Red Scholefield
FL, USA Status: offline
[QUOTE]Originally posted by lavneet While charging the nicad cells, the Triton manual says that after peak detection a top up trickle is given to the pack automatically. I have observed that after peak detection in charge mode, the display shows "End" rather than "Top". Is it still giving that trickle? I am confused because after the charging ends, the "mah" does not increase but the pack voltage increases steadily and slowly. [COLOR=blue]The trickle charge is only applied at charge rates above 1.0 amps, below that it is zero. Kind of dumb, but what do you expect for a smart charger? :-)[/COLOR] Strangely, in the triton, the discharge cut off voltage is automatically set at .8V/cell in the CYCLE mode. This cannot be manually set. Is this safe in general for battery packs.....esp if they are 6-8 cell packs? [COLOR=blue]The 0.8 volts/ cell cutoff is set when you use the Charge/Discharge or Discharge/Charge function. If you use only the Discharge function you can set it to whatever you want. 0.8 volts/cell however is OK for 6-8 cell packs discharged at C rate or above.[/COLOR] Cheers [/QUOTE]
_____________________________
Red S. AMA 951 Leader Member Disclaimer: What I have written here are my thoughts and in no manner shape or form reflect the views of RCU
