RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Page: <<   < prev  245 246 [247] 248 249 250 251 252 253 254   next >   >>
Login
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/30/2012 8:17 PM
armody
Score: 114
Last Login: 5/21/2013
Status: offline
Guys,
Since Du-Bro's products are reliable and trusted. I'm gonna go ahead and use Tygon and these are the items I'm gonna use.
Mody
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
It''s great2 keep flying invariably. Hitec Aurora9 2.4 GHz, Yak 54-120 /XYZ20, Kadet II, U-Sport Kits, MXS-R RCG20 (AMA Mem)
Hide Signatures
(in reply to Ernie Misner)
       Post #: 6151
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/30/2012 8:24 PM
tailskid
Score: 199
Status: offline
I've ONLY used Du-Bro Tygon and never had any problems.....good choice IMHO.
# 93 in Club Saito
Carl Goldberg Ultimate Brotherhood # 12
Hide Signatures
(in reply to armody)
       Post #: 6152
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/30/2012 8:41 PM
armody
Score: 114
Status: offline
Thanks tailskid,
I've been using Du-Bro's product, and they are pretty reliable. When I first went to my hobby shop in order to get a Du-Bro's fuel tank, they didn't have gas stopper. I was told that for the inside of tank, I should be using black neoprene not tygon as it may get brittle, but a lot of people advised me here to use Tygon so I'm gonna go for the Tygon, and Dubro's product are pretty cheap to be used.
Mody
Hide Signatures
(in reply to tailskid)
       Post #: 6153
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/30/2012 8:50 PM
rcguy59
Score: 129
Status: offline
DuBro is still among the best for bang-for-the-buck. You'll be just fine, Armody.
Jet Central Superbee & Rabbit
12Z Fasst for everything I fly
Hide Signatures
       Post #: 6154
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/30/2012 8:58 PM
armody
Score: 114
Status: offline
quote:
ORIGINAL: rcguy59
It sure is a bang for the buck Since the day of Christmas we had wind gusts like 40Mph now it's been mellowed down. Temp is lower 30's here at night. In the day it's higher 40's which is pretty good and cold for here where I live.
Next week hopefully I'd try to have my maiden, if weather allows it especially wind
Mody
Hide Signatures
(in reply to rcguy59)
       Post #: 6155
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/30/2012 9:10 PM
Lifer
Score: 148
Status: offline
I've used Tygon and had no failures. The tubing eventually hardens and needs replaced. Make sure your tank is easy to remove and leave enough tubing attached so that you can pull the tank out enough to get to the stopper screw.
I'm trying Viton this upcoming season and perhaps I won't have to change the fuel pickup line quite so often/ever.
Hide Signatures
       Post #: 6156
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/30/2012 9:57 PM
vertical grimmace
Score: 149
Status: offline
If you leave some fuel in your tank, your tygon will remain pliable.
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
(in reply to Lifer)
       Post #: 6157
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/30/2012 10:06 PM
tailskid
Score: 199
Status: offline
My Tygon tubing finally harden up after 3-4 years - in my Fuel Can!
# 93 in Club Saito
Hide Signatures
(in reply to vertical grimmace)
       Post #: 6158
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/31/2012 1:00 AM
vertical grimmace
Score: 149
Status: offline
quote:
ORIGINAL: tailskid
Well never mind then. I am just making it up to mislead my fellow modelers.
Hide Signatures
       Post #: 6159
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/31/2012 1:35 AM
Ernie Misner
Score: 130
Last Login: 5/20/2013
Status: offline
So you're going with a Dubro tank too, right? One clunk or two? What about filtration?
My 20cc profile ProX260 is going to have a Hayes 8oz. tank with Viton or Tygothane Polyurethane for the clunk line since I have some coming from McMaster Carr anyway, single clunk with a T for filling and a filter before the carb.
Hide Signatures
       Post #: 6160
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/1/2013 11:54 AM
Lifer
Score: 148
Status: offline
Quick question about engine timing: What is the net result if you set up the engine with LESS advance than the 28-32 degreees called for? Would it necessarily harm the engine? A little less performance but cooler running or easier starting qualities? Thanks in advance for any knowledgable responses!
