RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2010 2:58 PM
the pope
Score: 101
Last Login: 5/25/2013
Status: offline
quote:
ORIGINAL: tonyob
quote:
I like my coffee like my women, blond and sweet.
I prefer my coffee just like the way I like my women: strong, black, bitter, ground up and in the freezer!
Now thats just sick. In fact so sick that your more than welcome to head south to S.A. the murder capital of aus.Theres always room for one more. Cheers the pope
Hide Signatures
(in reply to tonyob)
       Post #: 101
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2010 5:56 PM
over-g
Score: 100
Last Login: 5/14/2013
Status: offline
I am just hoping to fit everything inside the cowl. This smaller engine looks to have alot of spunk and i think I will be able to fit everything inside. Hope to cut one hole and that is for the exhaust exit hole and maybe a small one for the plug wire cap.
Hide Signatures
(in reply to raptureboy)
       Post #: 102
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2010 9:14 PM
karolh
Score: 310
Last Login: 5/26/2013
Status: offline
quote:
ORIGINAL: Whistling Death
Wow that little engine was throwing that plane all over the place. I LMAO when Jody was flipping the plane end over end.
What is that end over end manoeuvre that Jody was doing called.
Karol
_____________________________
When inverted always remember that down is up and visa versa
Hide Signatures
(in reply to Whistling Death)
       Post #: 103
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2010 9:39 PM
AA5BY
Score: 153
Status: offline
Over-g... just remember to allow about three times more air exit than intake to a cowl to adequately cool the engine and avoid pressure issues that upset the carb metering.
Hide Signatures
(in reply to karolh)
       Post #: 104
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2010 9:51 PM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: karolh
What is that end over end maneuver that Jody was doing called.
Karol
I think it was to see if a end over end maneuver could kill the engine....well it sure did not kill the engine.   A good test to see what effects such a maneuver would have on the DLE20 engine.   Besides that...looks like a lot of fun!!!!   Capt,n
I never met a engine I did not like !
Hide Signatures
       Post #: 105
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2010 10:55 PM
mpascual
Score: 115
Last Login: 12/27/2012
Status: offline
quote:
ORIGINAL: captinjohn
quote:
ORIGINAL: mpascual
Today i've received mine for test purposes.
Side by side with a DLE30 it seems a very small engine.
And is lighter than the OS 120AX !!!!! (both with stock muffler) but i'm thinking in the tank size for this DLE20 ..... and for the AX .....
Are you going to put the test on YouTube?    Thanks  Capt,n
Yes , this week-end i will test my unit.
Regards
Hide Signatures
(in reply to captinjohn)
       Post #: 106
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2010 11:52 PM
over-g
Score: 100
Status: offline
quote:
ORIGINAL: AA5BY
Roger that AA5BY. I always cut a fairly large hole for the exhaust and the Jug has a decent opening all the way around between the fusalage and cowl. Thanks for the info, always appreciated
Hide Signatures
(in reply to AA5BY)
       Post #: 107
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2010 11:55 PM
victorzamora
Score: 134
Last Login: 5/12/2013
Status: offline
What oil ratio is required for this puppy?  Would Pennzoil at 40:1 be good enough, or does it require tons of oil (like the Saito FG's)?
PSI'm not starting an oil discussion, I just meant it as an example.
Tact is for people not witty enough to use sarcasm.
Hide Signatures
(in reply to P-51B)
       Post #: 108
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/20/2010 11:57 PM
w8ye
Score: 318
Status: offline
It uses the same oil ratio as the DLE30
Break in Pennzoil 32:1 . . . . .
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to victorzamora)
       Post #: 109
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2010 12:07 AM
SkyPilot101
Score: 125
Status: online
ooks llllike a must have replacement for my 20cc rcgf / aerovatt ..... damm. When are they gonna be ready?
Hide Signatures
(in reply to w8ye)
       Post #: 110
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2010 12:12 AM
victorzamora
Score: 134
Status: offline
Good to hear.  I wanted the Magnum .52G until I found out it required high oil ratios.  I just want to carry around one can of gas.
quote:
ORIGINAL: w8ye
Hide Signatures
(in reply to w8ye)
       Post #: 111
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2010 12:46 AM
Whistling Death
Score: 150
Status: offline
quote:
ORIGINAL: victorzamora
If you are like me you still have two cans of gas. One with breakin gas and one with everyday gas.
Blake
CORSAIR Brotherhood Lucky #13
Hide Signatures
       Post #: 112
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2010 12:53 AM
victorzamora
Score: 134
Status: offline
Well, that might end up being the case...but keeping one "set" of mixtures (32:1 and 40:1) would still be easier than keeping two "sets" of mixtures (4 cans total).  I'm hoping to be able to rid my dad of his glow fuel habit.  Also, I'd only keep a 1Gal jug of break-in as opposed to my 2Gal jug of regular stuff.  Right now I've only got one gasser (DLE55), but if that number starts rising I might have to get a 5Gal jug.  If the DLE20's are priced well, I might need to look for a 5Gal jug and keep my 2Gal as break-in fuel.
