RE: TA 152H Meister Scale Project Grun 4    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: TA 152H Meister Scale Project Grun 4
Page: <<   < prev  33 34 [35] 36 37 38 39 40 41 42   next >   >>
Login
RE: TA 152H Meister Scale Project Grun 4 - 9/20/2012 4:09 AM
pandissix
Score: 105
Last Login: 5/24/2013
Status: offline
I've used PC fans from radio shack anywhere from 2-3.5 inches. Can even run them off a separate ESC. May work.
Hide Signatures
(in reply to David010567)
       Post #: 851
RE: TA 152H Meister Scale Project Grun 4 - 9/20/2012 11:17 PM
IL2windhawk
Score: 100
Last Login: 5/1/2013
Status: offline
Yeah, I've experimented with PC fans too, but they've never actually flown in any of my planes (or cooling EDFs, for that matter). As an alternate approach: you don't even need an ESC... you can run them with direct current from a seperate battery pack (Small LiPo, NiMH, NiCD, even Duracells) with an on/off switch inside the battery hatch. Or getting more fancy: a remote toggle switch tied to a channel on your TX. I get a little nervous about adding extra circuits to my flight LiPos, but that's probably just because I don't know jack about electricity!
Should be interesting!
_____________________________
Fly War-Clouds.com
WWII Online Air Combat \\ Western Front
Hide Signatures
(in reply to pandissix)
       Post #: 852
RE: TA 152H Meister Scale Project Grun 4 - 9/21/2012 3:03 AM
David010567
Score: 105
Last Login: 5/17/2013
Status: offline
Final sanded the Rudder until I was happy with it, then covered in fabric... Ready for dope and primer.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
"It''s Dave man... Open the door I got the stuff"
Hide Signatures
(in reply to IL2windhawk)
       Post #: 853
RE: TA 152H Meister Scale Project Grun 4 - 9/21/2012 3:22 PM
IL2windhawk
Score: 100
Status: offline
Beautiful! I like the trick with the removable hinge wire.
Fly War-Clouds.com
Hide Signatures
       Post #: 854
RE: TA 152H Meister Scale Project Grun 4 - 9/21/2012 5:24 PM
David010567
Score: 105
Status: offline
quote:
ORIGINAL: IL2windhawk
Thanks... We needed the rudder to be removable to get to the tail wheel retract mounting bolts through a small hole in the fin post. Now that I think about it... It will also be very handy to maintain the rudder pull-pull cables and rudder horn if something breaks or wears out.
Hide Signatures
       Post #: 855
RE: TA 152H Meister Scale Project Grun 4 - 9/21/2012 8:49 PM
David010567
Score: 105
Status: offline
Final sanded the Elevators and covered with fabric... Ready for dope and primer.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 856
RE: TA 152H Meister Scale Project Grun 4 - 9/21/2012 8:52 PM
David010567
Score: 105
Status: offline
(4) magnets installed in the battery hatch using JB Weld.
Click for fullsize
Hide Signatures
       Post #: 857
RE: TA 152H Meister Scale Project Grun 4 - 9/22/2012 12:06 AM
vertical grimmace
Score: 154
Status: offline
You guys coming to Warbirds over the Rockies next weekend?
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
       Post #: 858
RE: TA 152H Meister Scale Project Grun 4 - 9/23/2012 7:47 PM
David010567
Score: 105
Status: offline
Per the Obberkommando... (1) big smiley face opening through the firewall to vent the ESC + (1) hole to route the wiring to the battery compartment.
Click for fullsize
Hide Signatures
(in reply to vertical grimmace)
       Post #: 859
RE: TA 152H Meister Scale Project Grun 4 - 9/23/2012 7:50 PM
David010567
Score: 105
Status: offline
Feeling real good about this battery hatch now that all the magnets are installed and everything sanded flush. No way this thing is coming off.
As far as I'm concerned... The Electron conversion is now complete.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 860
RE: TA 152H Meister Scale Project Grun 4 - 9/23/2012 7:51 PM
David010567
Score: 105
Status: offline
Glassed the fin joint and fin post... more glassing to come.
