Gabrielsande
Score: 115 Joined: 5/5/2009 Last Login: 6/12/2013 From: WokingSurrey, UNITED KINGDOM Status: offline
Right!, Again,at ground, all was good, nice idle and no hesitation at all,check rpm 9180 with the 17x6 apc ,kind of normal,batteries fully charged,on take of again the same hesitating,the running was very poor,and going quick to knife edge or pulling up sharply,it was almost quitting. This time I took with me a normal ni-mh 2600mah 6v battery, to try replacing the lipo+regularor /i was using to power the ignition,so I did,removed the regulator and lipo and installed the heavier ni-mh,just to see if was any lack of power at load from the regulator, despite was a 6v 3Amps,regulator it was a "turngy "cheap one. **at first I blamed the hesitation on knife edge due to gravity,but lerned it was because the engine is on full load on that attitude and spark struggled if a problem with the ignition/power** So started again for the second attempt and for my suprise, at ground the engine was far out of tune,it was idling very rough and quitting at full power, something to do with the regulator? I don't know,anyway tunned high and low end again, got it perfect (at ground) on take of it was almost perfect it missed just one stroke I could say, and flying was good, again it lost a bit of power going for the first knife edge,but after flying 2 minutes giving it some gas, it was getting better, and better, vertical lines were consistant,and knife edge very solid, I did noticed if slowing down for 1 minute flying slow a 1/4 of the gas and then giving full power,going up sharp or in to knife edge,still missing a couple of beats, but then goes ok, it seems like it does it when cool ,same like with glow engines,but if you keep throtteling up and down, and keep the engine warm it picks up instantlly. I had got here before if you look back on the thread at the same situation,let see if the next fly is not all over the place again!. So as it is Im happy with it, because that little miss time to time annoy me yes!, but the sound of that big four strokes goes over that fault!, I tried almost everithing, again before this replaced fuel lines for bigger ones,fuel filter,and the carb was taken apart cleaned (despite still new). Conclusion: I really would like to see more people having succes with this engine, I think they done a kind of mistake, mixing a walbro with a glow type barrel (plastic) carb, normal walbros are dead easy to set up,and they are 100% reliable,why they dont use a normal butterfly type walbro carb?? all my 2 stroke petrol engines dont have any issue at all once set from new, you never touch them, and they are really smooth through the whole throttle, and you will get more spares, I couldnt find a set of gaskets for this carb, from horizon you just get the base gasket thats it!. ********Just a guess based on observation, this barrel type carb looks like varies the mix, on the mechanical movement /adjustment of the barrel,getting the needlle in and out+ the vacuum generated on the venturi like glow ones, normal walbros depends on the jet next to the butterfly, and only based on the vacuum created depending on the butterfly position,so if you apply full power and the engine does not go up on rpm, because excesive load,the mix will be more accurate for that situation and probably the reason why these are so difficult to et right... anyway is just my guess******** I bet the next generation of petrol saitos will come with a standard walbro! Also sent few mails to horizon UK about this problems and asked them about getting a complete gasket set, they didnt reply,at least to tell me they received the e-mail, for the time being it looks like you have to buy a whole new carburattor if having problems, until some one starts stocking this gaskets/repair kit for the wyd carb. Yes you could fit a normal walbro with little modification,and also an other ignition, but at the end you are paying a lot for an engine you have to heavy modify to get a reliable running, when cheap chinese engines came set and tested, they run almost out of the box with no problems So lets see next time....
< Message edited by Gabrielsande -- 9/23/2010 12:36 PM >
Hide Signatures