Hide Signatures
       Post #: 6161
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/3/2013 9:22 PM
armody
Score: 114
Status: offline
Hi all,
Can anyone tell me the tank setup? Two outlets coming out of tank one is for vent and other goes to the carb. The one for vent is bent upwards and I'm going to use it for fueling the tank as well, once tank is full, I'd insert a fuel stopper to it. Is this setup OK?
Mody
Hide Signatures
(in reply to Lifer)
       Post #: 6162
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/3/2013 9:37 PM
phakur
Score: 100
Status: offline
Armody-
Don't think that will work as tank will need a vent since fuel is pumped and you will end up creating a vacuum. Suggest a "T" in the line to the carb with one leg of the "T" being your fill line. Some people put a loop in the vent line to avoid any issues and then let it hang out the bottom of the plane. Others just let the vent line hang out of the bottom of the plane.
Fill tank until gas comes out of the open vent line then plug the fill line. That leaves the vent line always open.
Larry
Hide Signatures
       Post #: 6163
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/3/2013 10:00 PM
sparky4lawndart
Score: 100
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: phakur
Armody-
Don't think that will work as tank will need a vent since fuel is pumped and you will end up creating a vacuum. Suggest a ''T'' in the line to the carb with one leg of the ''T'' being your fill line. Some people put a loop in the vent line to avoid any issues and then let it hang out the bottom of the plane. Others just let the vent line hang out of the bottom of the plane.
Larry
+1... Phakur is right... you're gas tank should have three ports (1 to carb, 1 to fill, and one to vent the tank). If you only have two connectors on your tank then you'll have to fill through the carb line with a t-connector or a fuel filler do-hickey like the one from Dubro (it actually closes the lead to the carb during refueling) and the vent line (is it clear that the vent line is important? lol)
anyway... it's a great motor... runs like a champ, easy to maintain, and pretty resilient...
just let me have it... It''ll be a lawndart in no time...
Hide Signatures
(in reply to phakur)
       Post #: 6164
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/3/2013 10:51 PM
armody
Score: 114
Status: offline
phakur thanks,
sparky, I do have T-connector, so that has to be connected to the line which goes to the carb and once the tank is filled up, I can plug the stopper to that line which goes to the carb and connected with T-connector. 2nd line which is for vent, I would take it curl it around on the top of the tank and let it hang downwards, open right? Which would push out the gas once it's full?
Have I understood it correctly?
Mody
Hide Signatures
(in reply to sparky4lawndart)
       Post #: 6165
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/4/2013 4:34 AM
Ernie Misner
Score: 130
Status: offline
If you use the T setup you might want to run a filter right before the carb. The T fueling method renders a clunk filter useless but that's okay with the carb filter. Another great option is to run 2 clunks in the tank. One is just for fueling / unfueling.
Hide Signatures
       Post #: 6166
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/4/2013 6:27 AM
microdon2
Score: 110
Last Login: 5/14/2013
Status: offline
Ernie - I think I just realized why you're saying that the T-method renders the clunk filter useless - because any particles in the fuel will get trapped on the carb-side of the clunk while filling the tank, and so will get pulled back up to the carb when fuel direction reverses, during normal engine running. Is that right? I had not thought of that before. So it seems I need to install some in-line filters on my planes, between the T and the carb.
Mike
Hide Signatures
       Post #: 6167
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/4/2013 6:37 AM
Ernie Misner
Score: 130
Status: offline
That's it microdon2, you got it. Yes, with that T setup it's way more important to have a filter before the carb. That's one advantage of a two clunk setup which is very popular. No, the two clunk lines don't get tangled or twisted.
Often you'll see guys fueling glow planes or whatever at the field and sometimes they'll have an in lilne filter but then fill the tank from the wrong side of that filter too.
Hide Signatures
(in reply to microdon2)
       Post #: 6168
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/4/2013 6:53 AM
rcguy59
Score: 129
Status: offline
That's why the hand-crank pump on my Jersey Fueler pumps the fuel through a filter on it's way TO the fill-line in the airplane. A CrapTrap right before the carb seals the deal.
Hide Signatures
       Post #: 6169
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/4/2013 11:11 AM
Richard D Bahmann aka/Wrongway
Score: 110
Last Login: 4/1/2013
Status: offline
I have a ceramic flilter clunk ($4) in my fuel tanks and in my fuel fillers... Never got crap from a t setup from 20cc to 150cc. Forgot to say never...
