RE: PeakModel Sbach 300 30cc Build thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: PeakModel Sbach 300 30cc Build thread
Page: <<   < prev  1 2 3 4 5 [6]
Login
RE: PeakModel Sbach 300 30cc Build thread - 3/10/2012 5:21 PM
vfalcon7
Score: 100
Last Login: 9/12/2012
Status: offline
Thanks George
Hide Signatures
(in reply to GEORGE_32)
       Post #: 126
RE: PeakModel Sbach 300 30cc Build thread - 1/1/2013 3:33 AM
jeffk464
Score: 100
Last Login: 5/23/2013
Status: offline
So what was the final verdict on this plane?
Hide Signatures
(in reply to JOHNS3D)
       Post #: 127
RE: PeakModel Sbach 300 30cc Build thread - 1/1/2013 4:52 AM
49dimes
Score: 100
Last Login: 5/21/2013
Status: offline
Good Flying plane. Peak models and sds hobby customer support is improving. Prices are going up too.
Hide Signatures
(in reply to jeffk464)
       Post #: 128
RE: PeakModel Sbach 300 30cc Build thread - 1/4/2013 3:30 AM
jeffk464
Score: 100
Status: offline
quote:
ORIGINAL: 49dimes
Will up pull out of a hover easily with the DL35RA?
Hide Signatures
(in reply to 49dimes)
       Post #: 129
RE: PeakModel Sbach 300 30cc Build thread - 1/4/2013 3:39 AM
49dimes
Score: 100
Status: offline
The DLE 35RE should have most impressive performance in this airframe. Pull outs, no problem with the DLE. I was using an MLD 35 with a 20x8 Xoar prop and the performance was spectacular. The new DLE should be just as good if not better!
Hide Signatures
       Post #: 130
RE: PeakModel Sbach 300 30cc Build thread - 1/4/2013 8:36 PM
jeffk464
Score: 100
Status: offline
Cool thanks for the info, one more thing. The site doesn't list the servo requirements, what size and torque servos are needed for it? I got the impression that it is cut for standard size servos but that they need to be metal gear and around 120oz torque, which is typically pretty expensive.
Something like this?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXYZW9&P=0
or cheaper non digital
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=002154980&I=LXANT5&P=K
Hide Signatures
       Post #: 131
RE: PeakModel Sbach 300 30cc Build thread - 1/5/2013 5:23 AM
nitro wing
Score: 125
Last Login: 5/22/2013
Status: online
I wouldnt put any Tower brand servos in it.
Hitec may have a few good choices too.
Hide Signatures
       Post #: 132
RE: PeakModel Sbach 300 30cc Build thread - 1/5/2013 4:53 PM
ROBCAR
Score: 100
Last Login: 5/15/2013
Status: offline
I wonder if this is the same exact plane that nitroplanes.com sells? They are advertising the 30cc sbach for $239 plus shipping but with a discount code and shipping comes to about $252 shipped to me here in NY. I see alot of 30cc sbachs for sale under different names. Just wondering if the nitroplanes version is the same as the 350-400 dollar versions?
Hide Signatures
       Post #: 133
RE: PeakModel Sbach 300 30cc Build thread - 1/5/2013 7:12 PM
49dimes
Score: 100
Status: offline
I do not know about the nitro planes but the peak model/sds hobby version comes from China toy and hobby company sxoingwan province (close to shanghai). This is the same area where the Pilot RC models are manufactured. There are a lot of quality ARF model manufacturers in China. As for servos for 30 cc airframes I would use metal gear 120 oz minimums. If your going to really do some hard 3d stuff 250 oz or better! Hobby king has a ton of quality servos at reasonable prices but be careful because they have a lot of cheap servos too. I personally have found the Blue Bird HV servos and Hobby King HV servos to rival or equal the Hitecs, Futabas and JR brands. If a servo is manufactured in Tiwain it is most likely very high quality. China servos suck.
Hide Signatures
(in reply to ROBCAR)
       Post #: 134
RE: PeakModel Sbach 300 30cc Build thread - 1/5/2013 10:39 PM
ROBCAR
Score: 100
Status: offline
I did notice the nitroplanes version has a glue in rear horiz stab where as the others have a 2 part bolt on stab with a tube. I prefer the tube.
Hide Signatures
       Post #: 135
RE: PeakModel Sbach 300 30cc Build thread - 1/6/2013 4:46 AM
jeffk464
Score: 100
Status: offline
quote:
ORIGINAL: ROBCAR
Do you happen to know what the discount code is? Based on the description it doesn't appear to be the same plane. The peak version has carbon fiber wing tubes and landing gear where the nitro planes has aluminum.
Hide Signatures
       Post #: 136
RE: PeakModel Sbach 300 30cc Build thread - 1/6/2013 3:57 PM
ROBCAR
Score: 100
Status: offline
discount code is "pricepickle" .....Gives you 6% off which helps a little. By time shipping is is added there is almost a $100 difference in the price of the 2 planes. The nitroplanes version was about $252 shipped to me here in NY. With the discount applied. I am not sure which one to get. I dont care about wingtube material but like the plug in stab in the peak/sds hobbies vesion versus the glue in. Also nitroplanes only has orange and green.
Hide Signatures
       Post #: 137
RE: PeakModel Sbach 300 30cc Build thread - 1/17/2013 6:41 AM
Planeclothes
Score: 104
Status: offline
quote:
ORIGINAL: nitro wing
Both the Tower TS-70 and Hobbico CS-70 are Hitec 645s. Look at the specs, I have used all three.
_____________________________
I'm only in it for the money...
Hide Signatures
(in reply to nitro wing)
       Post #: 138
RE: PeakModel Sbach 300 30cc Build thread - 1/17/2013 7:18 AM
nitro wing
Score: 125
Status: online
could be a good copy, specs dont mean crap though.
A dodge 2.5 engine is not the same a Lexus 2.5 engine for example, same specs..or close.
Possibly same components in servos, I just dont bother buying much generic copied stuff. Although I am guilty of buying from HK sometimes..Ok several times..
Hide Signatures
(in reply to Planeclothes)
       Post #: 139
RE: PeakModel Sbach 300 30cc Build thread - 1/17/2013 7:42 AM
49dimes
Score: 100
Status: offline
Buying from HK !?.... Well, Guilty too. But I tell you The Blue Bird servos are pretty good! The BLS 3114 and 2209 digitals are about 90 bucks each with shipping and I would stand them against the futaba BLS157 and 152 (190 each...ouch!!!) all day long. I fly them in my 50cc and 100cc air frames. Will probably post a build on the 104 inch extreme flight extra (BLS 3114 all around).
Hide Signatures
       Post #: 140
RE: PeakModel Sbach 300 30cc Build thread - 1/18/2013 7:26 PM
Planeclothes
Score: 104
Status: offline
Hey, I told you I have all three. It IS the same servo, same gears, same electronics, same motor, and it IS made by Hitec, period.
Hide Signatures
       Post #: 141
RE: PeakModel Sbach 300 30cc Build thread - 1/22/2013 5:26 PM
jeffk464
Score: 100
Status: offline
quote:
ORIGINAL: Planeclothes
Yeah, it was my understanding that hobbico and Hitecs were the same.
Hide Signatures
       Post #: 142
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.313RCU1
