RE: Aviatik DI build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Aviatik DI build
Page: <<   < prev  1 2 3 4 5 6 7 [8] 9   next >   >>
Login
RE: Aviatik DI build - 9/5/2012 3:59 AM
Flying Fox
Score: 109
Last Login: 5/16/2013
Status: offline
Goodluck Martin, wair fior the wind to be straight on down the runway then give her.
I'm not familiar with all the large scale gasser 'stuff' but learning from you and others on the forum. I do agree with you on the safety aspects though. Looking good!
Cheers,
Bri
Hide Signatures
(in reply to Nieuport nut)
       Post #: 176
RE: Aviatik DI build - 9/5/2012 1:50 PM
LT Pierce
Score: 100
Last Login: 5/25/2013
Status: offline
Hello Martin:
Good luck, with your test flights, too bad you do not live closer.
 The 400 field is Omni for wind direction.
We will be in Kitchner this week-end with the Messenger M-38.
 Regards Larry
Hide Signatures
(in reply to Flying Fox)
       Post #: 177
RE: Aviatik DI build - 9/5/2012 11:38 PM
Nieuport nut
Score: 105
Status: offline
Southerly winds at 23kph again >sigh<
Martin
Hide Signatures
(in reply to LT Pierce)
       Post #: 178
RE: Aviatik DI build - 9/13/2012 12:31 AM
geezeraviation
Score: 110
Status: offline
I was fortunate enough to meet Martin and see his model at Rhinebeck this past weekend and I gotta tell you guys the pictures here dont do it justice, its absolutely gorgeous.
Doc
_____________________________
Happy landings, Doc Hou Tx
The second rule of modeling is there is no such thing as an insignificant savings in weight
Hide Signatures
       Post #: 179
RE: Aviatik DI build - 9/13/2012 2:24 AM
N11
Score: 100
Status: offline
Second That Doc!!! Seen it up close Beautiful Model!
Jim
Hide Signatures
(in reply to geezeraviation)
       Post #: 180
RE: Aviatik DI build - 9/13/2012 3:47 AM
Nieuport nut
Score: 105
Status: offline
Thanks guys. It was a great weekend, in spite of the Saturday storm..
Hoping to test fly tomorrow afternoon. My test pilot is going away for the weekend so it's Thursday, or next week. Fingers crossed for the wind.
Martin
Hide Signatures
(in reply to N11)
       Post #: 181
RE: Aviatik DI build - 9/14/2012 4:09 AM
Nieuport nut
Score: 105
Status: offline
SUCCESS!!!
I did a test flight this evening and everything went well. We did a couple of power run-ups, range check, slight radio programming adjustments and then I handed the box over to Rolly Siemensen, a club member who has been flying since the 60s. Rolly does this for a lot of our club - test flights are no place for egos.
I have a couple of videos, but only one is worth downloading. (I am loading it on YouTube tonight.) You will see that the tail lifts quite easily with the application of power. This was reassuring as it confirmed that the CG must be close. Takeoff was straightforward and climb out at 1/2 throttle was good. A little up trim was needed but other than that, it flew fine. I got the transmitter a couple of minutes into the flight and found that it was very neutral laterally - it needed opposite aileron and rudder to come out of turns. The elevator is very powerful and only a very small amount was needed. It is a draggy plane that needs more power than I had thought, (I still have lots of reserve) The landing approach started WAY out, (I will have to do some "perceptual adjusting" for this size of plane), but touched down smoothly. Thanks Roll!
Overall, I felt a little like I was "balancing on a ball", but never like I was going to "fall off". The elevator sensitivity was surprising. While it is quite large, it is on a long tail moment which usually smooths things out, (think about pattern planes) . Normally, I would suspect a CG too far aft, but it's at 25% of MAC, and it's easy to lift the tail taxiing. I think it will get some expo to soften it around neutral and I'll dial down the throws. I think I'll also increase the aileron differential and see if that improves the roll rate.
