RE: Where are the 40cc Gas Engines???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: Where are the 40cc Gas Engines???
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: Where are the 40cc Gas Engines??? - 7/8/2012 9:13 PM
rica1
Score: 100
Last Login: 5/22/2013
Status: online
I'm looking for a very reliable 40cc range eng that is light and strong for a 14 to 15lb plane for aerobatics and 3D. Any opinions? or just go to 50cc and have it somewhat over powered?
Hide Signatures
(in reply to Scota4570)
       Post #: 51
RE: Where are the 40cc Gas Engines??? - 7/9/2012 5:16 AM
grossy2
Score: 100
Last Login: 5/21/2013
Status: offline
You have tha CRRC Pro GF40 Kit. It's a kit, so you can check all the bits on assembly. Swap out the CDI for an Rcexl and you have a reliable engine.
Hide Signatures
(in reply to rica1)
       Post #: 52
RE: Where are the 40cc Gas Engines??? - 7/9/2012 8:00 AM
rica1
Score: 100
Status: online
Grossy2,
I'll look into the CCRC Pro GF 40 then. What's the cost on the Rcexl ign? I don't mind putting it together if it's good quality and reliable. Thanks
Hide Signatures
(in reply to grossy2)
       Post #: 53
RE: Where are the 40cc Gas Engines??? - 7/9/2012 2:32 PM
ghoffman
Score: 163
Status: offline
We have been running the Mintor 38 in a 78 Inch EF Extra and on a 71 inch AJSlick.  More power over a wider power band than the 30's and at 2.2 pounds it fits the bill for the mid size planes.
Hide Signatures
(in reply to rica1)
       Post #: 54
RE: Where are the 40cc Gas Engines??? - 7/9/2012 3:00 PM
jaka
Score: 158
Status: offline
Hi!
Have a look at the MVVS .40cc engine.
_____________________________
Jan Karlsson - Supplier MVVS Products
Hide Signatures
(in reply to rica1)
       Post #: 55
RE: Where are the 40cc Gas Engines??? - 7/9/2012 3:53 PM
MTK
Score: 203
Status: online
quote:
ORIGINAL: rica1
Rica,
I am looking to sell my Mintor 38. It is not quite broken in yet with less than 1 1/2 gallons through it, maybe 20 runs. PM me if intrested....I'll make you a good deal.
It is an excellent sport motor, with easy field manners. It doesn't quite fit in my plane's nose so its relegated to pretty paper weight status rightnow
Regards,
MattK
Hide Signatures
(in reply to rica1)
       Post #: 56
RE: Where are the 40cc Gas Engines??? - 7/9/2012 5:20 PM
rica1
Score: 100
Status: online
Ghoffman, Will the Mintor 38 allow for 3D on a 14-15lb plane? Also, I think I would like the rear carb for better clearance. I will look into the Mintor as well. It has to have a reliable reputation so I can spend more time flying than troubleshooting! Don't want the reliable Zenoah 38 as it is heavy, would prefer the lighter small case engines.
Jaka, I have heard good things about the MVVS engs. I will look into the specs on it.
I'm doing some comparison research right now. I saw a new PTE 36cc advertised (looks good), light weight, rear carb, supposed to be good quality. I will look at reviews after comparing specs.
I have two 14-15lb and one 12.5lb planes that I would like to be able to interchange engs for convenience (mounting), gas mix, tune ability, parts needed etc if possible so I don't have to have to many different engines, rather than a different eng for each plane. I may get two or three (same) engs for these size planes. I have a couple 50cc planes that I already have 50cc engs for.
I appreciate the input, so feel free to give opinions.
MTK, I'll let you know if interested in your engine. Thanks, Rick
Hide Signatures
(in reply to MTK)
       Post #: 57
RE: Where are the 40cc Gas Engines??? - 7/10/2012 6:02 AM
grossy2
Score: 100
Status: offline
HI Rica.
Rexl CDI's are not overly expencive. Check out SDShobby, they can help you out.
If you were in Aust, I would be able to help you.
Cheers
Grossy
Hide Signatures
(in reply to rica1)
       Post #: 58
RE: Where are the 40cc Gas Engines??? - 7/10/2012 7:16 AM
rica1
Score: 100
Status: online
Grossy,
Thank you for the input on SDSHobby. I looked for the ignition but didn't find it. They do have a very large site and may need to look harder. Rick
Hide Signatures
       Post #: 59
RE: Where are the 40cc Gas Engines??? - 7/11/2012 5:43 AM
grossy2
Score: 100
Status: offline
Search under Rcexl. They have diffrent CDI's to suit diffrent size spark plugs. I think the Cap size for the GF40 Kit is 14mm. You will also need to replace the Hall sensor, for the orginal CRRC one will not work with a Rcexl CDI.
Cheers
Hide Signatures
(in reply to rica1)
       Post #: 60
RE: Where are the 40cc Gas Engines??? - 7/11/2012 7:17 AM
rica1
Score: 100
Status: online
Ok, I will need to check the price and compare how expensive with the eng and added ignition total cost. Maybe DA or DLE will come out with a 40cc?!
Hide Signatures
       Post #: 61
RE: Where are the 40cc Gas Engines??? - 7/11/2012 1:30 PM
kmeyers
Score: 125
Status: offline
A seller here on RC universe sells the CRRC 40 kit with an RCEXEL ignition. Check it out
http://www.agaperacingandhobby.com/
Oops!
