RE: BOOMERANG ELAN - New Build & Setup Thread!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: BOOMERANG ELAN - New Build & Setup Thread!
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: BOOMERANG ELAN - New Build & Setup Thread! - 5/16/2011 7:40 PM
dalk
Score: 100
Last Login: 1/27/2012
Status: offline
Lost my boomerang topdeck in flight yesterday . deck popped off after 3min flying and wrapped itself around my leftwing leading edge .
I was on a downwind leg and managed to gain "control" just before impact and had another hair raising moment whilst turning onto baseleg .
I manage to gain enough height to clear a 8ft fence on finals and landed the puppy whilst still dragging the topdeck around much to the crowds delight including myself !
I have a video clip that I'm gonna try to post on u tube.
Hide Signatures
(in reply to petera38)
       Post #: 101
RE: BOOMERANG ELAN - New Build & Setup Thread! - 5/16/2011 9:44 PM
Lil Hoss
Score: 100
Last Login: 6/20/2013
Status: offline
Hi Dalk
Good job landing your Elan.......
Stupid question, But how did the canopy come off???
I have many flights on my Elan and I just maidened a new Elan a week ago and I never had a issue like that.
Can you please explain how it might have happened so I may prevent it from happening on my Elan.
Again,,,, Nice job on saving you jet
Hoss
_____________________________
Ahhhh Wisconsin, 3 months of Great Harley Riding 9 months of pretty good Harley Riding.........
Hide Signatures
(in reply to dalk)
       Post #: 102
RE: BOOMERANG ELAN - New Build & Setup Thread! - 5/17/2011 4:21 AM
gooseF22
Score: 103
Last Login: 6/13/2013
Status: offline
Its funny watching folks relearn the same ol lessons over and over... All the challenges folks are having in the build of this jet were documented in the LONG thread from before.. including the tank mount mods, and placement of the gear. I had to grind the crap out of mine. anyway, its a great jet and I miss mine...good luck. Im flying a kingcat now, so I cannot justify having the elan again.....yet...
Goose
Wren Turbines USA, Fromeco
Hide Signatures
(in reply to Lil Hoss)
       Post #: 103
RE: BOOMERANG ELAN - New Build & Setup Thread! - 5/17/2011 6:30 AM
dalk
Score: 100
Status: offline
http://www.youtube.com/watch?v=7-uvXKybLls
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 104
RE: BOOMERANG ELAN - New Build & Setup Thread! - 5/17/2011 6:41 AM
dalk
Score: 100
Status: offline
u can see the front part of the deck scraping the ground on landing and then straightens out .
The back of the deck sticks out next to the left boom .
my wheel is still missing though (lol) and my underpants !
i don't know if any other model would have made it back . GO BOOMERANG !!
on closer inspection of the deck fastener section it seems that only a small bead of epoxy was holding the plywood in place .
hope to find a deck soon and will certainly glass that section in GOOD.
Hide Signatures
(in reply to dalk)
       Post #: 105
RE: BOOMERANG ELAN - New Build & Setup Thread! - 5/17/2011 12:53 PM
Xairflyer
Score: 105
Last Login: 6/19/2013
Status: offline
You were lucky as well that the turbine did'nt set fire to it which may have then burnt the plane in flight!
Must get the owner to check the one I just built, and probably get him to add some extra glue
www.letterkennymodelflyingclub.com
www.jmaireland.com
Hide Signatures
(in reply to dalk)
       Post #: 106
RE: BOOMERANG ELAN - New Build & Setup Thread! - 5/17/2011 1:08 PM
Xairflyer
Score: 105
Status: offline
The Elan had a couple of successful test flights on Sunday, the conditions were far from ideal but it flew very well.
I set the CG on the main gear as everyone suggested and we had a couple of millimeters of up elevator trim in it when we landed so we shimmed the tailplane with a few washers for the second flight again as some others have been doing.
Due to the very blustery conditions it was difficult to trim it out properly but a good start made for the next day which will hopefully have better weather.
Came out 21½ lb with the P80 (kero start) and two 4 cell NiMh 5000mah batteries and the JC 2500mah Lipo.
Click for fullsize
Click for fullsize
Click for fullsize
www.jmaireland.com
Hide Signatures
(in reply to Xairflyer)
       Post #: 107
RE: BOOMERANG ELAN - New Build & Setup Thread! - 5/17/2011 1:16 PM
Xairflyer
Score: 105
Status: offline
Some additional pictures of during the build below I meant to add.
