RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Page: <<   < prev  235 236 [237] 238 239 240 241 242 243 244   next >   >>
Login
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 4:13 AM
armody
Score: 114
Last Login: 5/22/2013
Status: offline
One thing again I'd like to ask, and I asked earlier and was not answered.
Which synthetic oil is good for DLE20, Klotz, Red Line, Stihl or Pennzoil. Can anyone tell me the specifications or which one to be bought other than Klotz, as I'm already using Klotz and do I gotta stick with it?
Mody
_____________________________
It''s great2 keep flying invariably. Hitec Aurora9 2.4 GHz, Yak 54-120 /XYZ20, Kadet II, U-Sport Kits, MXS-R RCG20 (AMA Mem)
Hide Signatures
(in reply to armody)
       Post #: 5901
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 4:18 AM
rcguy59
Score: 129
Last Login: 5/21/2013
Status: offline
I run DLE 20's, 30's, a 35 and a 55. I use 32:1 in all of them and have never fouled a plug, either. I have used only 87 octane, though 89 is fine if it makes you feel better. Keep in mind, all of my engines spend most of their time at or near full throttle because they are all in warbirds except for a 30, which is in an RV-4 and flogged just like the rest.
Jet Central Superbee & Rabbit
12Z Fasst for everything I fly
Hide Signatures
(in reply to tailskid)
       Post #: 5902
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 4:25 AM
w8ye
Score: 318
Status: online
quote:
ORIGINAL: armody
Mody
Those are all good ones.
I would not switch around to different brands. They require re-adjusting the needle valves sometimes.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 5903
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 4:34 AM
armody
Score: 114
Status: offline
rcguy59 and w8ye
Thanks a lot guys for the answers, I got all answers for now . I've installed it in my Yak 54 120 from nitroplanes, ain't a warbird.
The warbird I want for my Xmas gift is Seagull Model Dewoitine D.520 and get another DLE20 on it
http://www.horizonhobby.com/products/SEA2580. I love P51 Mustangs, but I've found to be the best replacement of Mustang!
Hide Signatures
(in reply to w8ye)
       Post #: 5904
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 4:42 AM
rcguy59
Score: 129
Status: offline
Though I'm not connected with ValleyView RC, I fly with them and belong to the same club. They have used Stihl HP Ultra for as long as I can remember, with excellent results, and continue to recommend it. The 30:1 oil mix ratio is for those using the Metric system. Those of us who still think in ounces find 32:1 easier to deal with. The engines don't seem to care one way or the other.
Hide Signatures
(in reply to w8ye)
       Post #: 5905
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 4:44 AM
armody
Score: 114
Status: offline
I stick with 32:1 ratio, I like Oz. better it's more easy. Probably the next DLE20 I'm gonna use Stihl or Red Line. I gotta get to know this DLE20 first with Klotz then think about something else.
Hide Signatures
(in reply to rcguy59)
       Post #: 5906
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 6:37 AM
tailskid
Score: 199
Status: offline
The instructions I received indicated 40:1 oil. As far as more oil.....less wear and tear - right?
# 93 in Club Saito
Carl Goldberg Ultimate Brotherhood # 12
Hide Signatures
       Post #: 5907
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 11:33 AM
w8ye
Score: 318
Status: online
quote:
ORIGINAL: tailskid
For the DLE 20 you had best use the 30 or 32:1 ratio or face possible trouble with the rod.
If you have a DLE30 or larger, 40:1 is fine.
Original AMA #31261
Hide Signatures
       Post #: 5908
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 12:03 PM
RiverLarry
Score: 100
Status: offline
 W8YE  mite as well just  stick with  32 / 1   like you said !!!
why have 2 tanks of gas to carry around with you !!!!
less chance on making a mistake       that mix  wont hurt a thing   (   KISS  )   (  KEEP IT SIMPLE STUPED )
is a good rule to go by   O  I am not calling any body       STUPED       dont need to open that can up  !!!!!
as long as a person is using a GOOD graid  oil   thay  should not  have  any truble
  DONT NEED TO HAVE  A    OIL   FIGHT !!!!              R/L
Hide Signatures
(in reply to w8ye)
       Post #: 5909
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 2:31 PM
w8ye
Score: 318
Status: online
+1
Original AMA #31261
Hide Signatures
(in reply to RiverLarry)
       Post #: 5910
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 3:20 PM
wesjon
Score: 100
Last Login: 4/3/2013
Status: offline
 Hi guys
I am having issues with my DLE 20. I have run about 3 litres through it and had it running perfectly. I had to remove the tank to lengthen some tubing and since then it just wont run properly. I can get it started, idles for a while, but then wants to quit. I have tried every needle adjustment possible but still it does this. It also get flooded all the time. I remove the plug and its drowning in raw fuel. Any ideas?