Hide Signatures
(in reply to rica1)
       Post #: 62
RE: Where are the 40cc Gas Engines??? - 7/11/2012 1:38 PM
ghoffman
Score: 163
Status: offline
DLE just came out with a 35 rear exhaust, and DA has a 35 out soon.
quote:
ORIGINAL: rica1
Hide Signatures
(in reply to rica1)
       Post #: 63
RE: Where are the 40cc Gas Engines??? - 7/11/2012 4:47 PM
rica1
Score: 100
Status: online
Kmeyers,
Agape looks like a great place to shop as they are a Christian organization and would be good to deal with. And the prices are very reasonable. I will keep them in mind in my comparison shopping. Thank you. Rick
Hide Signatures
(in reply to kmeyers)
       Post #: 64
RE: Where are the 40cc Gas Engines??? - 7/11/2012 4:59 PM
rica1
Score: 100
Status: online
ghoffman, good news on the DLE 35 and DA 35 coming out soon. These are going to be good possibilities and they both have a good reputation and DA has excellent customer service and warranty coverage.
Two of my 40cc size planes are built and have side carb and exhaust engs in them. I will check the dimensions on the rear carbs and exhaust engs and if they will fit, I think that will be better (more clearance). I appreciate all the good input. I will look for DLE 35 specs and reviews and see if I can get more info on the DA 35 coming out. Rick
Hide Signatures
(in reply to ghoffman)
       Post #: 65
RE: Where are the 40cc Gas Engines??? - 7/11/2012 8:31 PM
Whistling Death
Score: 150
Status: offline
quote:
ORIGINAL: ghoffman
quote:
ORIGINAL: rica1
Some of the know-it-alls that used to post here and have since left said this would never happen, well guess what?
Blake
CORSAIR Brotherhood Lucky #13
Hide Signatures
       Post #: 66
RE: Where are the 40cc Gas Engines??? - 7/11/2012 8:45 PM
ghoffman
Score: 163
Status: offline
I know, funny! I fly my DA-120 powered AJ Slick more than any other plane, because it is so reliable. I will buy a DA-35 in a heartbeat.
Hide Signatures
(in reply to Whistling Death)
       Post #: 67
MTK
Score: 203
Status: online
I didn't see anything like the posted pic on the DA website....Where did you see this info Gary?
Regards,
MattK
Hide Signatures
       Post #: 68
RE: Where are the 40cc Gas Engines??? - 7/11/2012 8:51 PM
ghoffman
Score: 163
Status: offline
I took that picture personally at the at the DA booth at the Toledo show, and spoke to them as well.
Hide Signatures
(in reply to MTK)
       Post #: 69
RE: Where are the 40cc Gas Engines??? - 7/11/2012 9:05 PM
rica1
Score: 100
Status: online
Any info from DA as to when in the Summer? If soon, it would be worth waiting for. Would like to hear specs (prop sizes) and review. Hope it comes with 4.8 to 8.4 voltage ignition. Rick
Hide Signatures
       Post #: 70
RE: Where are the 40cc Gas Engines??? - 7/11/2012 9:18 PM
earlwb
Score: 584
Status: offline
In my opinion the 40cc engine displacement size is being squeezed out by the 35cc,36cc engine on the lower end and the 50cc, 55cc, 56cc and 60cc engines on the other side. A 40cc engine tends to weigh about the same as a 50cc engine too. Then the 35cc size engines tend to have about the same if not better performance than a 40cc engine has too. So it makes it tough to choose one nowadays. Fortunately there are still a few 40cc size engines around, but I expect them to all but disappear in the next couple of years.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to rica1)
       Post #: 71
RE: Where are the 40cc Gas Engines??? - 7/11/2012 9:31 PM
BOB MOORE
Score: 105
Last Login: 5/14/2013
Status: offline
What is the HP of a Quadra 42??
Hide Signatures
(in reply to earlwb)
       Post #: 72
RE: Where are the 40cc Gas Engines??? - 7/11/2012 9:44 PM
ghoffman
Score: 163
Status: offline
DA ignitions are totally different than the Rcexl.  I don't know about 8.4V (2S Lipo) but they certainly can do more than 6.0V.  In any case, I use the Tech-Aero IBEC on my DA-120 with no issues in ~165 flights.  The Tech Aero IBEC steps the 2S lipo to 5.2V, and the DA seems to really like that.
Hide Signatures
(in reply to BOB MOORE)
       Post #: 73
RE: Where are the 40cc Gas Engines??? - 7/11/2012 11:02 PM
apalsson
Score: 168
Status: offline
quote:
ORIGINAL: earlwb
This certainly used to hold true where for example the old JC Engines 40cc was basically a downsized 50cc (53cc) but weighed pretty much the same.
These days, there are a few offerings of true 40cc as mentioned above in this thread. Weight-wise, it varies greatly.
The MVVS 40cc (beam mounted) mentioned in a previous post weighs 1,451gram (without ignition while the 50cc weighs 1,560grams and the 30cc 930grams
I personally have a 40cc installed in a 96" Rearwin Speedster that I use for aero towing and have found towing 5 - 6m gliders no problem with that combination (on a 22x8 Mejzlik prop and stock muffler)
The tow plane weighs a tad over 7Kg
In comparison, the 30cc mentioned likes 18x10 props, the 40cc likes 22x10 props and the 50cc works well on 23x10 props
MVVS Australia
MVVS Engines, Mejzlik Props, Accessories.
www.mvvs-australia.com.au
Hide Signatures
       Post #: 74
RE: Where are the 40cc Gas Engines??? - 7/11/2012 11:57 PM
rica1
Score: 100
Status: online
I've heard A123's (6.6v) are ok with DA ignitions but don't think DA has stated that. I'm not familiar with the Tech-Aero IBEC but sounds like it's reliable and I'd like to look at that.
I have been using the Wike IBEF on two 40cc planes with no issues. They are adjustable from at least 5-6 volts. If we can get away from the regulators it will be one less thing that can go wrong. I hope DA will step up the voltage on their ign modules.
Hide Signatures
       Post #: 75
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: Where are the 40cc Gas Engines???
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