I checked the head temp on landing. Now, it had been at low throttle during the approach and landing, and it took about a minute for me to get a reading. however, it read 188C with suggests that I'm right in the middle of the ZDZ recommended 180-210C.
After winning the "Spirit of Rhinebeck" award last weekend, (and a 1/3 scale Balsa USA Fokker DrI now in the basement), this caps off a great week.
Martin
Hide Signatures
       Post #: 182
RE: Aviatik DI build - 9/14/2012 8:56 AM
Teus
Score: 105
Status: offline
Congratulations Martin
Both with your maiden flight and your award at Rhinebeck.
Looking forward to the video when uploaded.
About your elevator controls; I also use expo to smooth out the controls on my planes but I don't dial the controls back when too sensitive. I use the max up elevator to hold the tail down when taxiing and during landing to prevent a flip over. It's sometime easy to have max elevator deflection.
Hide Signatures
       Post #: 183
RE: Aviatik DI build - 9/14/2012 12:29 PM
Nieuport nut
Score: 105
Status: offline
http://www.youtube.com/my_videos_edit?ns=1&video_id=OHqNdWELZoc
Thanks Teus. Yes, just using exponential would allow full deflection for ground handling purposes. By the way, the ground handling is very good - short, wide gear fairly far forward.
Martin
Hide Signatures
(in reply to Teus)
       Post #: 184
RE: Aviatik DI build - 9/14/2012 12:37 PM
geezeraviation
Score: 110
Status: offline
Martin, well done on the maiden, glad to hear all went well and the model flies gently.
Doc
Hide Signatures
       Post #: 185
RE: Aviatik DI build - 9/14/2012 12:49 PM
Nieuport nut
Score: 105
Status: offline
OK. Video is up but I don't get it with a search, so you'll have to just click the link above.
Thanks Doc. I can't say it flies gently yet, but not a problem. I have high hopes for the expo on the elevator based on my experience with my Dewoitine 501 some years ago.
Martin
Hide Signatures
       Post #: 186
RE: Aviatik DI build - 9/14/2012 1:24 PM
Teus
Score: 105
Status: offline
The link don't work for me Martin but I found the video
She looks great in the air.
Hide Signatures
       Post #: 187
RE: Aviatik DI build - 9/14/2012 1:38 PM
abufletcher
Score: 1576
Status: offline
Beautiful take-off and landing! Very well done. But "the team" at the field there needs some education on maiden-flight protocols. First, the "photo ops" need to be separated from the actual maiden. I was shocked to see that one guy out there taking photos while the pilots waits with the engine running for him to finish! Second rule, for videographers, keep the camera on the dang model! Don't the dogs or the pits or the windsock. And don't stand way back in the cheap seats.
But again Congrats on a amazing model...successfully maidened!
Hide Signatures
(in reply to Teus)
       Post #: 188
RE: Aviatik DI build - 9/14/2012 1:43 PM
Nieuport nut
Score: 105
Status: offline
Gosh darn, Teus, how did you do that?
I tried using YouTube's embed feature and all I got was the url and picture specifics, (ie a line of text), when I tried to post it here.
Curious as to your inability to make the link work, (it works for me), as well as your ability to find it on YouTube! I couldn't.
Don, it was the wife of a club member who was videoing. Hopefully I'll be getting some better video and still soon. As for photo ops - I have a ton of still from this build so that's not may orientation so much - sorry! The landing was every bit as good as the take off which is why Rolly always gets my "more complicated" test flights.
Martin
Hide Signatures
(in reply to Teus)
       Post #: 189
RE: Aviatik DI build - 9/14/2012 2:29 PM
gabriel voisin
Score: 110
Last Login: 5/24/2013
Status: offline
Martin, really beautiful....... it's an amazing model.
Greetinngs Matz
Hide Signatures
       Post #: 190
RE: Aviatik DI build - 9/14/2012 3:01 PM
Flying Fox
Score: 109
Status: offline
Fantastic Martin - so happy for you!