I Am WrongWayRC
Hide Signatures
       Post #: 6170
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/4/2013 2:20 PM
acdii
Score: 155
Status: offline
I prefer the 3 line setup since it eliminates the possibility of getting an air leak between the tank and carb, also eliminates the need for extra filters.  Did that to all my planes, glow and gas.  Since I use one of those metal fuel plugs, it also adds a touch of scale to my warbird.
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
       Post #: 6171
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/4/2013 2:24 PM
raptureboy
Score: 178
Status: offline
Never say never I also use a 3 line tank for the same reasons mentioned here, neither right or wrong just the way I like to do it. But the vent MUST remain open or your tank will collapse and your engine will quit at the most inopportune moment.
quote:
ORIGINAL: Richard D Bahmann aka/Wrongway
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
       Post #: 6172
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/4/2013 2:27 PM  1 votes
ahicks
Score: 669
Status: offline
I filter my fuel as it exits the hand pump. After that I trust the crap trap built into the carb? This in an attemp to minimize trouble/leaks on board.... and the carb's crap trap not that hard to inspect/service on occasion!
Mody, you're understanding correctly!
Hide Signatures
       Post #: 6173
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/4/2013 2:44 PM
Score: 110
Status: offline
Totally personal preference... In previous posts the feel was that 3 line was the only way..Let my post reflect that.
Not true..
If you like 3 line, go for it.
If you like two line, go for it.
Both work fine and I mentioned that I use two line on my gassers with great record as an example that that a 3 line is not a must...
Ernie, here is one for ya. I had dirt work its way back from the vent line on my 20cc profile because it was mounted under the wing and the prop blast allowed it to breath in dust that worked its way back to the fuel tank... Deadsticks later I cleaned the screen in the carb and then it happened again.. on the third time I put a filter on the end of the vent line and it stopped. (each time dismantling and cleaning the Hayes fuel tank). But an inline filter or filter clunk from the fuel pick up to the carb would have never allowed it.
Depending on the brand an inline filter may have a gasket that can leak... A ceramic clunk or walbro filtered clunk cannot leak...
The ceramic clunk that I use sucks every last drop from the tank.. It is also heaver than a regular clunk so if you are worried about lines that are stiff.. it will do the job longer... I lost track on my flight time once on my 50cc plane and when I had landed the plane and it had sucked the tank dry and the fuel line showed the fuel bubble half way up to the carb...
Gonna try a 17x7 on my DLE 20 this weekend.. Getting 8810 on the 17x6...anyone interested in results I will report back..
I Am WrongWayRC
Hide Signatures
(in reply to raptureboy)
       Post #: 6174
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/4/2013 3:33 PM
757jonp
Score: 110
Status: offline
I've got a situation with a DLE20/Mojo 65 combo that's got me a little puzzled, lets chew on this for a while. When I installed this engine on this airframe I reused the 16oz fuel tank previously used with a glow setup. Only change (other than setup for gas) was to move the tank back under the wing near the CG. The thinking was why not, I've got a good fuel pump with the engine, take advantage of it and get your fuel tank placed where regardless of the amount of fuel remaining, the CG will remain where it was to start with. For the most part this has worked well, e x c e p t when the fuel tank is full. With a full load of fuel, the engine will run normally e x c e p t when inverted. Flipping this turkey on it's back with a full tank will result in an immediate stumble from the engine and a possible deadstick unless the revs are kept high, where it will continue to run, but not well. Hard to tell if it's gone lean or rich.
Here's the kicker though... when the fuel level lowers to about 3/4, it runs fine in all attitudes. Hmmmmm? Now, there's no reason to have a 16oz tank on this plane,(other than that's what I had at the time of conversion) so I've run it for quite some time with a partial tank and it'll run without skipping a beat. The only thing a little unusual about my setup is that the tank is mounted about 16 inches back and 3 inches below the crank centerline.
The only thing I can think of that might cause a problem is that when inverted the tank would be 3 inches higher than the centerline and the weight of the fuel may(?) overpower the fuel inlet to the carb pump, and cause the engine to go rich. But that doesn't really explain why it wouldn't happen all the time, not with just a full tank.
Any thoughts?
Hide Signatures
       Post #: 6175
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.078RCU1
