RE: TA 152H Meister Scale Project Grun 4    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Hangar 9 Piper J-3 Cub 40 ARF / Saito 90 twin - RTF
Seller:  Hill202
Details:   $500.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: TA 152H Meister Scale Project Grun 4
Page: <<   < prev  32 33 [34] 35 36 37 38 39 40 41   next >   >>
Login
RE: TA 152H Meister Scale Project Grun 4 - 9/10/2012 4:28 PM
David010567
Score: 105
Last Login: 5/17/2013
Status: offline
My HF drill press has seen better days... Wish it would just die already. LOL!
_____________________________
"It''s Dave man... Open the door I got the stuff"
Hide Signatures
(in reply to David010567)
       Post #: 826
RE: TA 152H Meister Scale Project Grun 4 - 9/11/2012 2:11 AM
pandissix
Score: 105
Last Login: 5/19/2013
Status: offline
Super clean work as always DD.
Hide Signatures
       Post #: 827
RE: TA 152H Meister Scale Project Grun 4 - 9/11/2012 2:27 AM
pandissix
Score: 105
Status: offline
Burley
Still looking for some good 411 and photos on hooking up the Jeti ESC. Manual is worthless ...and this thing is not the normal Castle setup. I know your mafia has done some big electrics...anyone have some detailed photos of the setup and wiring?
Hide Signatures
(in reply to pandissix)
       Post #: 828
RE: TA 152H Meister Scale Project Grun 4 - 9/11/2012 3:34 AM
Chad Veich
Score: 265
Status: offline
That is some of the cleanest building I've ever seen. Beautiful workmanship David.
Hide Signatures
       Post #: 829
RE: TA 152H Meister Scale Project Grun 4 - 9/12/2012 3:44 AM
pandissix
Score: 105
Status: offline
DD
Doing some planning. When do you estimate this one will clear your bench?
Hide Signatures
(in reply to Chad Veich)
       Post #: 830
RE: TA 152H Meister Scale Project Grun 4 - 9/12/2012 6:44 PM
David010567
Score: 105
Status: offline
quote:
ORIGINAL: pandissix
DD
email sent
Hide Signatures
       Post #: 831
RE: TA 152H Meister Scale Project Grun 4 - 9/12/2012 6:50 PM
David010567
Score: 105
Status: offline
A little "Pick-up" work to do while I'm waiting for more parts... I forgot to do the right side exhausts. I cut the 1/32" plywood inlay, recessed balsa fuselage sheeting, glued down and filled over with Model Magic filler.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 832
RE: TA 152H Meister Scale Project Grun 4 - 9/12/2012 8:59 PM
David010567
Score: 105
Status: offline
Stuff is here...
Click for fullsize
Hide Signatures
       Post #: 833
RE: TA 152H Meister Scale Project Grun 4 - 9/12/2012 9:13 PM
David010567
Score: 105
Status: offline
Wow... I just realized that this big turbo scoop sits right where the batteries go. Hmmmm?
Click for fullsize
Hide Signatures
       Post #: 834
RE: TA 152H Meister Scale Project Grun 4 - 9/12/2012 9:53 PM
pandissix
Score: 105
Status: offline
Yes DD...I like the way you think...lets make the Turbo scoop functional in a sense...get some more air across those Lipos wont hurt. Glad to see the package from Dino arrived. Not crazy about that pilot...but he is for another project...Would look much better if they put him in a late war leather jacket...instead of the early 1940's BofB gear or Polish campaign.
Hide Signatures
       Post #: 835
RE: TA 152H Meister Scale Project Grun 4 - 9/12/2012 10:06 PM
David010567
Score: 105
Status: offline
Pandi... I need you to decide on how to secure the Battery hatch. I'm going to hinge one side of the hatch. If we use rare earth magnets we will need to use a tape "pull tab" like we did on your LA-7 hatch. If we use a latch, I guess we need one or two of those Uncle Bob's latch catch thingys?
Hide Signatures
       Post #: 836
RE: TA 152H Meister Scale Project Grun 4 - 9/13/2012 7:01 PM
David010567
Score: 105
Status: offline
I got after the turbo inlet... Roughed everything up with 150 grit before gluing down the resin intake lip. Applied some MicroLite and sanded everything flush, ready for primer.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 837
RE: TA 152H Meister Scale Project Grun 4 - 9/13/2012 7:34 PM
pandissix
Score: 105
Status: offline
What no weld lines?
