What does your Wood Pile look like?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> What does your Wood Pile look like?
Page: [1]
Login
What does your Wood Pile look like? - 8/9/2010 1:17 PM
thailazer
Score: 110
Last Login: 5/23/2013
Status: offline
Am wondering how other builders organize their sticks, bits, and sheets. Here's a photo of mine which I am sure is pretty modest when compared to most.
Click to see fullsize image.
Click for fullsize
_____________________________
Tiger Flyer #49
Hide Signatures
       Post #: 1
RE: What does your Wood Pile look like? - 8/9/2010 4:05 PM
beepee
Score: 109
Last Login: 5/22/2013
Status: offline
Mine is much less organized. I keep anything bigger than a postage stamp!
Bedford
Hide Signatures
(in reply to thailazer)
       Post #: 2
RE: What does your Wood Pile look like? - 8/9/2010 11:04 PM
sledderjw
Score: 100
Last Login: 10/9/2010
Status: offline
i go to swap meets and pick up airplane kits cheap............the last one i purchased was a sig kadet mk2 and it has alot of variety as far as balsa goes and you could never buy this much balsa for $50..........and if i don't have any major crashes through out the summer, i build the plane
Hide Signatures
(in reply to beepee)
       Post #: 3
RE: What does your Wood Pile look like? - 8/9/2010 11:05 PM
sledderjw
Score: 100
Status: offline
correction............$15 not $50
Hide Signatures
(in reply to sledderjw)
       Post #: 4
RE: What does your Wood Pile look like? - 8/9/2010 11:40 PM
GarySS
Score: 100
Status: offline
I use the long kit boxes, or boxes from balsa suppliers. They are labled as follows: Sheets, Sticks, Triangles, Hardwood Sticks, Leading edges, trailing edges, Good quality ply, and light ply. Then I've got a miscellaneous box with scraps of all sizes which I am constantly pawing through......
Hide Signatures
       Post #: 5
RE: What does your Wood Pile look like? - 8/10/2010 2:34 AM
John 38
Score: 100
Status: offline
For larger quantities of strip and sheet, I got a cardboard box that the local golfshop get golfsets delivered in. You can cut it down to 3 ft length or whatever suits. cheaper than buying a kit
Hide Signatures
(in reply to GarySS)
       Post #: 6
RE: What does your Wood Pile look like? - 8/10/2010 3:51 AM
WhiteRook
Score: 108
Status: offline
i have 3 different piles of wood in my basement, and 2 upstars . this scratch building has got to end
Hide Signatures
       Post #: 7
RE: What does your Wood Pile look like? - 8/10/2010 5:15 AM
tailskid
Score: 199
Last Login: 5/21/2013
Status: offline
I use old kit boxes...one for balsa stick and strips; another for sheeting; another for pushrods and the like, etc.
Click for fullsize
< Message edited by tailskid -- 8/10/2010 8:48 AM >
# 93 in Club Saito
Carl Goldberg Ultimate Brotherhood # 12
Hide Signatures
(in reply to WhiteRook)
       Post #: 8
RE: What does your Wood Pile look like? - 8/10/2010 6:47 AM
thailazer
Score: 110
Status: offline
I know how that goes! Years ago when I was heavy into scratch building, I'd find wood everywhere. Got in the bad habit of stuffing sticks up in the floor joist braces! Out of the way, but out of sight and mind as well!
Tiger Flyer #49
Hide Signatures
       Post #: 9
RE: What does your Wood Pile look like? - 8/10/2010 6:50 AM
vicman
Score: 189
Status: offline
After discovering three old kit boxes full of brand new wood (not in kit form) that was stashed I realized that wasn't the best storage method.
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
Hide Signatures
       Post #: 10
RE: What does your Wood Pile look like? - 8/10/2010 12:33 PM
beepee
Score: 109
Status: offline
Oh, the best redeeming value of an ARF ... a BIG box for storage or scratch-building wood.
Bedford
Hide Signatures
(in reply to vicman)
       Post #: 11
RE: What does your Wood Pile look like? - 8/10/2010 6:03 PM
scale only 4 me
Score: 314
Status: offline
+ another kit box user, I use kit boxes for monkote and long hardware, wire, nyrod erc. too
quote:
ORIGINAL: beepee
Bedford
If you have ARF boxes, you wouldn't need to store Balsa
Hide Signatures
       Post #: 12
RE: What does your Wood Pile look like? - 8/10/2010 7:37 PM
carrellh
Score: 179
Status: offline
quote:
ORIGINAL: thailazer
My pile is not huge. I have it flat on a table, some in an old kit box and some just on the table. I think having it on a fairly flat surface will keep it straighter than standing it on end but that may not be true.
quote:
ORIGINAL: GarySS
I use the long kit boxes, or boxes from balsa suppliers. They are labled as follows:.......
Gary, that's just wrong. Labels??? Everything needs to be in one totally disorganized mess.
- Carrell
Hide Signatures
       Post #: 13
RE: What does your Wood Pile look like? - 8/10/2010 10:39 PM
Edwin
Score: 156
Status: offline
Under the main work bench, and scrap on the other work bench.
Edwin
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to carrellh)
       Post #: 14
RE: What does your Wood Pile look like? - 8/11/2010 4:38 AM
ro347
Score: 335
Status: offline
I keep my wood in fedex tubes(triangular shaped). They are free.
Hide Signatures
(in reply to Edwin)
       Post #: 15
RE: What does your Wood Pile look like? - 8/11/2010 6:12 AM
vicman
Score: 189
Status: offline
I picked up an old blueprint cabinet at an auction and use it for my balsa and rod storage. I was lucky enough to score an old monokote rack and Master Airscrew prop rack from an LHS that closed it's doors. I would've scored a balsa rack if he had one but no luck. The cabinet works pretty well except for wing skins over 48" long.
Hide Signatures
(in reply to ro347)
       Post #: 16
RE: What does your Wood Pile look like? - 8/11/2010 7:12 AM
TedMo
Score: 100
Last Login: 8/23/2012
Status: offline
I built a rack with variuos size compartments that is attached to the ceiling beams. Used to do all scratch building so used lots of balsa so had compartments for each of the many sheet sizes . also have one similiar for Monocote. Have wood and Monocote some of which is from 40 years ago. Been building for 65 years now so not much I don't have. Guess I could say this is a hobby that can be very addictiveHa. I'm now 84 and still at it.
Hide Signatures
       Post #: 17
RE: What does your Wood Pile look like? - 8/11/2010 7:18 AM
vicman
Score: 189
Status: offline
Good show Ted.
Hide Signatures
(in reply to TedMo)
       Post #: 18
RE: What does your Wood Pile look like? - 8/11/2010 12:46 PM
beepee
Score: 109
Status: offline
You would know I need to keep balsa in my ARF boxes if you saw how I fly! I have built/assembled all types. Still building from bits of balsa is the most fun.
Bedford
Hide Signatures
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.407RCU1
