RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Page: <<   < prev  247 248 [249] 250 251 252 253 254 255 256   next >   >>
Login
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/12/2013 12:24 PM
lopflyers
Score: 140
Last Login: 5/20/2013
Status: offline
Sorry to change subjects, I have a question. I have already ran a gallon og gas w 32:1 in my new DLE 30. Now should I go synthetic? What is the ratio? How many ounces per gallon? Thx DLE gurus
_____________________________
Keep your wings level
Club Saito Member #693
Hide Signatures
(in reply to armody)
       Post #: 6201
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/12/2013 1:36 PM
RiverLarry
Score: 100
Status: offline
The little book that came with the DLE 30
does it not say  30 - 1    from  day 1   and then for life ?????
4 oz  =  32 - 1      works fine !!!!        cant be that hard !!!
    my $0.02
     R/L
Hide Signatures
(in reply to lopflyers)
       Post #: 6202
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/12/2013 2:07 PM
lopflyers
Score: 140
Status: offline
It also mentions 50:1 synthetic. That's why I asked. For me experience is more important than the manual.
50:1 would be 2.5 ounces/gal. Sounds too little to me. It's my first gasser��
Hide Signatures
(in reply to RiverLarry)
       Post #: 6203
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/12/2013 3:03 PM
Lifer
Score: 148
Last Login: 5/21/2013
Status: offline
Oil is cheap! I used dino oil at 32-1 for break-in and then 32-1 synthetic thereafter. No issues and engines last a long time.
Hide Signatures
       Post #: 6204
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/12/2013 5:31 PM
757jonp
Score: 110
Status: offline
Open up that engine and take a good long look at that $2.00 bearing on the rod end and tell me it doesn't want all the oil it can get! Consider also this engine runs at a higher RPM than the bigger ones do.
I recently broke the crank journal in one. Although the bearing showed no evidence of unusual wear, the journal did, and I was running 32:1 since the beginning. No complaint here, as I had been running the engine hard in excess of 10k RPM at times so I'm not terribly surprised something gave up.
Do yourself a favor. Run it at 32:1. The worse that can happen is you might have to buy some paper towels to clean up the mess. At least you'll keep the warranty intact.
Hide Signatures
(in reply to Lifer)
       Post #: 6205
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/12/2013 6:27 PM
lopflyers
Score: 140
Status: offline
Awesome thx, 32:1 synthetic it is
Hide Signatures
(in reply to 757jonp)
       Post #: 6206
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/12/2013 6:58 PM
rebranger
Score: 100
Last Login: 4/25/2013
Status: offline
quote:
ORIGINAL: armody
Ed,
The one I'm using it's Klotz and it's synthetic so I'd continue to use synthetic. I'm impressed with your collection, and for me it may take years to get the collection. I'm planning to get another plane Seagull's Sea Fury, which I'm still waiting on money. I had started a thread of picking out one engine out of two and which is gonna be your choice that was the thread, it was between DLE20 and Mintor22, I was planning to get Dewoitine D.520 I was told, it ain't gonna fly good, or it would be difficult since it does not have bigger wing area, so I switched on Sea Fury both by Seagull models.
I have mixed up two gallons of fuel with 8 oz of Klotz synthetic. Anyway, I had been advised to get another DLE20 since I wanted to try Mintor22, though I love DLE20. Anyway, after I'm gone through my two gallons of fuel, you want me to switch to Stihl Ultra synthetic and go from 32:1 to 40:1? People have advised me to continue to use 32:1, as I'm a newbie to gas, and including you everybody's advices/suggestions I take respectfully here but, it's kinda making me perplexed.
As far as that big pasture you've mentioned, I don't think anyone's gonna go for it, since most of the people are around 249, 1488, 2978, 1774 and so on. We've been given an offer by Sparks club as I mentioned in my PM, but I don't think people are gonna take it, since our club's charges were dirt cheap as other clubs around.
Mody
Klotz is about the best u can get. I just run Stihl 'cause that's what I run in all my saws. Cleaner burning is why most go to 50:1 with the good synthetics. I run the lil Stihl Ultra grey bottle, the regular, 4 oz , is in an orange bottle. Most of my engines are 2 - 5 yrs old plus. My biggest problem is gas goin "stale" & gumming up everything, so I use fresh gas everytime, only mix a gallon at a time, keeping it in good airtight bottle helps. Put a lil "Heet" in it to get the water, & a new gas stabilizer called Enzite (sp). Have tried Seafoam, Stabil, etc. they're alright, but still have problems if u let the gas sit, or age.
Speaking of the "Dewayne" as I call it, I have one with a Saito 120 on it. Flys like a dream!! It has done many landings (which is the toughest thing  on a Warbird, retracts, ugh)). It flys well, will do all scale maneuvers, no nasty habits (tip stall, etc). Just keep speed up on landing. I love the model,  it's kinda unique.