Hide Signatures
       Post #: 838
RE: TA 152H Meister Scale Project Grun 4 - 9/13/2012 8:04 PM
David010567
Score: 105
Status: offline
If you say one word about my dust... I'm sending you home.
Hide Signatures
       Post #: 839
RE: TA 152H Meister Scale Project Grun 4 - 9/14/2012 4:47 AM
wallace.tharp
Score: 100
Last Login: 5/16/2013
Status: offline
Beautiful!!!! Plase get a good cameraman for the maiden. Will it be on the lakebed out by the road to Big Bear?? Wallace Tharp
Hide Signatures
       Post #: 840
RE: TA 152H Meister Scale Project Grun 4 - 9/15/2012 2:17 AM
pandissix
Score: 105
Status: offline
Obberkommando der Luftwaffe paid a sight visit today. Pictures don't do this project justice. The craftsmanship in person has to be seen. A lot still needs to be done to get this operational. I would like to think it can be RTF before Christmas...I doubt any sooner.
This one will be maiden flight at the dry lake bed "rabbit" our trusty spot for big bird test flights. It's a few months off but will be well documented.
Hide Signatures
(in reply to wallace.tharp)
       Post #: 841
RE: TA 152H Meister Scale Project Grun 4 - 9/18/2012 2:58 PM
David010567
Score: 105
Status: offline
Scale hatch behind the pilot seat for access to the sliding canopy air cylinder done...
Click for fullsize
Hide Signatures
       Post #: 842
RE: TA 152H Meister Scale Project Grun 4 - 9/18/2012 3:01 PM
David010567
Score: 105
Status: offline
More work on the Battery Hatch... Freak'n Flying Coffin!!
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 843
RE: TA 152H Meister Scale Project Grun 4 - 9/18/2012 3:47 PM
pandissix
Score: 105
Status: offline
Flying Coffin...nice. That's what they called the HE 162
Hide Signatures
       Post #: 844
RE: TA 152H Meister Scale Project Grun 4 - 9/18/2012 4:00 PM
David010567
Score: 105
Status: offline
I decided to put the hinge on the left side. I'm going to use magnets to secure the hatch and make that little snorkel thingy that goes on the right side of the hatch so you have something to pull the hatch open with.
Click for fullsize
Hide Signatures
       Post #: 845
RE: TA 152H Meister Scale Project Grun 4 - 9/19/2012 12:59 AM
IL2windhawk
Score: 100
Last Login: 5/1/2013
Status: offline
quote:
ORIGINAL: David010567
That's really cool. I would give serious thought to installing a small EDF motor to cool your Lipos. Not that you really need it, but it would be really neat and it could look just like the real thing (if you removed the scoop from a real FW, the fan is built right into the side wall of the airplane).
Fly War-Clouds.com
WWII Online Air Combat \\ Western Front
Hide Signatures
       Post #: 846
RE: TA 152H Meister Scale Project Grun 4 - 9/19/2012 5:33 PM
David010567
Score: 105
Status: offline
Installed a hardwood block in the bottom of the rudder to accept the removable hinge pin wire and strap. The other end goes into an embedded nyrod in the top of the rudder.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to IL2windhawk)
       Post #: 847
RE: TA 152H Meister Scale Project Grun 4 - 9/19/2012 5:36 PM
David010567
Score: 105
Status: offline
Here is the final blend of the Fuse/Fin joint before glassing. Whew! Sanding dissimilar materials is a bear. Once Glassed I be able to smooth it out a little more.
Click for fullsize
Hide Signatures
       Post #: 848
RE: TA 152H Meister Scale Project Grun 4 - 9/19/2012 5:53 PM
David010567
Score: 105
Status: offline
quote:
ORIGINAL: IL2windhawk
Way kewl idea!! Hey Pandi... Whats the diameter of those electronic tubo fans you said you had for cooling?
Click for fullsize
Hide Signatures
       Post #: 849
RE: TA 152H Meister Scale Project Grun 4 - 9/19/2012 7:12 PM
David010567
Score: 105
Status: offline
FYI... 30mm edf unit would fit nicely.
Click for fullsize
Hide Signatures
       Post #: 850
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.734RCU1