Click for fullsize
Hide Signatures
       Post #: 861
RE: TA 152H Meister Scale Project Grun 4 - 9/23/2012 10:59 PM
pandissix
Score: 105
Status: offline
Looks good DD super clean. What are you going to make the little snorkel thing for the hatch out of?
Thinking this thing could clear your bench soon?
Hide Signatures
       Post #: 862
RE: TA 152H Meister Scale Project Grun 4 - 9/23/2012 11:22 PM
David010567
Score: 105
Status: offline
I'm going to hand carve the snorkel that will be used for opening the hatch from hard wood like pine or something.
Hide Signatures
       Post #: 863
RE: TA 152H Meister Scale Project Grun 4 - 9/24/2012 8:35 PM
David010567
Score: 105
Status: offline
Turbo Charger... Here we go!!
Made a card board template for the outer blending lines. After locating the scoop, I put a 2" diameter hole in side of fuse for a future battery cooling fan and epoxied the fiberglass turbo scoop down.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 864
RE: TA 152H Meister Scale Project Grun 4 - 9/24/2012 9:20 PM
David010567
Score: 105
Status: offline
Sanding mask made from template and located around Turbo scoop. Ready for "The Butter"
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 865
RE: TA 152H Meister Scale Project Grun 4 - 9/24/2012 9:34 PM
David010567
Score: 105
Status: offline
Just had a sick feeling I put this thing on the wrong side. Whew!
Hide Signatures
       Post #: 866
RE: TA 152H Meister Scale Project Grun 4 - 9/24/2012 9:38 PM
David010567
Score: 105
Status: offline
For some reason I chuckled when I saw this...
Click for fullsize
Hide Signatures
       Post #: 867
RE: TA 152H Meister Scale Project Grun 4 - 9/25/2012 1:52 AM
pandissix
Score: 105
Status: offline
Looks good. Glad you suggested the functional turbo scoop. We smoked two 6s packs in the 100+ heat this weekend...so any little bit well help!
What's with the radio? Is that part of the zombie apocalypse bail out kit?
Hide Signatures
       Post #: 868
RE: TA 152H Meister Scale Project Grun 4 - 9/25/2012 3:12 AM
David010567
Score: 105
Status: offline
quote:
ORIGINAL: pandissix
It's a Kraft radio... Get it?? Ahhhh never mind.
Hide Signatures
       Post #: 869
RE: TA 152H Meister Scale Project Grun 4 - 9/25/2012 5:28 PM
David010567
Score: 105
Status: offline
Just like buttering pancakes...
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 870
RE: TA 152H Meister Scale Project Grun 4 - 9/26/2012 1:41 AM
David010567
Score: 105
Status: offline
Here's my list of required tools... Gotta get after this Turbo scoop... Geez... Pandi never visits me on days like this.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 871
RE: TA 152H Meister Scale Project Grun 4 - 9/26/2012 4:03 AM
pandissix
Score: 105
Status: offline
Let me guess. The old spice is for breaking a sweat.
Hide Signatures
       Post #: 872
RE: TA 152H Meister Scale Project Grun 4 - 9/26/2012 5:54 AM
David010567
Score: 105
Status: offline
quote:
ORIGINAL: pandissix
Old Spice is for...
armpit (ˈɑːmˌpɪt)
— n
1. Technical name: axilla the small depression beneath the arm where it joins the shoulderRelated: axillary
2. slang an extremely unpleasant place: the armpit of the Mediterranean
Hide Signatures
       Post #: 873
RE: TA 152H Meister Scale Project Grun 4 - 10/2/2012 3:25 AM
David010567
Score: 105
Status: offline
Progress... All (4) edges of the battery hatch are glassed. Top was glassed with (2) layers 3/4 oz cloth.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 874
RE: TA 152H Meister Scale Project Grun 4 - 10/2/2012 3:27 AM
David010567
Score: 105
Status: offline
Little snorkel thingy was carved from pine, glassed and flow coated. Will be used for something to grab onto when opening battery hatch.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 875
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.711RCU1
