RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Page: <<   < prev  239 240 [241] 242 243 244 245 246 247 248   next >   >>
Login
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/30/2012 1:41 AM
acdii
Score: 155
Last Login: 5/20/2013
Status: offline
I spun up a 15x7x3 MA on my DLE, never flew it, but it did spin up and felt pretty strong. Knocked the RPM down quite a bit though.  Half tempted to use it on my Mustang, and set the Stang up as an A model.  Cooling would be the trick.
_____________________________
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
(in reply to Lifer)
       Post #: 6001
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/30/2012 1:48 AM
w8ye
Score: 318
Last Login: 5/21/2013
Status: online
That prop may work fine on the Mustang up in the air as the prop will unload well as the speed builds up?
You will just have try it and see?
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to acdii)
       Post #: 6002
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/30/2012 5:07 AM
tail heavy
Score: 105
Status: offline
I fly my H-9 60 size P-47 with a DLE-20 and a MA 15X7X3. Great combo. High speed passes are good but I am afraid to push the airframe too much as I assembled it with CA hinges.
"No mans life, liberty, or property are safe while the Congress is in session." - Mark Twain
Hide Signatures
(in reply to w8ye)
       Post #: 6003
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/30/2012 5:35 AM
Leroy Gardner
Score: 116
Last Login: 5/1/2013
From: Coeurd'''''''''''''''''''''''''''''''' ALENE,
Status: offline
quote:
ORIGINAL: Lifer
A DLE 20 will turn the MA 16x8x3 and the 15x7x3 quite well. Not the most efficient props, but they will do the job.
I don't know what the 8x3 pitch is all about and it's still 16". I have raised the engine 1" to gain some ground clearence ( it's being bashed ) and wing is also raised 3/4" for performance reasons. I need to figure the gear length so prop length is important at this time.
Did I mention it's a Tiger 60.
Leroy Tiger Club # 53, TF 1/5th P-51 mustang
Eagle 2'' bashed Tiger 60
Hide Signatures
(in reply to Lifer)
       Post #: 6004
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/30/2012 5:44 AM
rcguy59
Score: 129
Status: offline
The last digit is the number of blades (3).
Jet Central Superbee & Rabbit
12Z Fasst for everything I fly
Hide Signatures
(in reply to Leroy Gardner)
       Post #: 6005
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/30/2012 6:33 AM
armody
Score: 114
Status: offline
I have a question about DLE20, I've run my DLE20 two times on the ground and I ran probably one tank through it. It's installed on my Yak 54 120 big round cowl. I haven't done maiden on it, Sunday is the plan so far, it may change who knows, but the question is. Do I have to fly it without a cowl or with the cowl, weather is nice in 60's may drop or shoot up don't know.
Mody
It''s great2 keep flying invariably. Hitec Aurora9 2.4 GHz, Yak 54-120 /XYZ20, Kadet II, U-Sport Kits, MXS-R RCG20 (AMA Mem)
Hide Signatures
(in reply to rcguy59)
       Post #: 6006
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/30/2012 7:02 AM
rcguy59
Score: 129
Status: offline
Fly it with the cowling on. As long as the exit hole for the cooling air is adequate, you'll be fine. Once the cowling is on, run it on the ground to double-check the tune. Sometimes the tune will change with the cowling on vs. off.
Hide Signatures
(in reply to armody)
       Post #: 6007
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/30/2012 8:12 AM
sandyjain
Score: 100
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: armody
Mody
I would maiden, fly 2-3 flights without the cowl.... why ?:
Shows how the engine is behaving without the restricted airflow.
After putting on the cowl the above is the benchmark for engine behavior
Lose bolts and condition of muffler, firewall due to vibration are visible better.
Easier to access the needles for fine tuning
Cheers....
Sandy Jain
Hide Signatures
       Post #: 6008
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/30/2012 2:24 PM  1 votes
ahicks
Score: 669
Status: offline
quote:
ORIGINAL: sandyjain
I generally run with mine on, but Sandy has some really valid points for going without. Your call....
Hide Signatures
(in reply to sandyjain)
       Post #: 6009
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/30/2012 2:29 PM
Lifer
Score: 148
Status: offline
Test flights usually set the trims, verify the balance, etc. Without the cowl, will it adversely affect the outcome? I have a few planes that the cowl is heavy enough to affect the balance point.
Hide Signatures
(in reply to ahicks)
       Post #: 6010
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/30/2012 2:58 PM
hairy46
Score: 183
Status: offline
I always pin my hinges. Even the ca hinge
Hide Signatures
(in reply to tail heavy)
       Post #: 6011
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/30/2012 2:59 PM  1 votes
ahicks
Score: 669
Status: offline
Generally the manf. suggested CG is really conservative - safe. I wouldn't be too shy of flying without the cowl from that perspective? You could always check it without. If it's close, I'd run it....
