RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)    Gallery
Logged in as Guest
Users viewing this topic: w1nd6urfa
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Page: <<   < prev  222 223 [224] 225 226 227 228 229 230 231   next >   >>
Login
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2012 3:08 AM
phakur
Score: 100
Last Login: 6/18/2013
Status: offline
Yeah. We opened the low a bit to make sure we could get fuel into the engine. It being new. Didn't go much in the high side other then checking rpm. I think we gave it less then a quarter turn. The engine runs great for the several minutes in runs. No hesitation no stuttering. Up until the second it just quits Moved everything back to factory setting in an attempt to clear the problem
I'm using lawn boy oil mix so we are seeing a small amount of deposit out the exhaust as you would expect
It's just kind of wacky
I'm pulling the engine and will have the guys at the field take a look at the carb this weekend but still don't know how to eliminate the ignition as a possibility
Hide Signatures
(in reply to ahicks)
       Post #: 5576
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2012 4:13 AM
DwightMann
Score: 105
Last Login: 6/16/2013
Status: offline
I had a similar symptom caused by a loose wire in the battery connector. I finally noticed the " hot ignition" led was not lit.
Hide Signatures
(in reply to phakur)
       Post #: 5577
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2012 4:21 AM
RiverLarry
Score: 100
Last Login: 6/17/2013
Status: online
Hide Signatures
(in reply to DwightMann)
       Post #: 5578
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2012 9:31 AM
Lifer
Score: 153
Status: offline
As far as the question on the Corsair prop issue is concerned, you might try a 3 bladed 16x8 or 15x7 from Master Airscrew. I use both.
Hide Signatures
(in reply to RiverLarry)
       Post #: 5579
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2012 3:58 PM
Cactus463
Score: 100
Last Login: 6/10/2013
Status: offline
My DLE 20 runs greatbut-it takes about 10 to 20 seconds to slow to low idle after running at a higher rpmwhen it does come down to low idle it is fine-transition to full throttlr is fine-runs great except for this quirk
Hide Signatures
       Post #: 5580
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2012 4:11 PM
w8ye
Score: 318
Status: offline
The low speed needle valve is set too lean
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to Cactus463)
       Post #: 5581
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2012 4:18 PM
Lifer
Score: 153
Status: offline
Plus 1 on w8ye's comment.
Hide Signatures
(in reply to w8ye)
       Post #: 5582
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2012 4:50 PM
acdii
Score: 155
Status: offline
Well, I had my second flight with the 4* the other night. I switched the prop to an APC 16X6 and it woke it up.  I did not touch the needles on it, and it ran good. No transition issues like the first time with the MAS, temp was about the same, except lower humidity.  It idled down good, a quick touch o throttle got the RPM's up and it idled down nice again during my final, so looks like I got the engine dialed in well for the next gallon or two until it is finally broken in. When I landed after a 9 minute flight, the engine was cool, as in if I touched it I wouldn't get burned.  Has a little burble to it at high end, but no performance issues. I think the 4* has a 12-14 ounce tank and I used 1/4 of it for the 9 minute flight, which should relate to 30 minutes of flight to the tank. Wow!  Big difference between the APC and MAS props on this plane.  The MAS used much more fuel. I burned up a whole tank in 15 minutes with the MAS on.
Hooked now on APC props, have them on 3 of my planes that used to have MAS K.  All three fly much better.
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
(in reply to Lifer)
       Post #: 5583
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2012 7:40 PM
Falcon32
Score: 105
Last Login: 6/15/2013
Status: offline
Hi John
If you want to quiet it down try here http://www.gashanger.com/index.php?option=com_content&view=article&id=68&Itemid=75
A bit expensive and you will loose about 300 RPM but it does work.
Falcon
I’d rather be twiddling my thumbs.
Hide Signatures
(in reply to johnsh1234)
       Post #: 5584
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2012 7:44 PM
Twin_Flyer
Score: 108
Status: offline
Troy Built Models has something like that as well, and its only $20.
http://www.troybuiltmodels.com/items/TBMDLE20SILENCER.html
Bill S.
Carl Goldberg Ultimate Brotherhood #56
Ultra Sport Brotherhood #135
http://radiocontrolhobbies.freeservers.com
Hide Signatures
(in reply to Falcon32)
       Post #: 5585
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2012 7:48 PM
tailskid
Score: 199
Status: offline
I just bought one..should be here next week....
# 93 in Club Saito
Carl Goldberg Ultimate Brotherhood # 12
Hide Signatures
(in reply to Twin_Flyer)
       Post #: 5586
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2012 8:08 PM
ahicks
Score: 669
Status: offline
quote:
ORIGINAL: acdii
The 20's really like the APC 17x6. If you get the chance they are definitely worth a try. Going that way will load the engine a little more, and might even help clear up that burble? -Al
Hide Signatures
(in reply to acdii)
       Post #: 5587
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2012 8:53 PM
acdii
Score: 155
Status: offline
All the LHS had was a 17x4, otherwise I would have tried it.  For now I will fly with the 16x6 and order the APC when I have other items to order.   Once I get my landings smoothed out where I stop bouncing and knicking the prop, I will go to the larger one.
