RE: Fliteskin Ta-152 H1    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Fliteskin Ta-152 H1
Page: <<   < prev  2 3 4 5 6 7 [8] 9 10 11   next >   >>
[Poll]
Fliteskin Ta-152 H1
Foam 2 piece wing.
  13% (14)
Built up 2 piece wing.
  24% (26)
Foam 3 piece wing.
  18% (20)
Built up 3 piece wing.
  43% (47)
Total Votes : 107
(last vote on : 2/26/2013 4:02 AM)
(Poll will run till: -- )
Login
RE: Fliteskin Ta-152 H1 - 7/31/2012 7:23 PM
JGrc
Last Login: 5/14/2013
Status: offline
Yes Casey, getting busier again... I think I will do green 9 probably..
_____________________________
Fliteskin is tougher than you think!
Hide Signatures
(in reply to glazier808)
       Post #: 176
RE: Fliteskin Ta-152 H1 - 8/1/2012 3:39 AM
JGrc
Status: offline
Aileron is built up with bottom skin and ribs laser cut.
After all the ribs are lined up with brass tube and piano wire going through I CA ribs to bottom skin, sand even with long T and glue top and leading edge strips to complete the sequence.
JG
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 177
RE: Fliteskin Ta-152 H1 - 8/1/2012 5:45 AM
pimmnz
Last Login: 5/18/2013
Status: offline
Just wondering, will you be doing the wing washout like the full size? Washed out 3 deg at the aileron inner rib, then maintaining this to the tip? It would give the characteristic 'kinked' trailing edge and make a pretty safe airplane at low speeds/ high AOA's. Just a thought...
Evan, WB #12.
Hide Signatures
(in reply to JGrc)
       Post #: 178
RE: Fliteskin Ta-152 H1 - 8/1/2012 6:21 AM
JGrc
Status: offline
Evan,
Yes the wing has 3 degree constant washout root to tip. The pics of the full size that Ive seen show straight trailing edge so I made it constant
JG
Hide Signatures
(in reply to pimmnz)
       Post #: 179
RE: Fliteskin Ta-152 H1 - 8/2/2012 3:11 AM
pimmnz
Status: offline
Ahh, OK. All my photos of the full size that show the wing T/E ALL show the 'karakteristik kink'. It is just so easily seen, once seen on one and is a part of the whole, like the U/C angle and length etc. I know most the 3 view drawings don't show it, but again, when compared to the photos...
Whatever, you still have a magnificent machine.
Evan, WB #12.
Hide Signatures
(in reply to JGrc)
       Post #: 180
RE: Fliteskin Ta-152 H1 - 8/2/2012 3:27 AM
invertmast
Status: offline
quote:
ORIGINAL: pimmnz
Evan, WB #12.
I never noticed this "kink" but after doing some research, it seems that there in-deed is a bit of a kink in the wing about 1/2 way out... These are the best photo's I could find of the so called "kink"
http://www.warbirdphotographs.com/LCBW5/FW190-V30-3.jpg
http://www.warbirdphotographs.com/LCBW/TA152-2.jpg
http://www.warbirdphotographs.com/LCBW/TA152-1.jpg
Jose... when can we expect to get our hands on some of these parts?
< Message edited by invertmast -- 8/2/2012 4:01 AM >
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
       Post #: 181
RE: Fliteskin Ta-152 H1 - 8/2/2012 5:45 AM
JGrc
Status: offline
Evan, Thomas,
I see the little kink in one of the pics indeed. Very good information.
THese parts will be available as soon as I make sure everything builds right, and there are not major faults.
Thnks for heads up!
JoseG.
Hide Signatures
(in reply to invertmast)
       Post #: 182
RE: Fliteskin Ta-152 H1 - 8/2/2012 10:32 PM
pimmnz
Status: offline
Some more images, showing that even the Silver Hill 152 has a 'kinky' trailing edge. You can see under the wing of the compass swing airplane, that the 76 colour only covers the front half of the undersurface, and the rear part appears to be natural metal...so many variations...
Evan, WB #12.
Click to see the file in new window.Attachment.pdf
Hide Signatures
(in reply to JGrc)
       Post #: 183
RE: Fliteskin Ta-152 H1 - 8/2/2012 11:20 PM
JGrc
Status: offline
Here is the first glass fuselage and parts I just received.
Evan, do you have anypic with the flaps down?
JG
Click for fullsize
Hide Signatures
       Post #: 184
RE: Fliteskin Ta-152 H1 - 8/3/2012 12:07 AM
glazier808
Status: online
looks quite nice! What is the weight of the fuse, as is?
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
(in reply to JGrc)
       Post #: 185
RE: Fliteskin Ta-152 H1 - 8/3/2012 12:17 AM
pimmnz
Status: offline
I will look, but so far only two, both from the front so you can't see the flap inner construction. I would assume that they would be like the late model 'D' series wooden flaps, there is a report about the 152's wooden flaps being damaged on landing by water thrown up by the tyres. The Smithsonian web site has some photos of the 152 parts they hold, I believe there is a couple of photos of the flaps there. I will keep looking. The half painted wing undersurface does not seem to be uncommon, 152C 'CI+XM' shows the same thing, 152H 'CF+OY' and '150004' all show the same thing. Keep smiling!