If this were just my second or third plane though, I might be tempted to have somebody more familiar with it test fly it for me to at least get the maiden out of the way?
Hide Signatures
(in reply to Lifer)
       Post #: 6012
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/1/2012 1:14 AM
armody
Score: 114
Status: offline
Everybody has valid points in accordance with their perspective and experiences. I truly appreciate that. I'm gonna fly the plane, since due to a lots of things I could not have a maiden on it. The club I wanna join, I'd fly there as a guest so far this Sunday is confirmed don't if it's changed yet. Needles setting are OK, but not perfect or excellent as to speak, but I'm gonna fly it without the cowl which barely has any weight on it. Once I'm comfortable with the plane, all trimmed out, and pretty much crank up and fly, I'd put the cowl on since it has DLE20 on-board
Open to more inputs
Mody
Hide Signatures
       Post #: 6013
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/1/2012 1:47 AM
armody
Score: 114
Status: offline
Guys
One more opinion, suggestion, advice, input
I have asked this question in my other thread but I'm asking it here. What do y'all say about the Combo of DLE20 with Seagull Model's Sea Fury.
http://www.horizonhobby.com/products/sea-fury-91-120-arf-SEA3565
Mody
Hide Signatures
       Post #: 6014
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/1/2012 7:50 AM
Ernie Misner
Score: 130
Status: offline
No weight specs given there. Maybe go to the Seagull site directly for more. There is a review there if you click on Reviews where they guy put a FG30 Saito (Ithink) on it.
Hide Signatures
       Post #: 6015
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/1/2012 12:46 PM  1 votes
ahicks
Score: 669
Status: offline
My take, it's on the heavy side (typical Seagull), but should work OK as long as you aren't expecting it to fly like a trainer? I agree with the skill level they've assigned to it....
(From the assembly manual)
Specifications:
Wingspan66 in 167.5cm.
Wing area842 sq.in- 54.3 sq.dm.
Approximate flying weight9.95- 11 lbs-4.5kg- 5 kg.
Length59 in- 150cm.
Recommended engine size-.91 - 1.20 cu.in- 2-stroke.
-.91- 1.20 cu.in 4-stroke.
Recommended R/C 6 channels with 9 servos.
Flying skill level - Advanced/Intermediate.
Hide Signatures
(in reply to Ernie Misner)
       Post #: 6016
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/1/2012 8:07 PM
Ernie Misner
Score: 130
Status: offline
Thanks Al, those specs look good actually for 20cc engine. 20cc's is 1.22 cubic inches, so is right exactly at the top end of engine size requirements. Sure, it's heavier than a 3D plane but would give realistic wing loading for a war bird I think. Go for it and enjoy.
Hide Signatures
       Post #: 6017
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/6/2012 12:53 AM
Leroy Gardner
Score: 116
Status: offline
In the case of a DLE20 with a 16 X 8 prop, what is the end result of cutting 1/2" off ends of prop ?.
Hide Signatures
       Post #: 6018
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/6/2012 12:57 AM
rcguy59
Score: 129
Status: offline
A few hundred rpm at most.
Hide Signatures
       Post #: 6019
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/6/2012 2:06 AM  1 votes
ahicks
Score: 669
Status: offline
According to my math, that's going to take it down to a 15" prop, likely putting your rpms into the danger zone?
Are you considering doing this looking for ground clearance? No interest in a 3 bladed prop?
Hide Signatures
       Post #: 6020
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/6/2012 3:51 AM
microdon2
Score: 110
Last Login: 5/14/2013
Status: offline
Or use a 15x10.
Hide Signatures
       Post #: 6021
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/6/2012 3:55 AM
Leroy Gardner
Score: 116
Status: offline
quote:
ORIGINAL: ahicks
According to my math, that's going to take it down to a 15'' prop, likely putting your rpms into the danger zone?
Clearance yes, while I did'nt want to go with a 3 but may have to in order to keep the engine loaded to the right RPM. I have seen where some guy's have cut the tips off there props, thought I'd ask.
Hide Signatures
       Post #: 6022
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/6/2012 5:24 AM
Ernie Misner
Score: 130
Status: offline
Have you considered 3 1/2" wheels? Real light, like the Dave Brown type.
Hide Signatures
       Post #: 6023
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/6/2012 5:40 AM
microdon2
Score: 110
Status: offline
On some planes I put a 1/4" wooden plate between the landing gear and the fuse, for that much added clearance.
Hide Signatures
       Post #: 6024
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/7/2012 12:16 AM
Leroy Gardner
Score: 116
Status: offline
Turf tires are out, adding a block under the gear does'nt fair well, the engine has'nt been ran yet so I suppose testing props after break in is in order. I figured some of you have delt with this issue and I was looking for a short cut. There is alot of info on this engine so I'll go back and read more before I do the break in. Thanks all.
Hide Signatures
(in reply to microdon2)
       Post #: 6025
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
