C30 exhaust diverter?
Tower Hobbies
Logged in as Guest
  Printable Version
Walkera 53#8!! 5G6-1. Nine Eagles Kestrel 500's - RTF
Seller:  travis@rchelizone.com
Details:   $165.00   |  11/9/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Kyosho Helicopters >> C30 exhaust diverter?
Page: [1]
Login
C30 exhaust diverter? - 7/26/2003 5:15:35 AM
mlcasmey
Status: offline
Anyone using an exhaust diverter in the C30 to get the oil mess going down instead of on everything aft of the motor?
Mike.
       Post #: 1
C30 exhaust diverter? - 7/27/2003 6:23:44 AM
randy41
Status: offline
Yes: I use one.
_____________________________
Randy
Caliber 30/OS 32 SXH
Futaba GV-1 govoner
Futaba Gyro 401/9402 Servo
(in reply to mlcasmey)
       Post #: 2
C30 exhaust diverter? - 7/27/2003 9:35:43 AM
Vortexgen
Status: offline
yep, me too.
       Post #: 3
C30 exhaust diverter? - 7/27/2003 11:24:07 PM
mlcasmey
Status: offline
Guys, thanks for the help. I really love the caliber. I've put a couple of tanks thru her hovering around and getting the linkage adjusted for a no trim required hover.
I do have two gripes. One is: How do you get fuel in and out of this tank without taking the body on and off all the time?. Have you run the fuel lines back behind the body to a fueling port of some kind? Second: How do you adjust the mixture without taking the body on and off?
Don't get me wrong, I love the look of the body, but I now see that it makes servicing and tuning very difficult.
Mike.
       Post #: 4
C30 exhaust diverter? - 7/28/2003 1:28:43 AM
randy41
Status: offline
I have been wanting to ask the same question.
I currently use a quick fueler. But i am still concerned
about it allowing air in the fuel system.
Maybe some of the guys [COLOR=red]Vortexgen,flyboy,davidj and
a few other experienced helli flyer's [/COLOR] will give us input
and maybe some pic would be nice.
I up graded to the FT body and it does allow a little more room
for adjustments and looks ok. one could modify the stock
canopy. Take alook at davidj photo gallery for his modified
stock canopy.
Randy
Futaba GV-1 govoner
       Post #: 5
My Caliber Canopy setup - 7/28/2003 2:47:45 AM
DHDaniel
Status: offline
I am temporarily using the stock canopy I did cut it down,
made life alot easier.
easy access to fuel and engine
Dave
Click to see fullsize image.
Click for fullsize
Caliber 30 OS32 Gy401 9c
Hawk Sport OS32 Gy401 9c
       Post #: 6
NO room - 7/28/2003 3:09:47 AM
Temps
Status: offline
heres mine and i also use a deflector but once you start hovering higher (out of ground effect ) itll stay a lot cleaner
Click for fullsize
Quattro/0/Floor/3/Trees/0/Water/5/
       Post #: 7
C30 exhaust diverter? - 7/28/2003 6:04:11 AM
davidj
Status: offline
Look in my gallery at the last pic. It shows the hole I cut the same size as the one for the exhaust. Since then I have cut the skirts off from the canopy to help reduce weight.
Kyosho NW Field Rep
       Post #: 8
C30 exhaust diverter? - 7/28/2003 7:09:30 AM
caliberdave
Status: offline
davidj, do you have a template of that smoked windsheild? That looks so much better than the decal. I painted mine but yours looks even better.
       Post #: 9
C30 exhaust diverter? - 7/28/2003 7:18:11 AM
caliberdave
Status: offline
       Post #: 10
C30 exhaust diverter? - 7/28/2003 7:32:37 AM
mlcasmey
Status: offline
Thanks guys. I just never occurs to me to modify something from the factory. I don't know what makes me think that every factory design is perfect. A couple of well placed holes would be perfect and easier than adding some complex plumbing.
David, the header tank looks great, did you make the bracket or use an existing one?
PS, what are the little yellow boots an the skids?
Burned another tank hovering today and only scared myself twice. It was hard enough learning to hover these things when I was sitting inside, and only 22.
Mike.
       Post #: 11
C30 exhaust diverter? - 7/28/2003 7:54:40 AM
davidj
Status: offline
The smoked windshield is a raptor 60 windshield. IT DOES NOT WORK. The servo arms contact the widshield. I did it and then found out it would not work. The header tank is from Heliproz and the yellow skid stops are rubber skid stops.
Kyosho NW Field Rep
       Post #: 12
fuel line problems - 7/28/2003 9:02:10 AM
shocker
Status: offline
heres the fix put a century hawk body on the caliber works prefect i did look in my gallery
< Message edited by shocker -- Jul 28 2003 4:09AM >
       Post #: 13
C30 exhaust diverter? - 7/28/2003 9:05:40 AM
MooseLoad
Status: offline
I took a allen bolt, cut off the head...a little JB weld onto the needle valve with a strategically cut hole in the fuse and I can access the needle valve with my wrench with ease (where the black gromet is on the fuse) ) As far as the plumbing, I simply put the header tank as far back on the frame as I could by attaching it with the tail support screw and using a KSJ filter...the fuel clip is barely inside the fuse and can also be easily accessed.
Everyone says the caliber is an ugly beast but personally I think it looks pretty cool...especially when I dress it up with my squadron patch :-)
Click for fullsize
       Post #: 14
C30 exhaust diverter? - 7/28/2003 9:06:17 AM
MooseLoad
Status: offline
Here is one without the canopy...
Click for fullsize
