RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Page: <<   < prev  195 196 [197] 198 199 200 201 202 203 204   next >   >>
Login
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/15/2011 4:09 AM
w8ye
Score: 318
Last Login: 5/21/2013
Status: offline
The DLE 20 should be fine at 32:1
32 parts gasoline and 1 part oil. That is less oil than 30 parts gasoline and one part oil.
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to Doomking)
       Post #: 4901
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/15/2011 8:34 PM
armody
Score: 114
Status: offline
Hello y'all,
Since I'm one of the own of DLE20 and I would be experiencing my engine may be the end of January 2012, or February. There is another thread of Chinese gas engines, and it looks like we are under an influx of Chinese engines, which is good in a way that price may get plummeted but so far, it's seems like a shot in the dark.
http://www.rcuniverse.com/forum/m_10316994/anchors_10486267/mpage_16/key_/anchor/tm.htm#10486267
DLE20's been spoken a lot about and spoken high. I would like to ask a simple question of those who had been, or had used the DLE 20 engines in the past. The question is
What is a life span of DLE20 or bigger size gasser, how long do they last if not abused, and what are the precautions to be taken in order to keep it running good.
I know nothing can be predicted precisely when it comes to any electronics or mechanical stuff, but experiences make us learn the ropes.
Thanks y'all, happy flying and happy holidays
Mody
It''s great2 keep flying invariably. Hitec Aurora9 2.4 GHz, Yak 54-120 /XYZ20, Kadet II, U-Sport Kits, MXS-R RCG20 (AMA Mem)
Hide Signatures
(in reply to w8ye)
       Post #: 4902
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/15/2011 8:47 PM
ghoffman
Score: 163
Status: offline
I have over 250 flights on the DLE-20/Velox and had about 50 on the other DLE-20 I had before I sold it.  It is still running great, no issues.
Hide Signatures
(in reply to armody)
       Post #: 4903
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/15/2011 9:05 PM
armody
Score: 114
Status: offline
Wow 250 flights, that's really amazing and very encouraging. What are the general precautions to you take to keep it running well?
Hide Signatures
(in reply to ghoffman)
       Post #: 4904
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/15/2011 9:45 PM
SkidMan
Score: 105
Last Login: 4/24/2013
Status: offline
quote:
ORIGINAL: armody
Here is what I'm doing to keep my DLE-20 happy (which means I'm happy since I own two)
Correct fuel to Oil ratio with a high quality synthetic oil
Correct mixture: (Not too lean - Not too rich: either will cause problems)
Don't over-rev nor over-prop
(Don't crash)
Plenty of information on each of these on this thread.
Good engine.
Paul
Hide Signatures
       Post #: 4905
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/15/2011 10:29 PM
ghoffman
Score: 163
Status: offline
I run VP fuels 100% gas with Stihl HP Ultra synthetic, and a 17-6 or 17-8 Vess prop so it is not reving too high.  Also, I have plenty of cooling air, and even in a hover never gets too hot.
Hide Signatures
(in reply to SkidMan)
       Post #: 4906
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/15/2011 10:52 PM
armody
Score: 114
Status: offline
Paul, hoffman,
Great information. I bought me a wooden prop 16X6, and I might get 17X6 as well, don't want much speed but thrust. One thing I would like to clear it up, for the fuel, I bought Klotz 32:1 synthetic oil
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXS626&P=ML
and I have to buy the Hi Octane Supreme gasoline, that's it or something else?
Mody
Hide Signatures
       Post #: 4907
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/15/2011 11:13 PM
DougB1
Score: 112
Status: offline
quote:
ORIGINAL: ghoffman
How much would 2 gallons of VP fuel cost, that is what I mix up at one time. I have heard good things about it but is it cost effective if you fly a lot of gas.
Doug
Hide Signatures
       Post #: 4908
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/15/2011 11:30 PM
ghoffman
Score: 163
Status: offline
I buy it in a 5 gallon bucket for about $70, and the local shop gives me the Stihl HP Ultra with it.  With the DLE-20 that is alot of flying time, but I also use it in a DA-60 and a DA-120 as well.  The DA-120 uses about 20-25 oz per 10 minute flight, but the DLE-20 uses the 16 oz tank in maybe 30 minutes.
Hide Signatures
(in reply to DougB1)
       Post #: 4909
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/15/2011 11:33 PM
SkidMan
Score: 105
Status: offline
I'm using no-ethanol Rec fuel now but I started with 87 Octane pump gas and it worked just fine. Other than the possibility of some fuel line being more reactive to the ethanol than others, I believe that the uber-experts support the use of plain, out of the pump non-premium gas.
Everything else being equal, I don't believe that the gasoline will have any substantial effect on the longevity the engine.
Some have found a brand or type of fuel that works better for them. I use ethanol-free because I can get it and I'm not sold on the whole ethanol thing in the first place and it works fine for me.
Hide Signatures
       Post #: 4910
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/16/2011 12:09 AM
DougB1
Score: 112
Status: offline
quote:
ORIGINAL: SkidMan
What brand of fuel is it that has "no-ethanol in it, I would like to start using it if it is available where I live.
Hide Signatures
       Post #: 4911
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/16/2011 12:19 AM
ghoffman
Score: 163
Status: offline
VP fuels SEF 94:
Hide Signatures
       Post #: 4912
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/16/2011 1:00 AM
DougB1
Score: 112
Status: offline
quote:
ORIGINAL: ghoffman
VP fuels SEF 94:
I mis- read or mis-understood I thought you where talking about pump gas with the no-ethanol Doesn't someone have pump gas with out the ethanol in it ? I myself can't see paying $70.00 for 5 gallon of airplane fuel as much as I can go through, I just can't see how it is that much better but maybe someone can enlighten me.
