RE: H9 Jackal 50 Prop Jet    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Lanier Prediator 500 (II) - RTF
Seller:  stuk_at_work
Details:   $150.00   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: H9 Jackal 50 Prop Jet
Page: <<   < prev  51 52 53 54 55 [56] 57 58 59 60   next >   >>
Login
RE: H9 Jackal 50 Prop Jet - 9/13/2012 12:49 PM
FSXBA3P-MAN
Score: 100
Last Login: 3/7/2013
Status: offline
Love this plane very fast but it lacked a Military look to it.  Thought it looked alot a F-5 Agressor so here it is.  Plane flys better since the paint job..
_____________________________
Carl Goldberg Ultimate Brotherhood #107
Hide Signatures
(in reply to 2Brave)
       Post #: 1376
RE: H9 Jackal 50 Prop Jet - 9/13/2012 7:42 PM
cjshaker
Score: 100
Last Login: 6/12/2013
Status: offline
Very cool paint job
Hide Signatures
(in reply to FSXBA3P-MAN)
       Post #: 1377
RE: H9 Jackal 50 Prop Jet - 9/14/2012 12:40 AM
103/17
Score: 245
Last Login: 2/2/2013
Status: offline
What are the prop is everyone running with the Evo .60 nx ? Dont have the Jett pipe just the extended Evo pipe......
Hide Signatures
(in reply to cjshaker)
       Post #: 1378
RE: H9 Jackal 50 Prop Jet - 9/14/2012 4:34 AM
FSXBA3P-MAN
Score: 100
Status: offline
Im using a 10x7 composite.  Works great with the jett pipe and the stock evo muffler
Hide Signatures
(in reply to 103/17)
       Post #: 1379
RE: H9 Jackal 50 Prop Jet - 9/14/2012 7:29 AM
SpeedBoy
Score: 100
Last Login: 6/5/2013
Status: offline
This jackal painted looks better than the original , also I like the smaller canopy aspect , very very cool !!!
Living on a War Zone !!!!!
Seriously
Hide Signatures
       Post #: 1380
RE: H9 Jackal 50 Prop Jet - 9/19/2012 5:22 AM
bob62
Score: 100
Last Login: 6/19/2013
Status: offline
Advantage Hobbies sells the Jackle for $205.00
Hide Signatures
       Post #: 1381
RE: H9 Jackal 50 Prop Jet - 9/24/2012 5:29 PM
BluMiniMe
Score: 100
Last Login: 6/11/2013
Status: offline
Saw that price on Thursday and pulled the trigger. I have a cherrished and rebuilt YS45 side exhaust w/hatori pipe that should pull this thing around nicely.
Hide Signatures
(in reply to bob62)
       Post #: 1382
RE: H9 Jackal 50 Prop Jet - 10/6/2012 2:29 AM
BalsaBob
Score: 100
Status: offline
Is there a particular glow plug that is best to use with the 60NX ?
Thanks. Bob
" This plan is way too ingenious to fail for the fourth time ..... "
Hide Signatures
(in reply to BluMiniMe)
       Post #: 1383
RE: H9 Jackal 50 Prop Jet - 10/7/2012 9:44 PM
jet22b
Score: 110
Status: offline
quote:
ORIGINAL: BalsaBob
Thanks. Bob
Bob.
I am using a OS #3 plugs in my 60NX and they are running great!!
Sonny
aka
jet22b
Spitfire Brotherhood #12
P-40 Brotherhood #52
Hide Signatures
(in reply to BalsaBob)
       Post #: 1384
RE: H9 Jackal 50 Prop Jet - 10/29/2012 1:21 AM
ChriCYWG
Score: 100
Last Login: 6/15/2013
Status: offline
As I am about to start work on a Jackal shortly, I was reading this thread... lots of good info.. curious what the consensus is on the aileron and flap servos... manual recommends the MN48s.. there was some talk early on Page 17-20?? About Hitec 5245MG... but then there was talk of how these (can) fail due to a pin??
Just wondering what everyone is using...
Chris
Hide Signatures
(in reply to jet22b)
       Post #: 1385
RE: H9 Jackal 50 Prop Jet - 10/29/2012 1:29 AM
viper1676
Score: 100
Last Login: 4/26/2013
Status: offline
I used DS-821's for all my control surfaces except the flaps. For those I used Futaba S3004's as well as for the throttle.
Pull up....Pull up...Wait I'm upside down!!!!!
Hide Signatures
(in reply to ChriCYWG)
       Post #: 1386
RE: H9 Jackal 50 Prop Jet - 10/29/2012 3:31 AM
bob62
Score: 100
Status: offline
Watch a Jackel bite the dirt today, it was a 125 mile an hour pancake. Motor went about 75 yards after plane hit the dirt.
Hide Signatures
(in reply to viper1676)
       Post #: 1387
RE: H9 Jackal 50 Prop Jet - 10/29/2012 3:53 AM
viper1676
Score: 100
Status: offline
quote:
ORIGINAL: bob62
Yup...that's what happened to mine. Except the motor ended up 8 inches in to the ground.