I have taken it off my airframe and have it hooked up on a test bench. Suppose I could close the needles completely and see if it still somehow manages to draw fuel....
Hide Signatures
(in reply to w8ye)
       Post #: 5911
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 3:24 PM
afjetmech
Score: 105
Status: offline
quote:
ORIGINAL: wesjon
 Hi guys
Time to take apart the carb. Seeing as you messed with the tank, it probably got something in it that is clogging an orrifice or jet.
Hide Signatures
(in reply to wesjon)
       Post #: 5912
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 3:26 PM
wesjon
Score: 100
Status: offline
All I did was rearrange some tubing on the tank but who knows...I think you are right in saying its time to take the carb apart and have a look.
Hide Signatures
(in reply to afjetmech)
       Post #: 5913
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 3:31 PM
microdon2
Score: 110
Last Login: 5/14/2013
Status: offline
Also possible that you have a vacuum leak somewhere in that new \ moved tubing.
Hide Signatures
       Post #: 5914
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 4:14 PM
757jonp
Score: 110
Status: offline
For those of you that desire to correct that annoying timing curve here's the cure, and the price is right. I installed this on my Mojo 65/DLE 20 and it worked great. No more funny business on the lower RPM ranges! Ignition is RCEXEL with a "Paragon" sticker on it, unknown what model, but I suspect it's 01 (for 50cc RCG engines) .
http://www.hobbyking.com/hobbyking/store/__10996__Replacement_CDI_Ignition_for_RCG_50CC_Engines.html
Hide Signatures
(in reply to microdon2)
       Post #: 5915
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 4:21 PM
wesjon
Score: 100
Status: offline
quote:
ORIGINAL: microdon2
Highly possible actually as I had to lengthen the filling tube by adding another piece of tubing by using a metal joiner used for filling applications which came with my hand pump. etc. I doubt this is made for being under pressure and may be causing a vacuum leak to be honest. Will replace with one piece of tubing and see. Must be this as it is the only thing that I changed.....Will keep you posted!
Hide Signatures
       Post #: 5916
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 4:36 PM
microdon2
Score: 110
Status: offline
wesjon - Unless absolutely necessary get rid of joiners. And use them only if they have barbs on each end. I used to use a fueling port - but it leaked air - got rid of it.
Hide Signatures
       Post #: 5917
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 5:42 PM
acdii
Score: 155
Last Login: 5/20/2013
Status: offline
I read somewhere to use dino for the first few gallons before using Synthetic in these. I dont remember where I read that though or I would linky it.
jonp, is that out of the US warehouse?
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
       Post #: 5918
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 6:00 PM
757jonp
Score: 110
Status: offline
acdii... No, it's from the international section. As far as I can tell, the US warehouse does not stock parts of any kind. I just found this ignition while searching for something else.
Hide Signatures
(in reply to acdii)
       Post #: 5919
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 6:57 PM
acdii
Score: 155
Status: offline
well bugger that, last time I ordered from them I had issues with my bank.
Hide Signatures
(in reply to 757jonp)
       Post #: 5920
RE: DLE 20cc Gasser! (Data & Links 1st Post) - 11/15/2012 4:06 AM
rcguy59
Score: 129
Status: offline
< Message edited by rcguy59 -- 11/17/2012 11:34 PM >
Hide Signatures
(in reply to Makelaly)
       Post #: 5921
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/15/2012 7:06 AM
Ernie Misner
Score: 130
Status: offline
armody, who makes that red and white yak? It looks very nice!
Thanks, Ernie
Hide Signatures
       Post #: 5922
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/15/2012 12:59 PM
sandyjain
Score: 100
Status: offline
quote:
ORIGINAL: 757jonp
That is correct. The lubrication and scavenging qualities of Dino (mineral) oil are better - provided used in 1:32 or 3% mix NOT less.
After the engine is run thru few gallons of this oil and mix, one could shift to synthetic and use it in lower ratio 1:40 or 1:50.
But if the field you fly from is dusty (like in India for us) or hot - use dino oil @ 3% - your engine will be happiest....
Cheers....
Sandy Jain
Hide Signatures
       Post #: 5923
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/15/2012 2:04 PM
acdii
Score: 155
Status: offline
Why skimp on the oil?  Oil good, dry bad.
Hide Signatures
(in reply to sandyjain)
       Post #: 5924
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/15/2012 5:51 PM
Lifer
Score: 148
Status: offline
Are synthetic oils a step back in quality and features?
Hide Signatures
(in reply to acdii)
       Post #: 5925
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