Best Regards
Ed
Hide Signatures
       Post #: 6207
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/12/2013 11:49 PM
acdii
Score: 155
Status: offline
Oil is cheap, why risk going to lower oil content, you are not gaining anything.  A synthetic oil isnt going to protect it better using less of it. Oil gives engines life, why take it away?
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
(in reply to rebranger)
       Post #: 6208
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/12/2013 11:56 PM
Ernie Misner
Score: 130
Status: offline
rebranger, what have you had go wrong with your reed valves?
armody, I like your gas can setup. So you got the hardware from Hangar 9 I see and I like the way it sits on top of the gas can. Is that thread on the gas can a common one? The Hangar 9 pump setup will work on a gas can from Home Depot or whatever?
Thanks, Ernie Misner
Hide Signatures
       Post #: 6209
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/13/2013 12:02 AM
rcguy59
Score: 129
Status: offline
Have you seen the fueler set-up ValleyView sells? I saw some on the shelf the last time I was over there. Nice rig, simple too. Not much to go wrong.
Jet Central Superbee & Rabbit
12Z Fasst for everything I fly
Hide Signatures
(in reply to Ernie Misner)
       Post #: 6210
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/13/2013 12:07 AM
Ernie Misner
Score: 130
Status: offline
Hey Mike, I'll take a look when we go to the Monroe hobby expo. You going? I like the clean way the Hangar 9 one does sit on the jug though.
Hide Signatures
(in reply to rcguy59)
       Post #: 6211
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/13/2013 12:35 AM
WindGap
Score: 105
Status: offline
For those of you who updated to the wt793 carb, how does it compare to the stock carb?
Hide Signatures
       Post #: 6212
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/13/2013 12:51 AM
rcguy59
Score: 129
Status: offline
I'm going Friday with Burel, Ernie.
Hide Signatures
       Post #: 6213
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/13/2013 4:32 AM
acdii
Score: 155
Status: offline
I have one of the hanger9 fuelers too, haven't used it yet, but will as soon as I can fly again
Hide Signatures
       Post #: 6214
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/13/2013 7:24 AM
armody
Score: 114
Status: offline
quote:
ORIGINAL: Ernie Misner
Thanks Ernie,
This gas setup when my wife got me first P51 Mustang from Hangar-9. I still have those accessories with me. I used that set up on my glow fuel now it's on gas. I have seen some custom made fuel cans with fuel pump, nozzle and whole nine yards for around $80 or may be more or less. I don't think I can spend that much money on it and it works fine for me.
rebranger, I think my gas can is air tight, I'd try to put some plastic under the lid to make it more airtight, I usually store my gas in room temp. Now a days it's sitting on my working table in the garage as cold front is hitting again. I do have Stabil which I would add it to the fuel for it not to go bad.
I read one thing, that people have been breaking in DLE20 or 30 with regular oil then switching to synthetic oil, I really didn't get it. I ran my DLE20, I won't say it's completely broken in, but I ran it with Klotz synthetic in the first place, and I'm using the same prop 17X6 Xoar beechwood which I'd use it for flying. This is what working for me.
Mody
It''s great2 keep flying invariably. Hitec Aurora9 2.4 GHz, Yak 54-120 /XYZ20, Kadet II, U-Sport Kits, MXS-R RCG20 (AMA Mem)
Hide Signatures
       Post #: 6215
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/13/2013 11:41 AM
G T
Score: 100
Status: offline
Hi guys
Just thought I would add a comment on the 20cc
I have a few DLE engines of larger sizes and decided to put the smaller 20 in an old H9 P47 I had sitting around as a go out and fun fly with out the set up time of larger warbirds.. This model was powered originally with a RCV 90 and was a dog
This motor has transformed this plane into a really nice flyer with heaps of reserve power.
Started flying it with a 16x8 prop and tried it today with a 15x7 3 blade and it pulls a better up line with NO stopping
I am very impressed !
Hide Signatures
       Post #: 6216
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/13/2013 1:38 PM  1 votes
ahicks
Score: 669
Status: offline
I hear that! I started with the 30cc planes, but more recently they've taken a back seat to the 20cc's I have. The 20's are just easier to handle from the moment I decide to go flying until the lights are turned out in the garage when everything's put away again? Definitely no performance loss. Fun factor is the same?
Looking forward to this new 10cc engine and if/how that engine (and other similar engines that are sure to follow) might further shape how/what I fly?
Mody - oil topics are always going to be controversial. From what one works best for break in to what one makes you're engine more powerful and last the longest. I'm only going to say that this 20 has a pretty vulnerable crank pin. Keeping the rpm's in check with a properly sized prop and running 32:1 mix are widely known to let that crank pin/engine live happily. I wouldn't stray from those 2 things much? Other than that, and using oil that's designed to be used in an air cooled engine, I don't think you can go far from what's right?
