help with f-18 plug
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> help with f-18 plug
Page: <<   < prev  1 [2] 3   next >   >>
Login
help with f-18 plug - 8/4/2003 2:50:45 AM
corey-RCU
Status: offline
Thanks Mark can't wait to test it! Ted, this was how I thought it was done but it seems there are many ways to do it, I'll try some different ways and see what works best for me.
(in reply to corey-RCU)
       Post #: 26
help with f-18 plug - 8/16/2003 12:43:03 AM
corey-RCU
Status: offline
I figure I would post some pics of what I have so far, I need to do my wings and tail feathers before I do anymore on the plug. My two hatches are already covered in cloth.
       Post #: 27
help with f-18 plug - 8/18/2003 8:27:19 PM
corey-RCU
Status: offline
Here are the pics.
Click to see fullsize image.
Click for fullsize
< Message edited by corey-RCU -- Aug 18 2003 3:37PM >
       Post #: 28
help with f-18 plug - 8/18/2003 8:38:17 PM
corey-RCU
Status: offline
pic 2
Click for fullsize
       Post #: 29
help with f-18 plug - 8/18/2003 8:39:10 PM
corey-RCU
Status: offline
pic 3
Click for fullsize
       Post #: 30
help with f-18 plug - 8/18/2003 8:40:08 PM
corey-RCU
Status: offline
pic 4
Click for fullsize
       Post #: 31
help with f-18 plug - 8/18/2003 8:41:05 PM
corey-RCU
Status: offline
pic 5
Click for fullsize
       Post #: 32
help with f-18 plug - 8/18/2003 8:41:54 PM
corey-RCU
Status: offline
pic 6
Click for fullsize
       Post #: 33
Re: Plugs - 8/18/2003 8:42:30 PM
Johng
Status: offline
[QUOTE]Originally posted by Mike James
Automotive primers are great, but you can use something like "Pactra Prep" early in the game. At the end, just prior to making plugs, is where I'd spend the money on the best lacquer-based primer I could afford... something that dries as hard as possible. ("Duratec" for example)
[/QUOTE]
Hey mike, I just looked at the duratec web site and all their stuff seems to be vinyl ester or polyester based. Isn't that risky on a foam plug? Or am I not seeing a laquer based product of theirs?
_____________________________
John
       Post #: 34
help with f-18 plug - 8/18/2003 8:42:49 PM
corey-RCU
Status: offline
pic 7 and last one for now.
Click for fullsize
       Post #: 35
F-18 Plugs - 8/19/2003 4:45:29 AM
Mike James
Status: offline
Corey,
Yeah, man. The plugs are looking good! Are you pretty close to making molds?
JohnG,
You're right. I'd only use the Duratec at the end, which means it would be going over either epoxy or polyester. (no exposed foam)
Mike James
RC Design and Building - www.nextcraft.com
       Post #: 36
help with f-18 plug - 8/19/2003 5:31:12 AM
scole
Status: offline
Damn! That looks awesome! How did you make that plug? I am going to start a SuperHornet about that same size. What did you use as a reference?
       Post #: 37
help with f-18 plug - 8/19/2003 5:45:04 AM
Johng
Status: offline
THat does look sweet. I'm about to fly a 1/10 scale hornet myself...been saying that for the better part of a year... :
One way to keep the hatches and the rest of the fuse plug "matched" while you finish the glassing, would be to add the same layers of glass to the hatch plugs that you do to the main plug. THen the buildup thicknesses would be the same and the edges should sand to match.
John
       Post #: 38
Plug - 8/19/2003 9:37:12 AM
TGoodwin
Status: offline
Looking good! Is that a Toki .18 or the OS unit?
Ted
       Post #: 39
help with f-18 plug - 8/19/2003 8:18:19 PM
corey-RCU
Status: offline
Thanks guys, I need my wings and tail feathers before I can finish the fuse plug, I can't seen to find the time to order the cores...I will soon. Do you guys know of a good place to get the cores? Ted, it is the Toki .18. I modifyied a set of plans I had to build the hornet.