Congratulations for winning the "Spirit of Rhinebeck" award last weekend, and more so for the very successful maiden flight of your Aviatic! It's always gratifyting to see all one's hard work and effort pay off nicely with a successful first flight. Now you can start breathing again and simply enjoy flying.
Cheers,
Bri
Hide Signatures
(in reply to gabriel voisin)
       Post #: 191
RE: Aviatik DI build - 9/14/2012 3:44 PM
LADISLAV
Score: 100
Status: offline
Congratulation Martin. Not electric, but the sound makes up for it.
Laddie.
Hide Signatures
       Post #: 192
RE: Aviatik DI build - 9/14/2012 3:54 PM
abufletcher
Score: 1576
Status: offline
Martin, while I'd love to see some well-done stills of the finished model, what I was trying to say is once the engine is running it's time for the photographers to get out of the way...or rather to "take their positions" so that they can take the best possible shots without in any way interfering with the flying.
BTW, more and more I like the idea of having someone else do the maiden flights of my special scale models. I'm just too much of a nervous wreck to do a decent job as a pilot.
Hide Signatures
(in reply to LADISLAV)
       Post #: 193
RE: Aviatik DI build - 9/14/2012 4:05 PM
Nieuport nut
Score: 105
Status: offline
Jim Murdoch sent me some photos including takeoff, low pass and landing shots.
Martin
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 194
RE: Aviatik DI build - 9/14/2012 4:19 PM
abufletcher
Score: 1576
Status: offline
Well, I have to admit I REALLY like that second shot with the prop spinning...and that's the very one I was complaining about! I guess it was worth the brief wait.
Hide Signatures
       Post #: 195
RE: Aviatik DI build - 9/14/2012 4:38 PM
LT Pierce
Score: 100
Status: offline
Hello Martin:
Well done all around, excellent test flight..
What's next?
Hide Signatures
(in reply to abufletcher)
       Post #: 196
RE: Aviatik DI build - 9/14/2012 5:57 PM
Teus
Score: 105
Status: offline
quote:
ORIGINAL: Nieuport nut
Martin, when I click your link it will redirect me to my own youtube upload page because there is "my_videos_edit" in the URL, so youtube thinks I want to upload a video. I found your video by searching the video id. (OHqNdWELZoc found in your link) with youtube search. After that it's easy. Copy the URL and past it between the youtube tags: [youtube] here your url [/youtube].
If you quote my message with the video you see what I mean.
Many happy flights Martin,
Hide Signatures
       Post #: 197
RE: Aviatik DI build - 9/14/2012 6:12 PM
udet1918
Score: 100
Status: offline
Martin
I love it when a plan comes together...Well done!
Ron
Hide Signatures
       Post #: 198
RE: Aviatik DI build - 9/15/2012 3:37 PM
Nieuport nut
Score: 105
Status: offline
Laddie, I went with a proper canister exhaust after seeing Keith Zimmerley's DH-4 several years ago and being impressed with the sound. There is enough electric flier in me to NOT want the loud bark of so many gas "mufflers".
Larry, I traded in my BUSA certificate for a DrI, but I may try a more conveniently sized 1/4 scale model first - I like building this size. I also have a set of Teus' turnbuckles and I'd like to use them next.
Thanks Teus. I think I have it figured out now.
I am pleased with how well all the detail has stayed with the plane. Nothing has shaken loose. In fact all the rigging is still solid. I was sure I would forget something as this is my first gas plane, but so far nothing has let go. I still have to open up the radio compartment but have my fingers crossed. I'm sure that the ZDZ90 has something to do with this as it is a very smooth running engine. That is much of the reason I chose it.
Martin
Hide Signatures
(in reply to udet1918)
       Post #: 199
RE: Aviatik DI build - 9/19/2012 6:45 PM
Nieuport nut
Score: 105
Status: offline
I got some more photos from Dave Fasken, (a club member). Looking forward to getting out this weekend.
Martin
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.484RCU1
