RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Page: <<   < prev  234 235 [236] 237 238 239 240 241 242 243   next >   >>
Login
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/31/2012 10:45 AM
Lifer
Score: 148
Last Login: 5/19/2013
Status: offline
Thanks! I wish they still sold the P-38.
Hide Signatures
(in reply to rcguy59)
       Post #: 5876
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 10/31/2012 2:05 PM
acdii
Score: 155
Status: offline
quote:
ORIGINAL: armody
Guys,
Thank y'all for the great inputs. I have to run 3 to 4 full tanks on my DLE20 until I'm able to fly it. For fuel I'm using Klotz 32:1 with regular gas. Plug is CM6 NGK. In order to empty the tank, on what RPM should it be running until it burns out all the fuel? It should be full RPM for 40 seconds then idle for a minute? When do I have turn the motor off and let it cool for 5 minutes? I just wanna know the break in details.
I would really appreciate that.
Mody
No need to, just set the needles and fly. The engine will break in better flying than on the ground, you can easily overheat it on the ground.  Just run it rich for the first gallon or so, then readjust as you see fit. You will know when it is time to readjust as the idle will start getting higher without touching it, so you can back down the servo idle, and retune the needles.  These aren't like the glow motors where you run them a few minute WOT and let them cool down in stages.   Think of these the same you would a weedwacker or chain saw. Fire it up and put it to work.
_____________________________
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
(in reply to armody)
       Post #: 5877
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/2/2012 6:38 AM
armody
Score: 114
Status: offline
acdii,
I'm thinking to hopefully get this baby up in the air soon! I'd be flying it without a cowl for few flights, once engine is pretty much settled, I'd put the cowl back on.
Thank y'all for your inputs
Mody
It''s great2 keep flying invariably. Hitec Aurora9 2.4 GHz, Yak 54-120 /XYZ20, Kadet II, U-Sport Kits, MXS-R RCG20 (AMA Mem)
Hide Signatures
(in reply to acdii)
       Post #: 5878
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/2/2012 2:37 PM
acdii
Score: 155
Status: offline
Thats pretty much what I did. I stuck it on a plane that I got for $30 with no cowl on it, and just ran it.  Then the plane turned out to not be able to handle the motor, put it on another plane that could and it started running better with each flight.
BTW, my AYZ 20 arrived last night from VV. It looks a LOT like the DLE20, but the carb is much smoother in operation.  Looks like it came with a spinner adapter too so my 4" spinner for the Stang should fit this one OK, it does not fit the DLE at all.  Keeping my fingers crossed that it runs as good as the DLE does, should make the Mustang a sweet flyer.
One thing though, the motor mount included did not include the hardware, and I forget what size bolts to use for the engine to mount and mount to fuse, and want to get some on my way home tonight.   I'm thinking 8-32 for the engine, and 10-32 for the fuse, but not 100% sure.
Hide Signatures
       Post #: 5879
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/2/2012 4:41 PM
Cactus463
Score: 100
Last Login: 5/13/2013
Status: offline
I have DLE 20 in a Revolverengine runs grealt but find carb is veryvery sensitive to the smallest input-Have worked on servo and throttle arms to get the ssmallest movement possible-still one click on throttle gives about 3-4 hundred rpm increasehard to taxi-anyone else with this problem-???????
Hide Signatures
(in reply to ahicks)
       Post #: 5880
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/2/2012 5:52 PM
gade600sdi
Score: 115
Last Login: 5/17/2013
Status: offline
This is not a DLE 20 problem, but a geometry problem. Use a long arm on your carb and a small one on your servo. Set your travel to 100% on high and low and adjust the angle and the lenght of the pushrod. Lastly , you need a throttle curve. If your radio doesnt have it, get a radio that has mixing and throttle curve in the menu, so you can fine tune your resolution and travel to your liking.
Hide Signatures
(in reply to Cactus463)
       Post #: 5881
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/3/2012 1:42 AM
triumphman49
Score: 110
Last Login: 5/20/2013
Status: offline
•Click image, use arrow keys on keyboard or use controls under image to navigate photos
•Attached files only are shown in slideshow. Inline images from remotely hosted sites are not shown
Loading...
There is a copy of throttle geometry - clik on "Gallery" at the top of page . see below
Image 57 of 565
Image from post #10038571
Hide Signatures
       Post #: 5882
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/3/2012 2:09 AM
Ernie Misner
Score: 130
Status: offline
Just using reverse expo on a cheap radio should help. Yes, you definitely want to follow the throttle setup instructions on the gas engine thread near the top of the forum.