Evan, WB #12.
Hide Signatures
(in reply to JGrc)
       Post #: 186
RE: Fliteskin Ta-152 H1 - 8/3/2012 5:27 AM
JGrc
Status: offline
Evan, you're right about othe wood flap construction, I just don't know how many ribs is using. Casey, fuse is about 5 to 6 lbs. as now.
JG
Click for fullsize
Hide Signatures
       Post #: 187
RE: Fliteskin Ta-152 H1 - 8/3/2012 5:31 AM
t_burley
Status: offline
cant wait for the first in line kit
Todd
Meister, Aero Acc., Sierra, Glennis, Get Stencils, Shinden, Warbird Colors, Fliteskin, VicRC, Holman, Bates custom
Hide Signatures
(in reply to JGrc)
       Post #: 188
RE: Fliteskin Ta-152 H1 - 8/3/2012 10:11 AM
pimmnz
Status: offline
JGrc, images of the Smithsonian flaps.
Evan, WB #12.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to t_burley)
       Post #: 189
RE: Fliteskin Ta-152 H1 - 8/3/2012 3:19 PM
JGrc
Status: offline
Thank you Evan, those photos are very rare. I did a search and I could not find any before. Looks like the flaps are open ribs construction.
JG
Hide Signatures
       Post #: 190
RE: Fliteskin Ta-152 H1 - 8/3/2012 4:45 PM
F4u5
Last Login: 5/17/2013
Status: offline
Edit....Ooops, I voted way back when Still interested in the product Jose
Jeff
Where''s my glue....I gotta build!
Spitfire Bro #108
Hide Signatures
(in reply to JGrc)
       Post #: 191
RE: Fliteskin Ta-152 H1 - 8/3/2012 6:09 PM
JGrc
Status: offline
whatta mean Jeff?
Hide Signatures
(in reply to F4u5)
       Post #: 192
RE: Fliteskin Ta-152 H1 - 8/3/2012 7:26 PM
vertical grimmace
Status: offline
I am excited about this as well. Looks great and will be awaiting availability.
Gonna have one at the Warbirds over the Rockies this year? I would love to see how it looks in person. Even if not finished.
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
(in reply to JGrc)
       Post #: 193
RE: Fliteskin Ta-152 H1 - 8/3/2012 7:45 PM
F4u5
Status: offline
Hey Jose,
Ha, I tried to vote for the 3 piece wing, but poll closed; then I found that I voted way back when and had forgotten. I edited so I didn't look AS dense
I always wanted to build the Andersen TA, but never got around to it. With you, Vic and Jeff Micko making all of these glass fuselages and parts available, it really cuts the build time, and makes it more plausable. I find that pumps the enthusiasm and is great new.
As Vert says, be nice to see one at WOTR.
Now if we could just get a Mossie fuse in 120 inch span
Jeff
Jeff
Spitfire Bro #108
Hide Signatures
(in reply to vertical grimmace)
       Post #: 194
RE: Fliteskin Ta-152 H1 - 8/4/2012 2:18 AM
pimmnz
Status: offline
JGrc, I know I'm a PIA, but shouldn't you ailerons be open frame, fabric covered?
Evan.
Hide Signatures
(in reply to F4u5)
       Post #: 195
RE: Fliteskin Ta-152 H1 - 8/4/2012 6:21 AM
JGrc
Status: offline
Ye, work permitting I'll be at WOR, with the project.
Jeff, the 3 piece wing is available. I added an additional lite ply rib to the laser file so you can make the split. An aluminum tube does the rest.
Evan, PIA is OK, makes me work harder. Yes the aileros should be open frame but they would be too fragile, so I use a balsa sheet with ribs on top that is fabric (solartex) covered.
JG
Click for fullsize
Hide Signatures
       Post #: 196
RE: Fliteskin Ta-152 H1 - 8/4/2012 10:52 AM
pimmnz
Status: offline
Clever.
Evan.
Hide Signatures
(in reply to JGrc)
       Post #: 197
RE: Fliteskin Ta-152 H1 - 8/5/2012 6:07 PM
JGrc
Status: offline
quote:
ORIGINAL: F4u5
Hey Jose,
Jeff
Hello Jeff,
Jeff
Why would you want a Mossie when you can fly the Hornet? Look up the specs http://fliteskin.com/DHHornet.html
JG
Click for fullsize
Hide Signatures
(in reply to F4u5)
       Post #: 198
RE: Fliteskin Ta-152 H1 - 8/6/2012 3:36 AM
F4u5
Status: offline
I am a Mossie lover...
Spitfire Bro #108
Hide Signatures
(in reply to JGrc)
       Post #: 199
RE: Fliteskin Ta-152 H1 - 8/17/2012 5:03 AM
JGrc
Status: offline
Gun Hood plug is ready for molding, it took much more time that I thought!! worth the effort though....
JG
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to F4u5)
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.781RCU1