I drilled the flap horn lower down to give a better deflection, There is a ball link on the servo arm which allows it to go full travel without binding.
Also if you look I have fitted the kit supplied hinges closer to the top of the wing than the factory cut slot.
You have about 3mm gap between the flap and TE of wing when flap is up, but this setup gives me the near 90deg full down.
Colin from Boomerang Jets in the UK very kindly sent me some extra servo covers so I was able to fit a left and right elevator servo which I think is better. I then used a JR multibox to setup the elevators without having to use an extra channel.
Click for fullsize
Click for fullsize
www.jmaireland.com
Hide Signatures
       Post #: 108
RE: BOOMERANG ELAN - New Build & Setup Thread! - 5/17/2011 1:30 PM
Xairflyer
Score: 105
Status: offline
I used two 5000 4 cell NiMh packs and fitted them on top of the wheel wells with high grip velcro, I found best place for the ECU battery was on the intake floor, I could have mounted it under the tank try but at least at the intake you can get at it if it starts to smoke
On the other side I mounted the vent tank, I always fit these as they are great for preventing fuel from running out the vent pipe when you carry the model and also for preventing any excess fuel from ending up on the ground when filling the fuel tank.
Click for fullsize
Click for fullsize
www.jmaireland.com
Hide Signatures
       Post #: 109
RE: BOOMERANG ELAN - New Build & Setup Thread! - 5/17/2011 7:19 PM
jblloyd
Score: 100
Status: offline
Mystery part - does anyone know where this is suppose to go??
Click for fullsize
Hide Signatures
       Post #: 110
RE: BOOMERANG ELAN - New Build & Setup Thread! - 5/17/2011 7:27 PM
steve2972
Score: 100
Status: offline
quote:
ORIGINAL: jblloyd
Goosef22-don`t say anything !
Hide Signatures
(in reply to jblloyd)
       Post #: 111
RE: BOOMERANG ELAN - New Build & Setup Thread! - 3/22/2012 4:53 PM
mjunior
Score: 103
Status: offline
Right tail boom misalignment!
Have you guys faced this situation? If yes what did you do? I tried to force (boom and wing panel) but the final assembly seems to be highly loaded.
Regards,
Mucio
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to steve2972)
       Post #: 112
RE: BOOMERANG ELAN - New Build & Setup Thread! - 3/23/2012 12:28 AM
BaldEagel
Score: 118
Last Login: 6/18/2013
Status: offline
Over the life span of the Elan there have been a lot of problems with the boom ailgniment and the ali rods, but this is the worst miss ailgniment I have seen on one, how is the ailgniment without the boom in place? if that is OK it could just be the boom holes that are out, if so you could ream them out and Hysol some ply disc's inside the boom to compensate then make good on the surface, if its the wing tubes then a replacement wing is the only option.
Most have found that the ali rods need to be Hysoled in place to prevent the tail from changing incidence during flight, on the ground this can manifest itself by being able to move the tail up and down by up to three inches.
Hope this helps.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to mjunior)
       Post #: 113
RE: BOOMERANG ELAN - New Build & Setup Thread! - 3/23/2012 2:42 AM
mjunior
Score: 103
Status: offline
quote:
ORIGINAL: BaldEagel
Hope this helps.
Mike
Mike
Just checked alignment without the boom. Looks very good. I will try to work in the boom tubes position, ream them or even remove and bonding them again in the right position.
Mucio
Hide Signatures
(in reply to BaldEagel)
       Post #: 114
RE: BOOMERANG ELAN - New Build & Setup Thread! - 3/23/2012 7:17 AM
steve2972
Score: 100
Status: offline
The Elan is a great deisgn/looking Jet,but the quality of the Kit lets it down.
Hide Signatures
       Post #: 115
RE: BOOMERANG ELAN - New Build & Setup Thread! - 3/23/2012 11:05 AM
BaldEagel
Score: 118
Status: offline
quote:
ORIGINAL: jblloyd
If I remember correctly that is a doubler for the rear tank former between the wheel wells.