Hide Signatures
       Post #: 5588
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2012 9:36 PM
johnsh1234
Score: 100
Last Login: 4/27/2013
Status: offline
quote:
ORIGINAL: Falcon32
Hi John
Falcon
Thanks Falcon, that's interesting and will maybe try this option if I don't have any luck with Lifer's suggestions, didn't know anyone was doing these here in the UK, I'm very envious of the availability and prices of RC stuff that are available to people in the States.
Thanks also to Twin-flyer, but as I previously posted we are being really hard hit by customs and excise on buying anything from the States, a few years ago this was not a problem but now it is. As an example about a year ago I mail ordered a Aeroworks Prox .60-.90, after paying postage, import duty, vat, and, insult to injury handling charges it cost me around £240.00 thats around  $375.00.
Cheers,
John
Hide Signatures
       Post #: 5589
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2012 12:31 AM
NM2K
Score: 161
Status: offline
Make sure your fuel tank's vent line is unobstructed, i.e., no kinks.
Ed Cregger
"Practice makes prefect"
Hide Signatures
       Post #: 5590
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2012 3:33 AM
RBean
Score: 115
Status: offline
Something to look out for on these DLE 20s is the spring clip for the throttle shaft coming off. Then the spring pushes the throttle plate againt carb barrel side and distorts the plate. Had this happen twice. The sign was the engine wouldn't idle down. Too much fuel and air leaking through the distorted area. I tried to fix by hammering out the distortions and filing the edges down smooth. But couldn't get it close enough. Still leaks but will idle down slower. Need new carb but every one is "out of stock".
Hide Signatures
(in reply to NM2K)
       Post #: 5591
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2012 3:36 AM
tailskid
Score: 199
Status: offline
Oops, I took my spring OFF - hope that doesn't hurt anything.....
# 93 in Club Saito
Hide Signatures
(in reply to RBean)
       Post #: 5592
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2012 4:20 AM
nomadmariner
Score: 100
Last Login: 1/27/2013
Status: offline
Suggest putting the spring back on as it is needed but do not hook it on to the arm.
quote:
ORIGINAL: tailskid
“In order to fly, all one must do is simply miss the ground.”
Hide Signatures
(in reply to tailskid)
       Post #: 5593
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2012 4:27 AM
tailskid
Score: 199
Status: offline
That will be tricky....but I'll try. Thanks for the advice...
# 93 in Club Saito
Hide Signatures
(in reply to nomadmariner)
       Post #: 5594
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2012 6:17 PM
mach2
Score: 125
Last Login: 5/12/2013
Status: offline
quote:
ORIGINAL: rhd-RCU
Flying fields have been lost because of the noise. What we like and what the rest of the community likes are two differnt things.
Completely understandable, but I think this conversation started as a "what I like" thing. So that's where my side of it is coming. So to tell eachother that this sucks, or that sucks is different. That is simply opinion.
The 20 is perfect for the old man next door who stole my trash can and dumped the trash on my lawn because he feels my trash can should be behind my fence so he doesn't have to see it! I need to do some tuning today for a matter of fact.....
Jeremy
70" Revolver, DLE20
67" Goldberg Edge 540, DLE20
Hide Signatures
(in reply to rhd-RCU)
       Post #: 5595
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2012 6:28 PM
rhd-RCU
Score: 105
Status: offline
 I said nothing about sucks. I just stated a fact and also how I feel.
rd
Hide Signatures
(in reply to mach2)
       Post #: 5596
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2012 7:12 PM
mach2
Score: 125
Status: offline
quote:
ORIGINAL: rhd-RCU
Oh, no. I was talking about someone else's comment about the volume. Sorry for the miscommunication. Its kind of a dead subject now. I just hadn't been on in a few days so i didnt see that the topic has changed to a tuning question. I was just saying that i understand what you are saying and that I feel there is two sides of the noise issue. One side is how we as flyers like or dislike the sound of our planes, and then on the other side of the coin is the issue of nuisance to the community. Luckily I fly in a remote location so its a non issue.
Jeremy
70" Revolver, DLE20
Hide Signatures
       Post #: 5597
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/22/2012 10:04 PM
mach2
Score: 125
Status: offline
does anyone have a good source to buy the spinner adapter nut? I ordered one from horizon a while back but I dont like the way the threads feel on it. The 8x1 nut is kinda hard to find.
Jeremy
70" Revolver, DLE20
Hide Signatures
(in reply to mach2)
       Post #: 5598
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/22/2012 10:27 PM
RiverLarry
Score: 100
Status: online
Tower H
Hide Signatures
(in reply to mach2)
       Post #: 5599
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/22/2012 11:08 PM
Lifer
Score: 153
Status: offline
Tower sells one that is part of the .60-size P-47. You also might pick up a tap and clean up the threads on the spinner nut you have. Bye the way, the DLE 20 is a GREAT fit for the Top Flight P-47. Flies great with a 16x8.
Hide Signatures
       Post #: 5600
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.328RCU1
