RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Page: <<   < prev  189 190 [191] 192 193 194 195 196 197 198   next >   >>
Login
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/31/2011 8:01 PM
SpinnerRow
Score: 152
Last Login: 5/25/2013
Status: offline
quote:
ORIGINAL: a1pcfixer
Hopefully you'll find a better combo of prop, lube mix ratio, flying style, so that your next one lasts longer.
Flying style won't change (WOT or Bust!) so I need to change something else.
_____________________________
"Hey!!! That tree was NOT there when I took off!!"
Hide Signatures
(in reply to a1pcfixer)
       Post #: 4751
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/31/2011 8:04 PM
SpinnerRow
Score: 152
Status: offline
Hide Signatures
       Post #: 4752
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/31/2011 8:08 PM
Joespeeder
Score: 105
Status: offline
Hey RBean,
MAS Prop emailed me a follow up today on our inquiry to the 16x8x3 redesign question.
Here is the email copy and pasted to this post.
"Joe,
Ok, it sounds to me like the 16x8 3-blade with the "4020T" is a prior production model, and the 41 versus 40 refers to diameter in centimeters. We felt for safety sake the high torque gas engines needed a beefed up transition area. We have to balance safety and performance, as you can understand. That said, the 16x8 3-blade generally does well with the DLE20. An alternative is a 16x10.
Another change with the new 16x8x3 was strictly for pitch measurement. Because of our design, the back of the prop blade doesn't sit flat a prop gauge and people thought we were underpitched because of is. We had a slight re-design so that the pitch could be accurately read.
I hope this gives you the info you need. "
I thanked Teresa for her followup and insight. However, your test results suggest a definite change in the way the 16x8x3 performs on the DLE-20.
I think I still have an older MAS 16x8x3. I will have to dig it out and protect it till needed.
A few options in the 16 inch 3 blade variety can be found here.
http://www.valleyviewrc.com/estore/xoar-three-blade-propeller-16x8.html
http://www.v-eastonline.com/categories/Graupner-Prop-Shop/Super-Nylon-three-blade-props/
http://magnumrc.com/3-blade-wwii-warbird-propeller-16x8-p-245.html
http://www.menz-prop.de/english.htm
Joe
Hide Signatures
(in reply to jedijody)
       Post #: 4753
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/31/2011 8:56 PM
microdon2
Score: 110
Last Login: 5/24/2013
Status: offline
SpinnerRow - do you really run WOT? I rarely do - usually run about 2/3, then might go WOT for a speed pass, but then back off. Which is another reason I was surprised mine broke, like yours did. Maybe I was running too lean, or maybe this is just a defective part, and you and I were some of the unlucky ones. Either way, TH replaced the engine and I haven't had that problem again.
Hide Signatures
(in reply to Joespeeder)
       Post #: 4754
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/31/2011 9:17 PM
SpinnerRow
Score: 152
Status: offline
quote:
ORIGINAL: microdon2
It's a P-51 - I run WOT and might drop it "some" to land.
I also have a DLE 20 in a GP PT-17 with a Vess 17x6. It putts around on way less than half throttle for 20 minutes. An occasional WOT on an upline to do a roll, split S or hammerhead. I'm too afraid the plane would come apart on a WOT flat and level run.
Hide Signatures
(in reply to microdon2)
       Post #: 4755
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/1/2011 12:40 AM
RBean
Score: 115
Status: offline
Joespeeder,
Thanks for forwarding the e-mail re M/A prop. Does not really answer my concerns. Next good weather I'll put the new 16-8-3 in a DLE 20 which is broken in and see what the result is in the air. I'll report here. All the other props you listed are good but expensive compaired to Master Airscrew.
Hide Signatures
(in reply to SpinnerRow)
       Post #: 4756
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/6/2011 12:04 PM
gazzazh
Score: 135
Last Login: 7/7/2012
Status: offline
Hi All,
I am having a lot of issues with my 30cc dle engine and EMI...
I am using an AR7000 RX and Dx7 .. I am getting major interference.. my servos are moving on their own..
how many ferret rings do i need.. or what should i look for to get this problem solved.
