RE: TA 152H Meister Scale Project Grun 4    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: TA 152H Meister Scale Project Grun 4
Page: <<   < prev  30 31 [32] 33 34 35 36 37 38 39   next >   >>
Login
RE: TA 152H Meister Scale Project Grun 4 - 7/10/2012 7:24 PM
David010567
Score: 105
Last Login: 6/15/2013
Status: offline
got the standoff's black marked and scribed. Will turn em down and make em purty next.
Click to see fullsize image.
Click for fullsize
_____________________________
"It''s Dave man... Open the door I got the stuff"
Hide Signatures
(in reply to David010567)
       Post #: 776
RE: TA 152H Meister Scale Project Grun 4 - 7/10/2012 7:27 PM
t_burley
Score: 117
Last Login: 6/20/2013
Status: offline
when is this thing heading my way?
I need something for target practice
Todd
Meister, Aero Acc., Sierra, Glennis, Get Stencils, Shinden, Warbird Colors, Fliteskin, VicRC, Holman, Bates custom
Hide Signatures
       Post #: 777
RE: TA 152H Meister Scale Project Grun 4 - 7/11/2012 2:09 AM
pandissix
Score: 105
Last Login: 6/18/2013
Status: offline
Awesome work DD!!! Think we can get this finished, painted and maiden before WOTR?
Hide Signatures
(in reply to t_burley)
       Post #: 778
RE: TA 152H Meister Scale Project Grun 4 - 7/11/2012 2:31 AM
vertical grimmace
Score: 169
Status: offline
quote:
ORIGINAL: pandissix
You guys coming to WBOTR? That would be really cool to meet you guys and see this in person.
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
(in reply to pandissix)
       Post #: 779
RE: TA 152H Meister Scale Project Grun 4 - 7/11/2012 6:27 PM
David010567
Score: 105
Status: offline
Ok, I must admit... I'm real proud of these babies.
Click for fullsize
Hide Signatures
(in reply to vertical grimmace)
       Post #: 780
RE: TA 152H Meister Scale Project Grun 4 - 7/11/2012 7:20 PM
David010567
Score: 105
Status: offline
Question... Do electric motors need to be baffled?
Hide Signatures
       Post #: 781
RE: TA 152H Meister Scale Project Grun 4 - 7/12/2012 12:18 AM
David010567
Score: 105
Status: offline
I'm thinking of a upside down U shaped baffle so air runs straight over the pop tart. I also want to use the baffle as a mounting ring for the cowl so I can hide the mounting screws.
Hide Signatures
       Post #: 782
RE: TA 152H Meister Scale Project Grun 4 - 7/12/2012 4:15 AM
pandissix
Score: 105
Status: offline
Dave. Yes I think a baffle for air on the ESC is a good idea.
Hide Signatures
       Post #: 783
RE: TA 152H Meister Scale Project Grun 4 - 7/12/2012 4:22 AM
t_burley
Score: 117
Status: offline
yes good idea about air over ESC.
also we need to discuss WOTR?
If that is something that you plan on having there
so I know if I have time to paint and detail it
Todd
Hide Signatures
       Post #: 784
RE: TA 152H Meister Scale Project Grun 4 - 7/12/2012 5:55 AM
Tko310
Score: 100
Last Login: 5/10/2013
Status: offline
The is a definite possiblity of a very nice trophy ( if i do say so, since i make them) I you guys can get this this up there. I love to watch you guys work. Very motivational!
Tighe O'Meara
Hide Signatures
       Post #: 785
RE: TA 152H Meister Scale Project Grun 4 - 7/12/2012 3:15 PM
David010567
Score: 105
Status: offline
I wanted to try and lock tite the black socket head cap screws and turn down the heads using the lathe. Them turkeys are HARD!! I was able to turn one down with .005 cuts. Destroyed my hand ground HSS cutter. Oh well lesson learned.
In this instance... The good old Dremel tool and a bench grinder get's the job done efficiently.
Click for fullsize
Hide Signatures
(in reply to Tko310)
       Post #: 786
RE: TA 152H Meister Scale Project Grun 4 - 7/12/2012 3:17 PM
David010567
Score: 105
Status: offline
Dave's Desert Custom Axle and Standoff shop does it again. Sheen job finished... Back to modeling.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 787
RE: TA 152H Meister Scale Project Grun 4 - 7/12/2012 4:48 PM
John Taylor
Score: 100
Last Login: 6/19/2013
Status: offline
David, I love what you are doing with this project . Keep up the great work. John T.
