OS 40 Surpass C 17400rpm
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Tachometer Readings >> OS 40 Surpass C 17400rpm
Page: [1]
Login
OS 40 Surpass C 17400rpm - 7/26/2003 10:21:38 PM
futaba1024
Status: offline
HI.
This one is a bit of a laugh! Os 40 Surpass C 10% nitro 16% syn oil.
Graupner 8x6 16000
Master 8x4 17400.
< Message edited by futaba1024 -- Jul 30 2003 7:17PM >
       Post #: 1
OS 40 Surpass C 17400rpm - 8/8/2003 2:47:04 PM
dany_maia
Status: offline
Hi.
Are you trying to damage your engine?
(in reply to futaba1024)
       Post #: 2
OS 40 Surpass C 17400rpm - 8/8/2003 5:25:12 PM
sandal
Status: offline
dany_maia;
the FS-C engines are designed for high rpm use. 17.000 is no problem.
       Post #: 3
OS 40 Surpass C 17400rpm - 8/8/2003 5:52:08 PM
dany_maia
Status: offline
OK.
Sorry, I didnīt know.
Daniel Maia
       Post #: 4
OS 40 Surpass C 17400rpm - 8/8/2003 8:21:38 PM
futaba1024
Status: offline
In actual fact the 40fs-c is rated at .9hp@17500rpm, max rpm 21000.
cheers
       Post #: 5
OS 40 Surpass C 17400rpm - 8/9/2003 1:48:23 AM
sandal
Status: offline
I'd LOVE to hear one of those engines, the sound must be fantastic. I have a .30 and a .52 four stroke airplane engine, and thinking about what they would sound like at almost twice the rpm...
       Post #: 6
OS 40 Surpass C 17400rpm - 8/9/2003 1:50:05 PM
futaba1024
Status: offline
Sandal.
At those sort of rpm, it sounds a bit like a YS63 at full chat, as it happens we are running a YS63 silencer ! It fits a treat.
Cheers
       Post #: 7
OS 40 Surpass C 17400rpm - 8/9/2003 2:07:14 PM
sandal
Status: offline
*goosebumps*
       Post #: 8
RE: OS 40 Surpass C 17400rpm - 10/30/2005 5:18:28 PM
futaba1024
Status: offline
Just dug this one out again, the motor has changed owner and we have done some more prop testing on 10% fuel.
15000rpm on an APC 10x3 with an idle of around 3000rpm and suberb transition, the new owner is very pleased!
(in reply to sandal)
       Post #: 9
RE: OS 40 Surpass C 17400rpm - 10/30/2005 9:50:36 PM
Motorboy
Status: offline
quote:
ORIGINAL: sandal
dany_maia;
C means car, also designed for modelcar...
10x3 15000 = 0.723 (better effect)
Graupner 8x6 16000 = 0.719 HP
Master 8x4 17400 = 0.617 HP
Jens Eirik
< Message edited by Motorboy -- 10/30/2005 9:57:33 PM >
_____________________________
Jens Eirik
All landings are just controlled crashes!
       Post #: 10
RE: OS 40 Surpass C 17400rpm - 11/9/2005 8:47:54 PM
derferic
Status: offline
Futaba1024,
Can you provide a picture of the engine? I have the aero version but the 'C' model is obviously different.
Can someone say what is different internally to allow such high RPMs?
(in reply to Motorboy)
       Post #: 11
RE: OS 40 Surpass C 17400rpm - 11/10/2005 6:48:05 PM
More HP
Status: offline
Really stiff valve springs, larger exhaust port and different cam profile. The straight intake manifold helps too, rather than the 90 degree updraft airplane type.
Powerslave, Rust in Peace, Seasons in the Abyss, Breadfan, Night Moves, Badmotorfinger, Beg to Differ, Chaos A.D., Cowboys From Hell, Unknown Road, The X Factor, The Razors Edge, Lucifuge, Force of Habit, Ignition, How Will I Laugh Tomorrow...
(in reply to derferic)
       Post #: 12
RE: OS 40 Surpass C 17400rpm - 11/12/2005 5:33:57 PM
futaba1024
Status: offline
got it wrong.
< Message edited by futaba1024 -- 11/12/2005 5:37:11 PM >
(in reply to More HP)
       Post #: 13
RE: OS 40 Surpass C 17400rpm - 11/12/2005 5:38:31 PM
futaba1024
Status: offline
The 40c also has OS52 valves, here is a photo of the CX which has the recoil starter, the model we used was the C, same motor but with standard backplat
Cheers
Click to see fullsize image.
Click for fullsize
< Message edited by futaba1024 -- 11/12/2005 5:39:21 PM >
       Post #: 14
RE: OS 40 Surpass C 17400rpm - 2/8/2008 6:52:41 PM
futaba1024
Status: offline
Had originally built this motor fro a pal of mine, by swapping out the car crankshaft for the aircraft type with prop driver.
Subsiquently it has had one more owner and a twin needle carb fitted, have just bought it back from the last owner, still in mint condition!
Think they are out of production now.......... May be worth quite a bit on Ebay or I could find a plane for it.
Cheers
       Post #: 15
Page:   [1]
Page: [1]