Cheers and thanks a million
Happy Landings..
eat, live, breath RC
Hide Signatures
(in reply to RBean)
       Post #: 4757
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/6/2011 3:22 PM
karolh
Score: 310
Status: offline
If you are running the engine with the stock spark plug replace it with an NGK CM-6 plug, as the stock plugs are known to sometimes give interference and or running problems. Also ensure that the spark plug cap is pushed all the way down on the plug and over the hex section. HTH.
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
(in reply to gazzazh)
       Post #: 4758
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/6/2011 3:38 PM
gazzazh
Score: 135
Status: offline
Thanks.. will change plug, and will also wrap ignition in tin foil, shiny side facing in as well as place some ferret rings.. will keep u updated ,,cheers
Hide Signatures
(in reply to karolh)
       Post #: 4759
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/6/2011 3:54 PM
karolh
Score: 310
Status: offline
Try my suggestions first before using the foil or f/rings.
Karol
Hide Signatures
       Post #: 4760
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/6/2011 4:30 PM
TimBle
Score: 162
Status: offline
I tried a APC 168 on my DLE20 in the Spot On today.
WINNER  excellent vertical performance for pattern
Much better than the Xoar 16x8.
Still waiting for some VEss17x6 props to arrive.
I may try the APC 17x6 in the mean time.
Hide Signatures
       Post #: 4761
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/6/2011 7:41 PM
gazzazh
Score: 135
Status: offline
OK.. Thanks will do and will keep u updated . cheers
Hide Signatures
       Post #: 4762
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/6/2011 10:09 PM
FOOPED
Score: 105
Status: offline
Gazzagzh, Process of elemination. First chcnge the plug and make sure the plug cap is on all the way . It has to cover the plug hex. Next thing if not already checked is your battery switches. plug bat stright into receiver and also ignition moduel. Next step if you still have problem is start unpluging servoes one at a time. Be sure your battieres are good befour you start and your receiver is a good one. I am assuming you are using spectrum 2.4 system.
Hide Signatures
       Post #: 4763
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/6/2011 10:11 PM
a1pcfixer
Score: 168
Last Login: 8/16/2012
Status: offline
quote:
ORIGINAL: TimBle
Are we back on subject (DLE20) again?
Look at the post #1 and in the [Prop Data] area.
During the first few months this DLE20 was out, many of us found the Vess 17 x 6 (Sport) to be the best overall for performance,
with the Xoar 17 x 6 almost as good. Both do a great job of putting this DLE20 into it's torque curve, withOUT going into
the dangerous high rpm's.
Other props show higher rpm's, but the thrust is down a wee bit.
I tried a Vess 18 x 6 and spool-up seemed a wee bit slower than the 17 x 6's.
Jim L.
Learn from the mistakes of others.You won,t live long enough to make all of them yourself.
Hide Signatures
(in reply to TimBle)
       Post #: 4764
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/7/2011 2:16 AM
microdon2
Score: 110
Status: offline
apc1fixer - Can we delineate prop performance with flying style in mind? In other words, if someone's looking for 3D or vertical I imagine a larger prop with less pitch. For performance \ speed, smaller diameter and higher pitch, right? Just wondering when you say a Vess 17x6 is best for overall performance, are you thinking more 3D \ vertical?
Hide Signatures
       Post #: 4765
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/7/2011 3:00 AM
a1pcfixer
Score: 168
Status: offline
Somewhat, yes. But this mighty little gasser's torque curve seem to peak around abouts 8600rpm, give or take a few.
As such, pulling power/thrust is best up to about that point, after which it's wasting energy spinning useless rpm's.
If ya want/need rpm's, drop down to a 16 x8, or a 15 x 10 3-blade.
But bear in mind what Jody's noted in that it'll unload about 800-1200 rpm in flight,
so keep your static thrust rpm's down, and don't blow it up.
Jim L.
Hide Signatures
       Post #: 4766
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/7/2011 3:02 AM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: SpinnerRow
quote:
ORIGINAL: microdon2
Spinner - Same thing happened to me last summer. No idea why. I believe it's happened to others on this thread (or somewhere I read it). But did your crankcase break, too? Looks that way. That didn't happen in my case. The good news is you're covered under warranty for 2 years.
The bearing cage rolls smoothly on the pin with the rod on it. Not sure what happened. It spins about 8700-8800 RPM on the ground with the 15x10 prop I run on it. I bought it from Tower, so I'll have to wait to see what they say.