Hide Signatures
       Post #: 788
RE: TA 152H Meister Scale Project Grun 4 - 7/12/2012 6:40 PM
David010567
Score: 105
Status: offline
quote:
ORIGINAL: John Taylor
Thanks John... The machined bits here are all new to me. I'm learning as I go.
Hide Signatures
(in reply to John Taylor)
       Post #: 789
RE: TA 152H Meister Scale Project Grun 4 - 7/13/2012 5:28 PM
David010567
Score: 105
Status: offline
This Plymouth car starter is now mounted... Speak now or forever hold your peace!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 790
RE: TA 152H Meister Scale Project Grun 4 - 7/13/2012 6:09 PM
David010567
Score: 105
Status: offline
Cooling... I'm thinking of cutting out the face of the cowl and putting in a ring with 4 stator blades around the spinner and moving the poptart under the top of the cowl to use the scale vents.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 791
RE: TA 152H Meister Scale Project Grun 4 - 7/13/2012 11:05 PM
stefanP
Score: 100
Last Login: 3/25/2013
Status: offline
You didn't need to turn the heads down on the socket cap screws.I work at a shop where we make cap screws and different length set screws .No chance with using a scale 3 blade prop?? That's one advatage I like about electric power.I can use what ever prop is called for.Like I asked earlyer ,Is this a "ONE OFF PROJECT??".Keep up the great work.
stefanP
AMA 612678, CG 10-300 Member #63
IMAA 24164
Hide Signatures
       Post #: 792
RE: TA 152H Meister Scale Project Grun 4 - 7/14/2012 3:02 AM
pandissix
Score: 105
Status: offline
It's been so long I forget all the details. But this started as a two Meister Scale D9 kits and a TA152 plans and wing kit from Ty. Bash all that together and poof you have this kit bashed highly modified TA152. I know Ty built one of these years ago, I am not familar of anyone else taking on this project. Lord knows I don't have the skills alone to do this so it's a joint project. Burley will be painting it and I will be doing all the electronics and maiden.
Hide Signatures
(in reply to stefanP)
       Post #: 793
RE: TA 152H Meister Scale Project Grun 4 - 7/14/2012 3:05 AM
pandissix
Score: 105
Status: offline
Dave I like your thoughts of the the scale vents in the cowel and putting the esc there. My only request is the esc not be visible. So I don't want anyone looking down on the plane and seeing the esc. So let me know your thoughts.
Hide Signatures
       Post #: 794
RE: TA 152H Meister Scale Project Grun 4 - 7/14/2012 3:49 AM
David010567
Score: 105
Status: offline
quote:
ORIGINAL: pandissix
Tall order... Maybe we should just put pop tart at the bottom like we originally planned. I'll come up with screen window mesh to hide the vent hole under the cowl. Burley can just paint fake vents on top of the cowl.
Hide Signatures
       Post #: 795
RE: TA 152H Meister Scale Project Grun 4 - 7/14/2012 3:53 AM
David010567
Score: 105
Status: offline
Maybe we don't need a vent hole at all.
Click for fullsize
Hide Signatures
       Post #: 796
RE: TA 152H Meister Scale Project Grun 4 - 7/14/2012 3:54 AM
t_burley
Score: 117
Status: offline
how about Burley coming to the high desert there DD
and kicking yer 08r arse
Vent the bottom, hide it with screen, I'll weather over it
Todd
Hide Signatures
       Post #: 797
RE: TA 152H Meister Scale Project Grun 4 - 7/14/2012 4:01 AM
David010567
Score: 105
Status: offline
quote:
ORIGINAL: t_burley
Done... Mixing some 100:1 to break this baby in.
Hide Signatures
       Post #: 798
RE: TA 152H Meister Scale Project Grun 4 - 7/14/2012 4:05 AM
t_burley
Score: 117
Status: offline
quote:
ORIGINAL: Tko310
Tighe O'Meara
we'll see what happens Tighe. I hope to get to WOTR this year one way or another
Todd
Hide Signatures
       Post #: 799
RE: TA 152H Meister Scale Project Grun 4 - 7/14/2012 4:06 AM
t_burley
Score: 117
Status: offline
quote:
ORIGINAL: David010567
quote:
ORIGINAL: t_burley
I'd go 50:1 for this motor
Todd
Hide Signatures
       Post #: 800
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.407RCU1