Hide Signatures
(in reply to triumphman49)
       Post #: 5883
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/3/2012 2:45 AM
ahicks
Score: 669
Status: offline
Linkage diagrams:
http://www.rcuniverse.com/forum/m_8673009/tm.htm
go to post #22, down near the bottom of the first page
Hide Signatures
(in reply to Ernie Misner)
       Post #: 5884
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/3/2012 3:28 AM
rcguy59
Score: 129
Status: offline
If your radio has a throttle curve function or even just expo, set the linkage up as you would for a glow motor, then flatten the curve on the bottom end. Walbros are about as proportional on the bottom end as a toggle switch would be.
Jet Central Superbee & Rabbit
12Z Fasst for everything I fly
Hide Signatures
       Post #: 5885
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/3/2012 6:55 AM
armody
Score: 114
Status: offline
quote:
ORIGINAL: gade600sdi
I have Hitec Aurora 9. I read the exponential is used for softer functionality of servo, but what does a throttle curve do?
Mody
Hide Signatures
(in reply to gade600sdi)
       Post #: 5886
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/3/2012 7:14 AM
rcguy59
Score: 129
Status: offline
A throttle curve's effect is similar to that of expo. Properly adjusted, it will make a gasser's decidedly NON-linear throttling "feel" more linear on the throttle stick. If your radio has either of these features, monkeying around with the linkage geometry is completely unnecessary. Fine tuning of the engine's response to throttle-stick movement is very easy using either of these functions. This is exactly the sort of thing computer radios were invented for.
Hide Signatures
       Post #: 5887
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/3/2012 4:15 PM
acdii
Score: 155
Status: offline
Makes a world of difference too. Instead of having a half stick of throttle, you can adjust it for a full stick, just dont expect much difference when you get pas half stick, its pretty much wide open past that point.
Hide Signatures
       Post #: 5888
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/4/2012 7:43 AM
armody
Score: 114
Status: offline
Hello Guys,
As per acdii's suggestion. Last week I ran the DLE20 on the ground for few minutes sporadically. As I was told to get this plane and fly. Today weather is excellent, wind is gonna be less than 8mph and I'm fully prepared to have a maiden flight on it. Wing bolt I lost it and I did not have the which can be screwed tight with hand. I found my old nylon bolt, and I cut them half. They fit pretty well to the wings, and I have not installed the cowl yet, since I gotta fly it without the cowl for a while right?
Biggest pain in the butt is screwing tight the wing bolt, one can be done with the flat-head screw driver other needs a lot of cumbersome work, but I'd make it work, at least I'd try. I'd try to adjust the engine, I'm only afraid of idle. While I was running the engine, after setting up the idle, I also noticed that after the full throttle as soon as pull the gimbal back to idle,, the idle would stay little bit higher than previous setting, but after may be 10 seconds, it would get back to the old setting. I did not understand that part. Anyway, it's my first gasser and experiencing new things would make me learn new things on that.
Still inputs are welcome
Three recent pictures of my plane as I was working on it in my office at home
Mody
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to acdii)
       Post #: 5889
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/4/2012 9:09 AM
sandyjain
Score: 100
Status: offline
The DLE20 ignition has a peculiarity that it gets to idle after a few seconds. So do not worry. for initial flights keep the idle tad high - high enough that the model does not move on the ground.
Remember to check CG, all bolts must have threadlock and surfaces will feel better with -ve expo. On futaba I keep -40%.
I guess you shall be rather pleased with the performance of the DLE20...your model looks great...enjoy your maiden...
Cheers....
Sandy Jain
Hide Signatures
       Post #: 5890
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/4/2012 1:27 PM
microdon2
Score: 110
Last Login: 5/14/2013
Status: offline
armody - if you want to pull your DLE 20 down to idle sooner use the Idle Cut or Throttle Down function on your radio. I've been doing that and it works great - let's you keep the idle at a decent (none-stall) rate while up in the air, then you can cut it on landing approach, if needed. Also, for your wing-bolt problem, buy a small ratchet. Much easier than using your fingers in that tight space.
Hide Signatures
(in reply to sandyjain)
       Post #: 5891
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/4/2012 2:01 PM
ahicks
Score: 669
Status: offline
Mody, you probably have the idle mixture adjusted slightly lean. Try going just a tad richer with it and see if that doesn't get it to come down to idle more reliably.
Hide Signatures
(in reply to microdon2)
       Post #: 5892
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/4/2012 9:26 PM
armody
Score: 114
Status: offline
Sandy Jain Thank you very much for your comments. That's my first Gasser and I put it together with the help of my mentor who is extremely meticulous about geometry, measurement and accuracy. CG had been set up as per manual's direction. We did not have to add up the weight to it, just tweaked around the battery packs, and boom we got pretty accurate CG on it. I've been helped out pretty well on throttle curve, and I gotta do some research on that.
