RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)    Gallery
Logged in as Guest
Users viewing this topic: Jonde
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Page: <<   < prev  250 251 252 253 254 255 [256] 257 258 259   next >   >>
Login
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/1/2013 6:44 AM
bcchi
Score: 650
Last Login: 5/22/2013
Status: online
quote:
ORIGINAL: Ernie Misner
>>> .I have had one for years no problems with them. I guess they are still around.Really tells you right now what timing is doing >>>
bcchi, are you saying that you've mounted a degree wheel AND propeller and have actually seen what the timing is doing when it is RUNNING?
Thanks so much, Ernie Misner
Yes I do that all the time.
BCCHI
Hide Signatures
(in reply to Ernie Misner)
       Post #: 6376
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/1/2013 2:37 PM
BadAzzMaxx
Score: 448
Status: offline
Here a couple pictures of a rig I made for checking the timing curve on ignitions.
Works pretty good and can the curve from 200 rpm to 8,000 rpm.
Front half of a engine, out runner motor and speed controller with servo tester to run the speed controller.
Don't have to worry about getting whacked by the prop when testing.
Milton
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Contact Milton@rcextremepower.net
Team RCeXtremePower.com
Hide Signatures
(in reply to bcchi)
       Post #: 6377
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/1/2013 3:35 PM
kmeyers
Score: 125
Status: offline
Milton
Great looking rig, I always say knowledge is power. I was hoping someone would put up some pics of how they were making timing lights work.
I have sent alot of people to RCeXtremePower for ignition solutions, they have always been taken good care of.
Keep up the great work.
Oops!
Hide Signatures
(in reply to BadAzzMaxx)
       Post #: 6378
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/1/2013 4:05 PM
BadAzzMaxx
Score: 448
Status: offline
quote:
ORIGINAL: kmeyers
Milton
Thanks for the referrals and comments.
You get tired of working and decide to retire, Then you get bored and think of something to make to take up some time.
Then you think how can you make money with it. LOL
So far have built a CNC router but had no idea what I was going to use it for until I came up with the idea of the conversion ignition brackets for the DA/3W and ZDZ engines, With a cost of about $3,000.00 for router and software I will have to sell a lot of them to pay for it.
Then got bored again and built a electric chopper bicycle, Don't want to say what I have in it. LOL
Milton
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to kmeyers)
       Post #: 6379
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/1/2013 10:46 PM
vettedriver
Score: 100
Last Login: 5/20/2013
Status: offline
Just received my DLE 20 from VV and it came with a Model A-02 Ignition 8.4v date of MFG 6/12
Hide Signatures
(in reply to ahicks)
       Post #: 6380
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/1/2013 11:23 PM
Ernie Misner
Score: 130
Status: offline
quote:
ORIGINAL: vettedriver
Hey that's a good start from DLE. I wonder if they are still shipping them with the timing set at 35 degrees BTDC? I think at 35 degrees they just line the sensor up with the center-mold-line on the case casting. Is that where yours is?
Hide Signatures
(in reply to vettedriver)
       Post #: 6381
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/2/2013 4:10 AM
vettedriver
Score: 100
Status: offline
Ernie, you are correct right in line with the case webbbing.
Hide Signatures
       Post #: 6382
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/2/2013 6:22 AM
Ernie Misner
Score: 130
Status: offline
Just retard it as far as it'll go in the slots and you'll be closer to 28 degrees.
Hide Signatures
       Post #: 6383
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/3/2013 3:32 PM
phakur
Score: 100
Status: offline
Has anyone used this DLE 20 on a CMP Cessnal 182?
If sohow'd it go?
Larry
Hide Signatures
       Post #: 6384
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/4/2013 7:40 AM
armody
Score: 114
Status: offline
quote:
ORIGINAL: BadAzzMaxx
quote:
ORIGINAL: kmeyers
Milton
Milton
Milton,
That's simply genius, Wow. Awesome bike.
Mody (Working and Enjoying Broadway of Nashville, TN)
It''s great2 keep flying invariably. Hitec Aurora9 2.4 GHz, Yak 54-120 /XYZ20, Kadet II, U-Sport Kits, MXS-R RCG20 (AMA Mem)
Hide Signatures
       Post #: 6385
RE: DLE 20cc Gasser! (Data & Links 1st Post) - 2/4/2013 5:09 PM
rye
Score: 110
Last Login: 5/23/2013
Status: offline
though this may help,rye
http://www.rcuniverse.com/forum/m_11396471/anchors_11396528/mpage_1/key_/anchor/tm.htm#1
Hide Signatures
(in reply to jedijody)
       Post #: 6386
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/4/2013 9:25 PM
captinjohn
Score: 247
Status: offline
I have used a older Sears timing lite that is 12 volt powered.  I use a very small strand of copper wire and place it on the sparkplug tip so the cap when shoved on plug, holds it there. This give a good place for the pick-up wire to work the timing lite.  Works great!  I have used it on flywheel mags too...some do have advance....which was a surprize too me.  I even held a camera and the flash from lite on the prop...."frooze" the motion of the prop and in the photo the prop arc was a blur.  Capt,n  P.S.  Always use a jumper ground wire too from steel braid to engine.
I never met a engine I did not like !
Hide Signatures
       Post #: 6387
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/6/2013 12:45 AM
SteveC68
Score: 100
Last Login: 5/3/2013
Status: offline
Any chance of DLE coming out with a DLE20 rear exhaust with the angled plug head?
Also does anyone make a prop shaft extension for the DLE20?
