RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Page: <<   < prev  243 244 [245] 246 247 248 249 250 251 252   next >   >>
Login
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/24/2012 9:21 PM
rcguy59
Score: 129
Last Login: 5/19/2013
Status: offline
Use a Hayes tank, Ernie. Under 6 bucks complete at our LHS.
_____________________________
Jet Central Superbee & Rabbit
12Z Fasst for everything I fly
Hide Signatures
(in reply to Ernie Misner)
       Post #: 6101
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/24/2012 10:56 PM
vertical grimmace
Score: 149
Status: offline
quote:
ORIGINAL: Ernie Misner
I need bottles as small as 8 oz. though and don't think? Fiji's come that small.
Fortitude makes an 8oz ready to go. Although, I found 8oz to not give me quite as much flight time as I wanted with my Focke Wulfe and replaced it with the next size a 16 oz. Probably way more than I need now.
< Message edited by vertical grimmace -- 12/25/2012 6:46 AM >
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
       Post #: 6102
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/24/2012 11:43 PM
Ernie Misner
Score: 130
Last Login: 5/17/2013
Status: offline
>>> Use a Hayes tank, Ernie. Under 6 bucks complete at our LHS. >>>
Now I like that idea Mike, thanks. The Hayes tank stopper is good for glow or gas apparently? What about the clunk line that comes with the Hayes tank? Replace it with Viton type gas line? Will the gas type fuel line seal adequately on the small glow sized barb they provide for the clunk line????
Thanks and Merry Chrismas 2012 to all -
Ernie Misner
Hide Signatures
(in reply to vertical grimmace)
       Post #: 6103
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/24/2012 11:49 PM
757sean
Score: 100
Last Login: 1/12/2013
Status: offline
Dubro 16oz tank, solder on barbs, sta flex fuel line from K&S, viton on the cluck line for flexibility.. we don't do fancy here, just dependable. And I use Wal-mart oil....
That'll get em started....
Hide Signatures
       Post #: 6104
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 12:32 AM
rcguy59
Score: 129
Status: offline
Replace the neoprene line that comes with the tank with small tygon or viton, whichever you like. The rest of the tank tolerates gas just fine, including the o-ring on the stopper. The Hayes tanks have served me well with glow, gas and kerosene.
Hide Signatures
       Post #: 6105
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 1:40 AM  1 votes
ahicks
Score: 669
Status: offline
quote:
ORIGINAL: 757sean
I got tired of carting all that extra fuel around, but the rest of your setup, including your oil (if that's where I was when I needed some last), can be found in any of my gassers... for the same reason!
Have a Merry Christmas guys!
-Al
Hide Signatures
(in reply to 757sean)
       Post #: 6106
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 2:09 AM
757jonp
Score: 110
Status: offline
You do know...the tank doesn't have to be filled? Actually it's strapped under the wing on the CG of a Mojo right there in plain sight.. Very handy to come down on a low pass and see how much fuel is left. I'm in the process of mounting an identical tank on the other side for smoke. I like flying for 30 minutes or so.
I recently sold the airframe another DLE 20 was used on. Debating whether to buy another airframe or sell it.
Hide Signatures
(in reply to ahicks)
       Post #: 6107
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 2:30 AM
armody
Score: 114
Status: offline
quote:
ORIGINAL: rcguy59
Hayes tank have pretty cheap price as even compared to Dubro, wow
16 oz is $3.69 can't beat it, don't know bout shipping thought
http://www.hobbylinc.com/htm/hay/hay146.htm
It''s great2 keep flying invariably. Hitec Aurora9 2.4 GHz, Yak 54-120 /XYZ20, Kadet II, U-Sport Kits, MXS-R RCG20 (AMA Mem)
Hide Signatures
(in reply to rcguy59)
       Post #: 6108
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 2:34 AM
armody
Score: 114
Status: offline
BTW,
One question I'd like to ask. What line do you use inside the fuel tank? I was using Tygon and my LHS guy told me use some black line tubing for the fuel tank's inside since fuel would ultimately get the fuel line brittle after a while. I don't know what that black tubing line is called. Any idea what y'all use?