About the exponential, I had set it up on my old glow plane which I have sold out, it worked great. Without expo, if I have to jitter the gimbal/ radio stick on the aileron would jitter too, once the expo is set up, the operation is very smooth even jittery of the thumb won't make much difference on it. Now on this Yak 54 120 I tried to set up the expo on my Hitec Aurora 9, pretty much the same set up I did on my previous gas plane. With expo 0ff, the aileron throw/ movement is normal, but when expo is on, movement is not smooth, it lags a tad which is noticeable but barely. I never understood that part if anyone has idea on that?
microdon2 That's a pretty good idea to set up the idle cut or throttle down function on my radio. As far as the small ratchet is concerned, I thought about it and it's a pretty good idea, but the nylon bolt has a flat head screw on it, it is not hex screw, so does ratchet come with some sort of add to it thingy which may tighten up the flat head nylon bolt?
ahicks I'm gonna work on that mixture as well.
Today I have not been able to have a maiden flight on my plane, since weather was ideal, sunny, less than 8 Mph wind, it's beautiful out there, temp is around 80 +. Today nobody's at the flying field as well, next week there would be some guys at the flying field with pretty good experience on gas engines. I'd rather like to go there while they are present, so I can have them look at my engine as well. I hope this Renaissance gets over soon, it causes a lots of traffic problems in our area.
Thank y'all
Mody
Hide Signatures
       Post #: 5893
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/4/2012 10:04 PM
armody
Score: 114
Status: offline
I also found this video of Exponential setup on Hitec Aurora 9 2.4Ghz radio.
http://www.youtube.com/watch?v=7QNLSArltSU
Hide Signatures
       Post #: 5894
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/6/2012 2:08 PM
Cactus463
Score: 100
Status: offline
Had same problem with minerichened the low speed needle 1/8th turn and it works fine now-
Hide Signatures
       Post #: 5895
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 3:05 AM
armody
Score: 114
Status: offline
Hello Guys,
Thanks a lot for your great inputs. I wanted to ask y'all this question but somehow I forgot. Last night I was watching a DLE20 video on YouTube, so that question popped up on my mind.
The question was regarding the "Gas and Synthetic Oil for the Gas and ratio".
Here is what I'm using. I'm using Regular Gasoline the 3rd grade which is lowest one 87 one I think which normally I use in my car as well. That's the gasoline I'm using for my DLE20. Do I have to go one grade up?
The synthetic oil I'm using is Klotz. Do I have to buy Red Line synthetic oil or Stihl or Penzoil? What do you say about Klotz?
Third and last question. The ratio I used was 32:1 and I gotta remind you I just ran the engine on the ground almost 1/4 of a tank or max 1/2 that's it with regular gas klots 32:1 ratio. After how many flights do I have to change the synthetic oil ratio or do I have to keep it 32:1. Also explain in to me the ratios for the oil, and reducing the ratio or adding the ratio what difference does it make to the motor/engine.
I will really appreciate detailed explanations here.
Thanks a lot guys and happy flying
Mody
Hide Signatures
       Post #: 5896
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 3:35 AM
w8ye
Score: 318
Status: offline
You must keep the "DLE 20" at 32:1 or have trouble with the rod
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 5897
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 3:39 AM
bcchi
Score: 650
Status: online
quote:
ORIGINAL: armody
Hello Guys,
Mody
About your wing bolts.Buy two bolts and two wing nuts.Screw wing nuts onto bolts and use wing nuts to hand tighten in your airplane.
BCCHI
Hide Signatures
       Post #: 5898
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 3:55 AM
tailskid
Score: 199
Status: offline
quote:
ORIGINAL: w8ye
You must keep the ''DLE 20'' at 32:1 or have trouble with the rod
I thought they recommended 40:1.....but more oil, the longer the engine lasts!
# 93 in Club Saito
Carl Goldberg Ultimate Brotherhood # 12
Hide Signatures
(in reply to w8ye)
       Post #: 5899
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 11/14/2012 4:10 AM
armody
Score: 114
Status: offline
quote:
ORIGINAL: w8ye
You're talking about trouble with piston rod? so I need to keep the ratio 32:1. Thanks for the great tip w8ye.
bcchi. I never thought about wing bolts good idea, and I'm gonna use the washers from inside and outside to keep the wings tightly closed and intact.
Tailskid: You thought they recommended 40:1 or you're sure about it. I read in the DLE20's manual and actually it says 30:1 not 32:1 guess ain't much of a difference. One question, I'd like to ask ya, how can you say more oil, the long the engine lasts?
Hide Signatures
(in reply to w8ye)
       Post #: 5900
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.500RCU1