Steve
Hide Signatures
(in reply to captinjohn)
       Post #: 6388
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/6/2013 6:03 AM
armody
Score: 114
Status: offline
Hello Guys,
How is it going? Nashville Tennessee is a great place, night life is amazing, this city looks like it has some life going on, I'm overwhelmed, impressed and had great time of my life as my project is almost getting wrapped up. The question I wanna ask here is about DLE30. Though I totally understand this is not the thread for DLE30 but I still feel like asking the question here.
As I have mentioned I was gonna get Seagull's Sea Fury ARF, but I've changed my mind and I'm gonna get Seagull's Edge 540 180 with 77" wing span and planning to get DLE30 on it. It seems like a great combo, ain't it?
http://www.horizonhobby.com/products/edge-540-180-arf-SEA5550
I've setup my mind on it, I wanna go little more bigger on it. 30cc motor seems to be a great choice on it. Question is, hopefully once I've gotten that motor, do I still have to use regular oil during break in and after how many tanks am I supposed to switch it to synthetic blend. Secondly, does it's ignition give or is it gonna give me hard time set up like DLE20 did?
Mody (In Nashville now)
Hide Signatures
(in reply to SteveC68)
       Post #: 6389
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/6/2013 1:56 PM
ahicks
Score: 669
Status: offline
DLE 30 care and feeding the same as the 20. Most will use the same gas can to feed both. It might be a little more forgiving when setting up the low speed, but by time you get to that you'll have enough time on your 20 where the differences regarding the 30 will be a non event. Should be of no concern....
Hide Signatures
(in reply to armody)
       Post #: 6390
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/7/2013 12:40 AM
rcguy59
Score: 129
Status: offline
A 77" airplane is better suited to a DLE 35 than the 30. The power difference is noticeable. I know, I have both.
Jet Central Superbee & Rabbit
12Z Fasst for everything I fly
Hide Signatures
       Post #: 6391
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/7/2013 3:44 AM
armody
Score: 114
Status: offline
rcguy,
you think 35cc is a better choice than 30cc? I think I'd go by your advice then.
Mody
Hide Signatures
(in reply to rcguy59)
       Post #: 6392
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/7/2013 3:55 AM
rcguy59
Score: 129
Status: offline
I think the 35 is a better choice for your airplane. I have 2 DLE 30's, and I'm very fond of each. The reason I recommend the 35 for you is because it has more power. Most 30cc planes are 70-72"  span. At 77" span, a bit more power is needed to get the full potential from the airframe. Both are great engines.
Hide Signatures
       Post #: 6393
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/10/2013 12:01 AM
Leroy Gardner
Score: 116
From: Coeurd'''''''''''''''''''''''''''''''' ALENE,
Status: offline
There has been the question of mufflers for the DLE 20cc engine in a narrow cowl like the 60 size mustang or in my case a bashed Tiger 60. It's a Pitt's style by J'TEC Radiowave now available at Tower Hobby, stock # LXBFYT $ 79.99, fit's engine very nicely.
Can not get upload images to come up, will try later.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Leroy Gardner -- 2/10/2013 8:40 PM >
Leroy Tiger Club # 53, TF 1/5th P-51 mustang
Eagle 2'' bashed Tiger 60
Hide Signatures
       Post #: 6394
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/17/2013 9:36 PM
armody
Score: 114
Status: offline
Hello Guys,
Today I went to fly my Yak 54 with DLE20 on it. I tried my best to lower down the idle but I couldn't do it. Tweaked the radio, EPA, Sub-trim, it never ran right. My flying buddy and I tried to tweak the servo, it made a little difference. Now I have realized along with the fine tuning on LSN and HSN, it also needs the right push rod for throttle. The throttle rod is of nylon, covered with red nylon on top of it, one end which has the clevis which goes to the servo and other end which is metal Z band goes to the carb throttle arm which I think is a mistake if I'm right? does it have to have a plastic clevis or should I use Du-bro ball link threaded 1/16th. The push rod bends as well. I need some help here, what exactly do I need to use for throttle, what size push rod, which linkages size and all.
Please help!
Mody
Hide Signatures
(in reply to Leroy Gardner)
       Post #: 6395
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/17/2013 9:48 PM
armody
Score: 114
Status: offline
Here are some images, BTW I couldn't get to fly today . It got windy too but not bad though, but whole day wasted. Better luck next time
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 6396
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/17/2013 10:27 PM
ahicks
Score: 669
Status: offline
Mody getting your throttle linkage running smoothly with little or no slop is almost an art form. What you have will work fine if properly installed?
Straight lines from the carb to the servo work best. If you deviate far from that you're probably going to spend extra time getting it to work freely.
Hide Signatures
       Post #: 6397
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/18/2013 12:19 AM
757jonp
Score: 110
Status: offline
Evening Mody
You got a Z bend in that throttle arm? (looks like it and that's the way I read it) You need to get rid of that quick as it will wear out the hole in that phenelic (whatever you call it) throttle arm.
Any kind of ball and socket arrangement where the stud can be bolted solid to that throttle arm will work fine.
I'd take a pic of mine, but it's in the trailer. 30 degrees out and blowing like heck!
Hide Signatures
       Post #: 6398
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/18/2013 12:26 AM
triumphman49
Score: 110
Status: offline
Hi ARMODY,
Many folks attach a longer arm to the carb throttle arm . . . to give more resolution to the servo arm movement.
Is it "dying" on you, . . . or still hanging with the high idle? Know at one time you considered changing to a RcExl ignition.
T-man49 in Al
Hide Signatures
(in reply to 757jonp)
       Post #: 6399
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 2/18/2013 1:41 AM
rebranger
Score: 100
Last Login: 4/25/2013
Status: offline
Did you leave the throttle return spring on?
Best Regards
Ed
Hide Signatures
       Post #: 6400
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.734RCU1