Merry Christmas to y'all and happy holidays
Mody
Hide Signatures
(in reply to armody)
       Post #: 6109
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 3:07 AM
rcguy59
Score: 129
Status: offline
Black tubing is usually neoprene, but you can't always count on it. Neoprene resists gas for only a short period of time compared to tygon. I've never used viton, as I've always been satisfied with tygon. Around here, tygon is incredibly easy to find, which is more than can be said for viton. Avoid using any tubing that came with a kit / ARF. Fuel line is one more thing on the long list of things the Chinese can't be fully trusted to have figured out yet. Stick with the known-quantities. Besides, tygon is cheap and has an excellent track-record. Why screw around? It's very rare that I have a problem related to a fuel tank, but when I do, it invariably drives me nuts because tank issues are usually mistaken for other problems. (Other than leaks, of course) If all else fails, find the guy at your field that never seems to have problems (he's the guy that flies the most) and find out what he's using. Copy his set-up until you gain enough experience to think you know better. After a few choice screw-ups, you WILL learn.
Hide Signatures
       Post #: 6110
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 3:13 AM
microdon2
Score: 110
Last Login: 5/14/2013
Status: offline
rcguy -
Doesn't Tygon get brittle after a while? (two seasons?) I thought that was the advantage of neoprene. Do you change your fuel lines every couple of years as part of maintenance?
Hide Signatures
       Post #: 6111
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 3:19 AM
757jonp
Score: 110
Status: offline
Viton is the way to go inside the tank at least. Much more flexible than similar sized Tygon. Outside the tank I like to use something clear to view whats going on. The clear tubing from K&S works good. Yes it gets stiff, but I haven't seen that as a serious problem. I jsut removed some that was in use for about 2 years, just sold the airframe. Fuel lines were fine.
Hide Signatures
(in reply to microdon2)
       Post #: 6112
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 3:22 AM
armody
Score: 114
Status: offline
rcguy59,
Thanks the black tubing is neoprene and the guy at my LHS who happens to be the president of one of the local club here, he told me to use neoprene since it does not get brittle and your statement seems to contradict him which I'm sure you are telling cos of your experiences and I respect that. I'm just a NOOB here when it comes to gas and I yet to fly my plane but Thank GOD I've got a plane with DLE20 on it. Now your statement makes me wonder to replace the neoprene with tygon and throw away the neoprene. So the life span of tygon is better than neoprene?
As far as my club is concerned a lot of members have been thinning out for couple of years, I don't know why and few people I come across see them flying. Gas fliers are mostly evening fliers since one of them has stopped coming to the field or have found out another club, the other one has not been shown up lately and mostly guys fly are glow guys. So my club ain't much helpful when it comes to Gassers, that's why I try to get more and more data over here
Mody
Hide Signatures
       Post #: 6113
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 3:24 AM
757jonp
Score: 110
Status: offline
What he's calling neoprene is probably viton.
Hide Signatures
       Post #: 6114
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 3:34 AM
microdon2
Score: 110
Status: offline
Armody - Have you looked around for another club nearby that has more of a gasser crowd? I belong to four clubs, and each has it's own mix of planes and characters.
Hide Signatures
(in reply to 757jonp)
       Post #: 6115
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 3:47 AM
rcguy59
Score: 129
Status: offline
I assembled the tank in my GS P-47 (DLE55) over 3 years ago. It's never been opened since and the clunk line is still as flexible as it should be. And I DON'T drain the tank at the end of the day. It gets flown year-round. I have seen tygon get very stiff, though not actually brittle. This was tubing that was outside of the tank, though. Never seen a clunk line stiffen, but it could happen, I suppose. I don't claim to be any kind of expert, I'm simply relating my experiences. You have my sympathy, however, as when I started flying gas, our field was crawling with knowledgeable gas-flyers and still is. Jody even took the time to give me my first lesson at the field on tuning my new DLE55 after he and Tom brought it to me at the field the week before. Guess you could say I couldn't have gotten off to a better start. Prior to that, I used what seemed like miles of tygon in my turbine-powered stuff and never had problems with it there, either. I do replace the tygon and festo fuel lines on my jets once a year, just because jets make such a God-awful mess when something goes badly wrong. I can crash several gassers for what one jet crash would cost.