Mike
Hide Signatures
       Post #: 116
RE: BOOMERANG ELAN - New Build & Setup Thread! - 3/23/2012 2:28 PM
BaldEagel
Score: 118
Status: offline
quote:
ORIGINAL: mjunior
quote:
ORIGINAL: BaldEagel
Hope this helps.
Mike
Mike
Mucio
Before you move or ream out the main spar hole, check to make sure its not just the ali dowels that are causing the problem, assemble the wing and boom without them and see how the fit looks.
Mike
Hide Signatures
       Post #: 117
RE: BOOMERANG ELAN - New Build & Setup Thread! - 3/23/2012 5:04 PM
mjunior
Score: 103
Status: offline
quote:
ORIGINAL: BaldEagel
quote:
ORIGINAL: mjunior
quote:
ORIGINAL: BaldEagel
Hope this helps.
Mike
Mike
Mucio
Mike
The trial I did was with the main carbon spar and the aluminum sticks all installed and the assembly was good. Also the main spar hole looks good. I think the problem is in the ali rods and I will not do anything in the main spar hole.
Mucio
Hide Signatures
       Post #: 118
RE: BOOMERANG ELAN - New Build & Setup Thread! - 4/4/2012 1:44 PM
mjunior
Score: 103
Status: offline
I've got a new boom from Boomerang Jets (thanks to Colin) end now everything is ok.
Some pictures.
Mucio
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 119
RE: BOOMERANG ELAN - New Build & Setup Thread! - 4/4/2012 2:23 PM
voodoodb
Score: 100
Last Login: 6/11/2013
Status: offline
Great News. Good Luck with it.
Hide Signatures
       Post #: 120
RE: BOOMERANG ELAN - New Build & Setup Thread! - 4/4/2012 2:43 PM
mjunior
Score: 103
Status: offline
Before to purchase the Elan I was afraid about not being a good decision to upgrade from my Sprint to an Elan (and instead to purchase a expensive scale model)
Now I saw it assembled I'm sure it was a very good decision to choose it.
It is real a nice looking aircraft and the overall construction quality is very good. All of these added to the sport flying characteristics makes me very excited to fly it soon and make it my all life jet model.
Thanks to Alan, Patricia, Colin and Dave
Mucio Viana
Brasil
Hide Signatures
(in reply to voodoodb)
       Post #: 121
RE: BOOMERANG ELAN - New Build & Setup Thread! - 4/4/2012 2:48 PM
Lil Hoss
Score: 100
Status: offline
You WILL NOT BE SORRY buying the Elan or any of the Boomerang jets.
They are a pleasure to fly
You made a GOOD choice
GOOD LUCK
Hoss
Hide Signatures
       Post #: 122
RE: BOOMERANG ELAN - New Build & Setup Thread! - 4/4/2012 7:20 PM
kimhey
Score: 100
Status: offline
I had a Sprint and sold it...could not forgive myself, and bought an Elan a few months later. Boomerang jets are a pleasure to fly, very stress free flying
One thing to consider: I used a P80se in both models,. My Sprint came out tail heavy (easy to move components to achieve correct CG). But my Elan came out very nose heavy, so much that my cockpit compartment is almost empty . Be prepared to mount the batteries far back, some puts the batteries over the wheel wells or even under the turbine (I am not to sure about how smart the latter is...).
In the end, I ended up adding 50gr at the end of each boom.
When hinging the flaps, make sure you get lots of deflection AND check that the flaps don`t bind in up position before gluing the hinges. I had to sand a bit on each flap to get a nice flush fit in the up position.
Full flaps on my Elan is close to 90 degrees deflection (so it is actually more like speed brakes than flaps).
The Elan flies similar to the Sprint, maybe slightly faster at full throttle. Slows down really nice on landings
Hide Signatures
       Post #: 123
RE: BOOMERANG ELAN - New Build & Setup Thread! - 4/4/2012 7:42 PM
mjunior
Score: 103
Status: offline
quote:
ORIGINAL: kimhey
Thanks for your comments kimhey
This really may be a problem since I will use a Wren 100 turbine. It is lighter than the P80.
Regards
Hide Signatures
(in reply to kimhey)
       Post #: 124
RE: BOOMERANG ELAN - New Build & Setup Thread! - 5/9/2012 12:51 PM
mjunior
Score: 103
Status: offline
Time to start working in a new jet.....
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by mjunior -- 5/22/2012 3:31 AM >
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.858RCU1
