition, and will I need to use the new sensor and adjustable bracket.
Falcon
Hide Signatures
(in reply to w8ye)
       Post #: 5517
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/27/2012 10:30 PM
triumphman49
Score: 110
Status: offline
Hello Falcon32,
From top DEAD center, believe you should be ok if you get within a couple of degrees of 28. Worth a try before changing sensor mounts.
Hide Signatures
       Post #: 5518
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/27/2012 10:37 PM
Falcon32
Score: 105
Status: offline
Thanks, I'll see if I can adjust the existing bracket to get me to 28 degrees.
Falcon
Hide Signatures
(in reply to triumphman49)
       Post #: 5519
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/27/2012 10:59 PM
w8ye
Score: 318
Status: offline
The original ignition sensor on the DLE 20 is mounted centered on the casting seam on the bottom of the engine. This sensor will work fine with any RCEXL ignition "as is" if the sensor is good.
Original AMA #31261
Hide Signatures
       Post #: 5520
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/28/2012 1:20 PM
bgw45
Score: 113
Status: offline
The instructions on the RCXL checker say that the prop hub should be turned to the point when the beeper goes off. The beeper off point is the proper timing point. This can be confirmed by simply installing a cm6 in the cap and it will fire at the same point.
I did not read the instructions and misled myself till Jody squared me away.
Hide Signatures
(in reply to w8ye)
       Post #: 5521
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/28/2012 8:44 PM
tailskid
Score: 199
Status: online
Throttle shaft is twisted...yep, it is twisted and now I need a replacement - any suggestions on who handles these engines?
# 93 in Club Saito
Hide Signatures
(in reply to bgw45)
       Post #: 5522
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/28/2012 8:58 PM
Falcon32
Score: 105
Status: offline
Hi Guys
Thanks for all the information you have posted, but I think I need to clarify a couple of points.
I'm sure that the sensor fitted to the engine is in good condition and will get the engine running.
Also I know how to use the RCXL tester unit correctly although the instructions are not that helpful.
The real issue is that if you read the Hobbico manual for the DLE 20 it states the timing to be 38-40 degrees BTDC.
Using the tester I'm getting about 38, which I believe is correct if using the original #4 ignition unit.
However I've swopped that one out for the unit more commonly used on the DLE 55 where the timing is 28 degrees BTDC.
My question therefore is should I leave the timing at 38 degrees or change to 28 degrees.
Thanks for your patience.
Falcon
Hide Signatures
(in reply to bgw45)
       Post #: 5523
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/28/2012 9:23 PM
Twin_Flyer
Score: 108
Status: offline
Tower Hobbies...
$35.00
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXANVR&P=Z
Bill S.
Carl Goldberg Ultimate Brotherhood #56
Ultra Sport Brotherhood #135
http://radiocontrolhobbies.freeservers.com
Hide Signatures
       Post #: 5524
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 6/28/2012 9:34 PM
tailskid
Score: 199
Status: online
Thanks Bill....but it says it is for the 30cc.........maybe the same carb. CRAP I hate to spend $35 when all I need is that stupid throttle part..........such is life I guess.
Jerry
# 93 in Club Saito
Hide Signatures
(in reply to Twin_Flyer)
       Post #: 5525
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.750RCU1
