Monokote on edge of firewall
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> Monokote on edge of firewall Page: [1]
Login
Monokote on edge of firewall - 4/8/2002 6:42:50 AM
lennyk
Status: offline
What's the best method to get the covering on the edge of the firewall stuck down real good so that it does not end up peeling when taking the cowl off or accidentally rubbing it etc ?
Lennard
       Post #: 1
Monokote on edge of firewall - 4/8/2002 7:09:33 AM
Vince
Status: offline
I generally overlap the firewall edge 1/4" to 3/8", just iron it down. I then rough up the overlap with steel wool, then seal the firewall with thinned epoxy, including the overlapped MoneyKote.
Vince
(in reply to lennyk)
       Post #: 2
Monokote on edge of firewall - 4/8/2002 7:44:00 AM
wgeffon
Status: offline
[QUOTE]Originally posted by Vince
Vince
[/QUOTE]
Yup....
_____________________________
Wayne
       Post #: 3
Monokote on edge of firewall - 4/8/2002 11:10:16 AM
Shortman
Status: offline
good idea, ill have to try that... i just painted over the monokote with the aeroglause or whatever its called stuff
Steven Carroll
AMA# 738035
       Post #: 4
Monokote on edge of firewall - 4/8/2002 9:14:56 PM
gpmikemorse-RCU
Status: offline
It may not be obvious from the previous posts, but the trick is to do the Monokote before you fuelproof the firewall.
       Post #: 5
Monokote on edge of firewall - 4/8/2002 11:35:28 PM
Gastronom-RCU
Status: offline
WE use thinned epoxy to fuel proof firewall, then sand down fine and apply monokote over entire firewall. Dril holes for mount, control rod, & fuel line, then add minimal amount of epoxy into/around drilled holes.
Works great.
       Post #: 6
Monokote on edge of firewall - 4/10/2002 7:46:22 AM
Vince
Status: offline
[QUOTE]Originally posted by gpmikemorse
It may not be obvious from the previous posts, but the trick is to do the Monokote before you fuelproof the firewall. [/QUOTE]
Ooops, yep forgot that.
Vince
       Post #: 7
Monokote on edge of firewall - 4/10/2002 8:15:12 AM
Mendes
Status: offline
I use Balsarite, nice thing about it is that it is a fuelproofer too.
       Post #: 8
Monokote on edge of firewall - 4/11/2002 1:26:51 AM
BingoFlyer
Status: offline
I have always used Balsirite and MonoKoted the entire engine compartment, I may have to go to something else now that I can't get Balsarite.
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU5
