ZDZ 80 Hard starting and won't idle
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> ZDZ & RCS Support >> ZDZ 80 Hard starting and won't idle
Page: [1]
Login
ZDZ 80 Hard starting and won't idle - 7/27/2003 7:33:44 AM
Check6-RCU
Status: offline
I need some help guys. This is a new engine. Set needles at 1 1/2, sensor was all the way counter clockwise. Would not start at idle. Finally started at 1/2 throttle , but only with an electric starter. Runs very smooth from 1/2 to full throttle, but quits immediately when throttling down past 1/2 throttle. This is very frustrating. Any ideas??
Fred
       Post #: 1
ZDZ 80 Hard starting and won't idle - 7/27/2003 9:01:59 PM
Mike Dooley/RCS
Status: offline
Fred,
Check that the throttle butterfly is opening correctly. The screw head on the throttle shaft should be facing into the engine when at idle or closed position. If the carburetor was removed be sure that all pulse holes are properly aligned with the carb and gaskets so that the carb pump can operate.
Mike Dooley
RC Showcase
(in reply to Check6-RCU)
       Post #: 2
ZDZ 80 Hard starting and won't idle - 7/28/2003 7:54:34 AM
Check6-RCU
Status: offline
Hi Mike,
Thanks for the tip. I checked my butterfly and the screw head is showing with the plate closed. I'm in the process of reversing it. Hope this does the trick. I'll let you know. Pump seems to be working on the carb, when choked , I get plenty of gas coming out the carb.
Fred
       Post #: 3
ZDZ 80 Hard starting and won't idle - 7/28/2003 5:39:04 PM
Mike Dooley/RCS
Status: offline
Yes, if you can see the screw head when closed, it is opening backwards...
Mike Dooley
RC Showcase
       Post #: 4
ZDZ 80 Hard starting and won't idle - 8/1/2003 3:19:02 AM
Check6-RCU
Status: offline
Mike!! You are the best!!!
Did everything you suggested, this engine is a whole new animal. Starts very easily and idles down where you can almost count the blades. AWESOME!! Can't believe that little butterfly could make such a difference. Thanks so much for your input, can't wait to get the MB 5 in the air.
Thanks again ,
Fred
Both needles set at 1 1/2 turns, pickup sensor all the way over.
Transition when running is instantaneous, engine runs very smooth, using a 24x10 Zinger for breakin, 40 to 1 mix Lawnboy ashless.
       Post #: 5
ZDZ 80 Hard starting and won't idle - 8/3/2003 3:39:11 PM
Rtel
Status: offline
Just started my new 80 yesterday. What a *****cat! Starts easy and is very predictable. I'm running on Penzoil with a Mejzlik 26X10 with the cowl off and in two tanks of gas I have already picked up 300 RPM. Will even idle down to 1600 RPM at this stage of the break in. This is going to be a fun engine! BTW, I have had an RCS-1.40 for the last two years that I have enjoyed too. Looks like I'm going to have to put my airplane in harms way tomorrow and do a first flight.
Rick
       Post #: 6
ZDZ 80 Hard starting and won't idle - 8/9/2003 4:34:10 AM
capthis
Status: offline
Check 6 do you have the bing carb?
_____________________________
Been there, crashed that!
       Post #: 7
ZDZ 80 Hard starting and won't idle - 8/9/2003 6:02:02 AM
Check6-RCU
Status: offline
I believe it is.
Fred
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.609RCU2