-Al
Hide Signatures
(in reply to G T)
       Post #: 6217
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/13/2013 2:06 PM
RiverLarry
Score: 100
Status: offline
 + 1 Ahicks  on the OIL and  R P M !!!
After all the post about OIL I would think by now that would of been  a givin !!!
there is a hi rpm RED LINE    and a oil content in the book    stick with that and
and there little DLE should be  Happy Happy
I do have a new  Tillitison carb     that came for a gas converson for a SAITO 150
going to give it a try today to see what happens
waiting for my little 10 cc from  H H   ( and yes 20 - 1 )   on the OIL
people are all ready beating that   20 - 1  too death   also      R/L
Hide Signatures
(in reply to ahicks)
       Post #: 6218
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/13/2013 4:54 PM
wesjon
Score: 100
Last Login: 4/3/2013
Status: offline
Hi all
Just thought I would keep you updated on my progress with my DLE 20. I was having lots of issues getting her to run reliably. Changed the carb for a new one today and no more issues! Started after a good few flips on choke and is idling brilliantly and holding good high rpm. Still a bit of hesitation on throttle up but just needs to be tuned out. I am very happy as the previous carb was giving me a severe headache! I couldnt believe how well it ran today, was over the moon!
I hate mysteries and would like to find out what was causing my problems. Things I did to the original carb:
  • I had to replace the fuel barb as the first one snapped...
  • opened to clean the filter
The low end needle had quite a bad bend in it too which leads me to believe that it may have been sucking air from here or possibly the fuel barb...I remember reading on a forum somewhere that after replacing the barb it never runs very well for some reason.
Wes
Hide Signatures
       Post #: 6219
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/13/2013 4:57 PM
coronabob
Score: 110
Status: offline
quote:
ORIGINAL: ahicks
-Al
The fun factor went up for me after I put a Bowman ring in one of my DLE 20s. It pulls fuel and starts in a few flips - it just does.
Hide Signatures
       Post #: 6220
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/13/2013 5:02 PM
RiverLarry
Score: 100
Status: offline
Hay good going   from across the POND !!!!!
did you take the HS  and LS jets  out all the way !!!!
and blow air through them !!!  just a thought        R/L
Hide Signatures
(in reply to wesjon)
       Post #: 6221
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/13/2013 5:09 PM
wesjon
Score: 100
Status: offline
Greetings R/L!
Indeed, a South African living in the UK!! Been here 10 years and still cannot get used to this weather! Today was beautiful but my hands eventually got too cold so I had to pack it in!!
Yep, cleaned out the needles too!
Cheers
Wes
Hide Signatures
       Post #: 6222
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/13/2013 6:19 PM
microdon2
Score: 110
Last Login: 5/14/2013
Status: offline
coronabob - good to hear - I've got Bowman rings for my DLE 20 and DLE 30 - haven't installed them yet - just about to. Good to hear that they help!.
wesjon - you may want to try a Raydiowarm. From Europe, about $75 US. Well worth the money - I could not fly in the cold without it.
Hide Signatures
       Post #: 6223
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/13/2013 7:41 PM
rebranger
Score: 100
Status: offline
They don't seal properly on the block. JUst lay block on flat sheet of glass with #200 - 300 GRIT AUTO BODY sand paper wrapped around it and sand down, check reeds for good sealling first. Sometimes they are a little bend &/or the block isn't square to let 'em lay completly flat or flush.  Doesn't happen often tho.. but have it on your check list if you run into a fuel draw problem, Sometimes the cases leak, but again not very often. Most of mine have run great right out of the box. But every once in a while, I get a bad one. Carbs are the biggest problem tho..LOL
Armody, Magnolia
They say don't run the synthetic oil to break in, I guess cause it's TOO slick & make the rings take longer to seat.
Next thing I'm gonna try (other than changing out the carbs) is a Bowman ring. From what I have been reading on here, that's the hot set up!
Best Regards
Ed
Hide Signatures
       Post #: 6224
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 1/14/2013 4:27 AM
armody
Score: 114
Status: offline
rebranger, ahicks and other guys,
I had no idea that I had to run a non-synthetic oil in the first place, never read it anywhere, not even on this threat, if it's there on this thread and I may have overlooked it so sorry about it. I was always told to run a synthetic oil and this is when I found the Klotz and I read that I gotta use 32:1 on it. One gallon 4 oz. I don't think I'm gonna make any change in carb, and in the ring, and I don't think I'd be able to change the ring and get Bowman ring what everybody's talking about. May be I can but I've not even yet flown the plane due to circumstances beyond my control, and I'd hopefully try to go out and fly that thing off of a retention pond which is dry.
I'd continue to run the way it is, as I really take care of my stuff, and I do not abuse it. I'd adhere to the instructions of it and I hope I won't run into any prob with DLE20.
Thanks guys for all your support and now a lot of guys are coming up with new questions which is interesting.
Mody
Hide Signatures
       Post #: 6225
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.219RCU1