Hide Signatures
       Post #: 6116
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 4:11 AM
microdon2
Score: 110
Status: offline
rcguy - thanks for the info. Good to know Tygon can last a few seasons without getting brittle. I'm nowhere near owning a jet (above my current pay grade!) but I do love watching them. They have a few at my Brooklyn club at Floyd Bennett Field. Amazing machines - they go vertical and never slow down! What power. And at upwards of $20k a pop, I guess it's worth a little extra maintenance.
Hide Signatures
       Post #: 6117
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 4:56 AM
rcguy59
Score: 129
Status: offline
Mine aren't that expensive, but none are what I'd call cheap. Lately though, I've been having a lot more fun with big gas warbirds. Less hassle and a lot less "pucker factor" than a jet. When you buy tygon, make sure it says "tygon" on the tubing itself. I've run into knock-off tubing that's the same color and feel, but isn't genuine tygon. Maybe that's the source of some of the conflicting experiences guys have. I live across the street from a Stihl dealer and he carries the real stuff as does the LHS.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 6118
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 5:37 AM
Ernie Misner
Score: 130
Status: offline
Nice collection of warbirds there! There must be different qualities of Tygon like you said. Many have said it got stiff on them inside of the tank.
Hide Signatures
       Post #: 6119
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 6:35 AM
armody
Score: 114
Status: offline
rcguy good collection
What about this tygon? Is it good and right for Gasser?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD740&P=FR
Hide Signatures
       Post #: 6120
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 6:41 AM
rcguy59
Score: 129
Status: offline
That's what my LHS sells. Last time I bought DuBro tygon it was GENUINE tygon. Says so right on the tubing. Good stuff. Buy a roll and share a little with your buddies. I've found that when I have a whole roll, I don't hesitate to replace a piece that's questionable.
Hide Signatures
       Post #: 6121
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 7:03 AM
vertical grimmace
Score: 149
Status: offline
I use Tygon exclusively, inside and out of the tank. My problems with Tygon are how much of a pain it is to get my fuel dot off of my fill line. I sometimes use a short section of viton or neoprene here to make this easier. One of the tricks as mentioned is to leave a little gas in the tank. It keeps the tygon klunk line flexible.
Keep in mind not all planes are the same. Many warbirds have the tank buried in the fuselage and are a little bit more tricky to get to to service than a profile 3D type model that you can visually inspect easily. There is nothing worse than finding out about a tank problem by seeing fuel streaming out of the fuselage while filling!
Hide Signatures
       Post #: 6122
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 12:43 PM
RiverLarry
Score: 100
Status: offline
Armody      Go to  MC Master Carr !!!!!
thay have  Vinton   /   Tygon    @ .80 ft     1/8   brass  T   and you can get differnt wall thick  !!!!
 purty much  any type or sise  of  tubing you would ever need !!!
And    bolt cutters     (   For the lock !!!!  )              R/L
Hide Signatures
       Post #: 6123
RE: DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 10:19 PM
dirk.matherne@att.net
Score: 100
Status: offline
i have one on a stearman i like it alottttttt
Hide Signatures
(in reply to P-51B)
       Post #: 6124
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/25/2012 10:35 PM
Michel
Score: 123
Last Login: 5/18/2013
Status: offline
Hi
I work , in small engines , ( I,m no pro ) , and fix many . The best , which I use , inside the tank , is the fuel line from , " HONDA " weed eaters ( weed /trimmers ) , the 4 cycle one,s . I have some that are still beening used , thats " 6 years ago " . They are extremly flexble , and keep the flexability for years . Some of the other small egines are also good , Stihl , Husvarna , Echo , and so on . ( I am speaking about the inside gasline )
I tryed viton and found it to be too stiff , but , does last a long time . If you,ll use the Honda one,s ,................... you,ll never look back .
Michel
Hide Signatures
(in reply to RiverLarry)
       Post #: 6125
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