I'm setting up my girlfriend's 40-sized trainer as electric right now, I can't wait to get both my dad and I completely out of glow!!
Hide Signatures
       Post #: 113
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2010 12:56 AM
jedijody
Score: 309
Last Login: 1/15/2013
Status: offline
The DLE20 has roller bearings on both ends of the connecting rod but, it spins a relatively large prop for it's size at pretty high RPM compared to it's big brothers and even though the big end of the rod is directly in front of the reeds, high RPMs can reduce the amount of oil exchange through the bearing.
I strongly recommend following DLE's oil ratio recommendations which will be, as in all their engines 30/32:1 minimum no matter what oil you choose to use. I run 32:1 in everything all the time.
< Message edited by jedijody -- 7/21/2010 2:07 AM >
Now go outside and play
Hide Signatures
       Post #: 114
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2010 1:43 AM
Antique
Score: 557
Last Login: 3/21/2012
Status: offline
DLE knows what works..Oil experts might want to follow suit.....
RC Ignition
Hide Signatures
(in reply to jedijody)
       Post #: 115
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2010 3:58 AM
captinjohn
Score: 247
Status: offline
OK...for those wiz- kids, if a person takes 4 oz of oil & mixes it to 9/10 (.90) of a gallon of gas...what ratio do you end up with?   Capt.n
Hide Signatures
(in reply to Antique)
       Post #: 116
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2010 4:05 AM
Whaleflyer
Score: 100
Last Login: 2/20/2013
Status: offline
about 28:1 ??
Hide Signatures
       Post #: 117
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2010 4:13 AM
Edwin
Score: 156
Status: offline
Watching this closely. I also need a replacement for my rcgf 20cc.
Edwin
Hide Signatures
(in reply to Whaleflyer)
       Post #: 118
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2010 4:26 AM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: Whaleflyer
about 28:1 ??
How about 4oz oil to .95 gallon of gas?   Capt,n   I use that most the time!!!!
Hide Signatures
       Post #: 119
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2010 5:06 AM
gboulton
Score: 773
Status: offline
quote:
ORIGINAL: jedijody
Jody, can we organize a movement to copy/paste this into every oil/mixture jihad that comes up in the future?
¡ǝʌısuǝdxǝ sı dn puɐ dn sı uʍop ''pǝʇɹǝʌuı puɐ ʍo1 uǝɥʍ
Hide Signatures
       Post #: 120
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2010 7:17 AM
michaelchow
Score: 105
Last Login: 5/24/2013
Status: offline
Hi Mr.Jody,
My name is Michael chow, JBA model engine company,  I met Mr. Tom in Beijing model fair this year, and Mr.Tom imported J15G from my company, did you do any test for J15G.
thanks!
michael
Hide Signatures
(in reply to P-51B)
       Post #: 121
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2010 7:20 AM
michaelchow
Score: 105
Status: offline
Hi Jody,
My friend made some vedio of J15G, and try to re-made the J15G to install on Align600N. please visit the website.
http://v.youku.com/v_show/id_XMTg3NjgxMjQ0.html
  http://v.youku.com/v_show/id_XMTg3NjkzNzI4.html
  http://v.youku.com/v_show/id_XMTg3Njk5MDEy.html
  http://v.youku.com/v_show/id_XMTg3NzEzODI0.html
  http://v.youku.com/v_show/id_XMTg3NzA1MTQ0.html
maybe you can give me any advice.
thanks!
michael
Hide Signatures
(in reply to michaelchow)
       Post #: 122
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2010 9:05 AM
hairy46
Score: 183
Status: offline
W8YE, Thank you so much for all your great and thought out answers! I always read your comments and also follow them closely, Always a pleasure! Yes 32/1 sounds right to me, I have heard some say 100/1 50/1 just does not sound right to me! oil is oil some better then others but an engine does not care if its good or great oil but it does care if there is enough to lube it proper! An improper lubed engine will fail! All my engines ice auger weedeaters etc, get 32/1
My doctor told me I would need allot more therapy, So I bought more planes!
Hide Signatures
(in reply to w8ye)
       Post #: 123
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2010 9:29 AM
w8ye
Score: 318
Status: offline
I'm a 32:1 man myself in everything except my gas Saitos and they are 20:1
Original AMA #31261
Hide Signatures
(in reply to hairy46)
       Post #: 124
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/21/2010 9:36 AM
hairy46
Score: 183
Status: offline
No gas Saito's yet, but if when, I will keep that in mind! Thanks!
My lady said she would take a plane back to her mothers if I bought another War-bird, Two of the prettiest take offs I have ever seen!
Hide Signatures
(in reply to w8ye)
       Post #: 125
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.266RCU1
