hobbico 12v 7a battery
Tower Hobbies
Logged in as Guest
  Printable Version
FISHER FUEL PRODUCTS 5 GALLON & 2.5 GAS FUELERS
Seller:  hunternfla
Details:   $220.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> hobbico 12v 7a battery
Page: [1]
Login
hobbico 12v 7a battery - 4/8/2002 7:19:35 AM
gene375
Status: offline
, what should my volt read when my flight box battery is fully charged, i have a hobbico 12 volt 7 amp battery, i am unsure if it charging all the way, how long to charge and at what rae, thanks
       Post #: 1
hobbico 12v 7a battery - 4/8/2002 11:00:30 AM
dgrant
Status: offline
When I check mine, it reads almost 14volts right after taking off the charger. You should use one of the wall-plug variety, at about 600Mah. Usually overnight is sufficient. I haven't done the math on this one to figure rate/time. I just put overnight. No biggie. What is biggie though, is when hooking charger up to battery. Connect leads to battery FIRST, then plug charger in wall. When disconnecting, unplug wall FIRST, then disconnect leads. Doing in this order will prevent you from shorting your charger out. If the leads from charger touch when plugged in, I think it toasts your charger. Chargers are about $14 a piece, I went through a few of them.
(in reply to gene375)
       Post #: 2
hobbico 12v 7a battery - 4/8/2002 12:22:41 PM
4*60
Status: offline
After a few hours off charge your battery should read about 12.7 volts if fully charged ? !!
12.7 is a bit low, more like 13.0 volts fully charged.
< Message edited by Red Scholefield -- Apr 8 2002 11:59AM >
_____________________________
"Of course, that's just my opinion. I could be wrong." the other Dennis Miller
       Post #: 3
hobbico 12v 7a battery - 4/18/2002 12:36:08 AM
RFD
Status: offline
Get an ACE CVC charger and your troubles are over. It will bring your battery up to voltage and then go on trickle.
RFD
       Post #: 4
hobbico 12v 7a battery - 4/18/2002 5:30:46 AM
Geistware
Status: offline
I have hook-ups in my truck and it charges at 14.5 and when I get to the field, it reads 12.9
If I remember correctly, a 12 volt battery under no-load will read from 13 volts fully charged and 12 volts empty
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU5
