William Robison
Joined: 11/10/2002 From: Mary Esther, Florida, FL, USA Status: offline
wildhair: I'll bet you left the nose and nacelle blocks pretty think, didn't you? If it's not too late pop all the forward blocks off and cut a lot more out of the inside. If you can get them all down to 1/8" wall thickness you should be fine. Another way to decrease nose weight is using Tru-turn spinners. Expensive, but they are even lighter than the Du-Bro plastic ones. And the Du-Bro are lighter than most other metal spinners. If you can get the nose block off, look at the front former F1. Its ply, and you can cut a fair bit of it away without losing any amount of strength. Also the former F3 at the wing LE can be hollowed. Finally, at 4 3/4" CG with a weight of 9lb. 3oz. the plane should fly without a problem other than being a bit fast, and landing a little hot. If you have not hollowed the blocks too much, going back and doing it should give you another 1/4 inch on the CG all by itself, and at 5" CG you should have a nice flying plane. HTH. Bill.
_____________________________
Real Airplanes have Two Engines AMA 25139 - More than 40 years.