Doug
Hide Signatures
       Post #: 4913
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/16/2011 1:09 AM
acdii
Score: 155
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: DougB1
quote:
ORIGINAL: ghoffman
VP fuels SEF 94:
Doug
I thought the whole point of going gas was to cut down on the costs of flying with Glow. $14 a gallon for gas is crazy.  Heck $4 a gallon is crazy.
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
       Post #: 4914
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/16/2011 1:10 AM
ghoffman
Score: 163
Status: offline
No, that is what I do because the DA-120 uses alot of it, but you can buy it a quart at a time.
Ready-To-Use Versions
  • 4 Cycle Unleaded Gasoline
  • 2 Cycle Premixed with Oil (50:1)
  • 2 Cycle Premixed with Oil (40:1)
Each available in quart containers, 5-gl pails, 30-gl and 54-gl drums
Hide Signatures
       Post #: 4915
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/16/2011 1:17 AM
ghoffman
Score: 163
Status: offline
Don't forget that a gasser runs at 14.7:1 air to fuel, a glow runs about 5:1.  If you can find pump gas without ethanol, great, but I won't run it if I don't have to.  There are a lot of other reasons besides economics to run a gasser as well.
Hide Signatures
       Post #: 4916
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/16/2011 2:59 AM
SkidMan
Score: 105
Status: offline
quote:
ORIGINAL: DougB1]
I don't know the brand of the stuff I use. I am told that it is only legal for use off road or in motorcycles and antique cars - at least in Florida. I get it from a performance motorcycle/marine shop in the Orlando area. They also sell VP.
The good news is that this non-ethanol REC fuel doesn't cost too much more than premium at the pump.
You might check out marinas in your area. They usually carry no-ethanol gasoline. Just remember that with the compression ratios we are running you don't need high octane,
Paul
Hide Signatures
       Post #: 4917
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/16/2011 4:06 AM
DougB1
Score: 112
Status: offline
When I go fly at the Dawn Patrol meets on a weekend I'll go through 5 gallons easy flying my 1/3 & 1/4 scale WWI birds. Yes going gas is a lot cheaper and who knows what it might cost if those birds were glow.
Hide Signatures
       Post #: 4918
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/16/2011 5:16 AM
Tarasdad
Score: 135
Last Login: 3/31/2013
Status: offline
The 76 station here sells 98-octane racing fuel at one of their pumps. We gat a lot of off-roaders here on weekends and holidays and they are the primary customers so it kinda makes sense. I've been looking at going to gas from glow, would this be a viable fuel? I'd be looking at smaller displacements, 20cc and less.
Tarasdad
Club Saito #680; 2x Saito .91, Saito .80, Fox .50, Fox .25, Fox .19; Apprentice 15e; Tiger 60; Super Chipmunk
Hide Signatures
       Post #: 4919
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/16/2011 1:49 PM
w8ye
Score: 318
Status: offline
The DLE20 is the most viable of the small gassers
Original AMA #31261
Hide Signatures
(in reply to Tarasdad)
       Post #: 4920
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/16/2011 2:06 PM
ghoffman
Score: 163
Status: offline
+1 definitely.
The thing that the guys around here joke about is how little fuel my DLE-20 uses.  I had a dead stick and was saying that I don't understand, I put gas in it last month.  It will go 4-5 flights on one (1/2 liter FiJi bottle) tank of gas, and of course, there is no slime on the plane, no starter, no glow igniter.  It is: ignition on, choke on, flip 3-4 times until it runs and dies, then choke off, flip it and it is running.  Usually after that, it is a single flip the rest of the day.
Hide Signatures
(in reply to w8ye)
       Post #: 4921
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/16/2011 3:18 PM
armody
Score: 114
Status: offline
quote:
ORIGINAL: armody
Paul, hoffman,
Mody
With this Klotz synthetic oil+Gasoline from the gas station is all I need for my DLE20.
I will appreciate if anyone can answer me on my question since I'm gonna use DLE20.
Hide Signatures
       Post #: 4922
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/16/2011 4:51 PM
a1pcfixer
Score: 168
Last Login: 8/16/2012
Status: offline
Premium is NOT required, but can be used.
All that's required for our gas is regular, and 10% methanol is fine for any of our toys of the past 15 years or so.
Think of the gas your weed trimmer, chain saw, edger uses....regular gas + 2-stroke oil at the correct mix ratio,
nothing special - same for most of our RC gassers UNLESS the mfg specifies otherwise (the DA60 requires premium for example).
Jim L.
Learn from the mistakes of others.You won,t live long enough to make all of them yourself.
Hide Signatures
       Post #: 4923
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/16/2011 5:02 PM
SkidMan
Score: 105
Status: offline
quote:
ORIGINAL: a1pcfixer
My limited understanding is that this is due to these newer engines using gaskets and membranes that are compatible with alcohol (ethanol in the case of gasoline).
Hide Signatures
(in reply to a1pcfixer)
       Post #: 4924
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 12/16/2011 5:09 PM
armody
Score: 114
Status: offline
Thanks for the replies guys, I really appreciate it.
Regular Gas seems to be fine idea
What about the Ethanol? is it lower graded than regular one and is it available at the gas stations?
Hide Signatures
       Post #: 4925
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.047RCU1