My guess is the crank pin is not made with high quality metal found in for example...a Echo chainsaw.   Not  very many crank pins break in most engines.
I never met a engine I did not like !
Hide Signatures
       Post #: 4767
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/7/2011 3:19 AM
a1pcfixer
Score: 168
Status: offline
quote:
ORIGINAL: captinjohn
More likely 1018 or 1117 (low carbon steel) with a quickie case hardening on the bearing surface.
Now add in a lack of adequete lube, high rpm's generating excessive heat in that rotational mass (crank pin area),
and you get a roller cage bearing that toasts that heat treated pin changing it's hardness.
At some point a few of those little pin say I'm outta here!
Design flaw.....I doubt it.
Application misuse....more likely.
And remember, lawn care items such as you mentioned have a proper designed cooling setup that our uses lack.
Jim L.
Hide Signatures
(in reply to captinjohn)
       Post #: 4768
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/7/2011 6:35 AM
TimBle
Score: 162
Status: offline
quote:
ORIGINAL: a1pcfixer
quote:
ORIGINAL: TimBle
Post #1 is a great resource for a starting point wrt finding an ideal prop ON A PLANE. There ais frontal area and weight considerations as well as application.
Thus far tried the
XOAR/JXF 16x8, 16x10, 17x6, 17x8,
APC 16X7 and 16x8
of the lot the APC 16x8 flies the Spot on best.
Results may vary from plane to plane and pilot to pilot wrt flight performance.
Hide Signatures
       Post #: 4769
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/7/2011 9:51 AM
gazzazh
Score: 135
Status: offline
quote:
ORIGINAL: FOOPED
Thanks for all the info.. will work on it.. and will keep you posted.. Hopefully its just the plug.. i am keeping my fingers crossed...
Cheers
Hide Signatures
(in reply to FOOPED)
       Post #: 4770
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/7/2011 4:14 PM
acdii
Score: 155
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: microdon2
Is your P-51 about the same as a TF P-51 Gold Edition?  I am tring to determine if this will work for my plane.
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
       Post #: 4771
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/7/2011 4:34 PM
SpinnerRow
Score: 152
Status: offline
quote:
ORIGINAL: acdii
The .60 size, yes.
Airborne Models - World Models Blue Nose P-51
Got a new motor on the front of it. Anyone know of a 15x10 besides the master air screw K-Series or the ACP that I'm currently running? I'd like to stick with a 15x10 but need something that will load it up a bit more than a Pattern APC 15x10. I might try an APC 14x12 but I'm not sure it would load it up any better than the 15x10
Hide Signatures
(in reply to acdii)
       Post #: 4772
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/7/2011 11:31 PM
aa2dd
Score: 106
Last Login: 5/26/2013
Status: online
My Big Stick 60 setup is:
servos in rear. 10 oz fuel tank on cg, ignition and ignition battery directly behind firewall. Installed a hatch cover behind firewall so i have access to ignition/battery. DL 20 ENGINE WITH SLIGHT RIGHT THRUST. and about 3 or so oz weight on tail. prop 16x8 presently, but prefer 17x6. tires are dave brown lites and diameter is 6"! they look neat and work better than neat! and keep prop out of the ground
Performance is awe inspiring! straight up, rolling, all the way, as far as you wnat to go. very stable and fun plane to play with. Installed triangle stock behind firewall for strength, and pinned firewall on both sides and bottom. Dont know how long it will hold together. has about two or three gallons so far, and still going ok. With this setup, you need to be a throttle hound! dont think you wnat to fly with the hammer down all the time!
have fun
Bruce
aa2dd
Hide Signatures
(in reply to w8ye)
       Post #: 4773
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/8/2011 8:51 PM
DaleD
Score: 105
Status: offline
quote:
ORIGINAL: aa2dd
Bruce, would love to see a few pictures of your stick.
DaleD
Hide Signatures
(in reply to aa2dd)
       Post #: 4774
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/10/2011 8:02 PM
jsallade
Score: 100
Last Login: 5/10/2013
Status: offline
No a 14x12 will load it up less than a 15x10 within the same brand and line/series of props. To load it up more and go down to a 14 you need to find a 14x14... If they exsist, I've never seen one.
Hide Signatures
       Post #: 4775
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.844RCU1