Hide Signatures
(in reply to bob62)
       Post #: 1388
RE: H9 Jackal 50 Prop Jet - 10/29/2012 7:03 PM
jet22b
Score: 110
Status: offline
Hate to hear that another Jackal has come to a end. Just put my baby to bed for the winter!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 1389
RE: H9 Jackal 50 Prop Jet - 11/5/2012 3:34 AM
Captainkirk757
Score: 100
Last Login: 1/15/2013
Status: offline
Hi peoples, just giving an update..... If you put an O.S.75AX engine in the Jackal the best prop is an 11 x 12. I am getting 9 lbs of thrust so I have a power to weight ratio of 1 to 1. The plane flies FAST and it is very stable. However I am having an issue with those Eflite 60 sized electric retracts, they begin to cycle on there own when I retract them up  and I can't seem to solve the problem. One main gear would start cylcling first, then the other then the nose gear but when I put them down they stop. Does anyone have any suggestion?
Hide Signatures
       Post #: 1390
RE: H9 Jackal 50 Prop Jet - 11/5/2012 4:25 AM
Sygy00
Score: 100
Last Login: 6/10/2013
Status: offline
Yes Cap'n, your battery is not providing enough voltage during the cycle.  Firstly, NEVER use your radio battery for the retracts, ALWAYS use a separate battery.  I can show you how to wire this if you need it so the retracts only use the separate battery.  Second, you need a battery that can produce about 5 amps and hold at least 5 volts with this current drain.  And all this is assuming you don't have a high resistance in the wiring or connectors (especially connectors) that is dropping the voltage.  I've measured as much as 1 volt drop across some connectors under load.  Not good, especially if you have multiple connectors.
I used the 46 size eflites on my Jackal, with a 6V 1000mah NiMh separate battery.  I can cycle the gear about 100 times on one charge and have had no problems.  You will likely need a larger battery, say 6V 1400+ mah with something like 8-10C discharge rating (better too much battery than too little).
BTW - can you upload some pictures of you engine installation?  I'd love to see how you squeezed the 75 in there.
Good luck
Hide Signatures
(in reply to Captainkirk757)
       Post #: 1391
RE: H9 Jackal 50 Prop Jet - 11/5/2012 12:27 PM
bob62
Score: 100
Status: offline
Please provide your diagram for wiring a separate battery for the retracts. Thanks Bob
Hide Signatures
(in reply to Sygy00)
       Post #: 1392
RE: H9 Jackal 50 Prop Jet - 11/6/2012 2:32 AM
Sygy00
Score: 100
Status: offline
OK, attached is the wiring diagram to let any system use it's own battery supply, including electric retracts.  With this arrangement the receiver supplies the control signal only.  The added switch is important, and lets you work with your plane's radio without worry about the gear moving when you don't want it to.  I suggest putting this switch right next to your normal radio switch to help remind you to turn it on and off with the radio for flight.  I know that for most radios the center wire is the (+) power wire and is usually red.  You will need to check to make sure you cut the right wire for your radio.  I found a diagram on the internet and included it here for reference.  Note that some Airtronics radios now have connectors that match other brands - so make sure you know which wire is (+).  And, when you cut the wire, be careful you don't cut the others.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to bob62)
       Post #: 1393
RE: H9 Jackal 50 Prop Jet - 11/19/2012 2:40 PM
tlj125
Score: 104
Last Login: 6/18/2013
Status: offline
Seven more flights on the Jackal this past Sunday. Perfect conditions. Fixed my problem with the front nosegear not coming down by putting Tygon tubing over the control wires. They were flexing so much inside the plane when the the gear was retracted that they would get hung-up on themselves or other edges. The plane is flying and landing better than ever. Show center verticals until the plane became a dot in the sky. Great fun.
Terry
Hide Signatures
       Post #: 1394
RE: H9 Jackal 50 Prop Jet - 11/20/2012 12:17 PM
djay
Score: 100
Status: offline
Hi Guys.
Just finished my replacement Jackel build.
Forgot how fiddly it was to build for an ARF.
Fitted the Jett 56 from the previous Jackel, now long gone.
Carried out a test flight last friday but plauged with lots of engine problems, which I traced first to a loose gland nut on the needle valve assy, causing air leaks, and then to the carb assy coming loose sucking in air. Both problems causing the plugs to burn out in minutes.
Once those were fixed engine was tuned and ready for flight , when after refuelling the fuel valve stuck open, so all further flights were abandoned.
The one short flight was hair raising, as I forgot to put rates on the ailerons, luckily the engine ran so rough it only reached half speed so was eventually manageable.
All problems fixed so will try another flight this coming weekend.
Darryl.
I used to land in English cow poo, now I land in Camel poo. Plane still smells the same though.
Hide Signatures
(in reply to tlj125)
       Post #: 1395
RE: H9 Jackal 50 Prop Jet - 11/20/2012 2:39 PM
tlj125
Score: 104
Status: offline
Anybody tried putting some wheels with brakes on the plane yet? I was considering it as I fly off a paved runway. Roll out after landing is pretty long- over 75 ft before it slows enough to turn around. If it's a fast lasting, the roll out can be longer and put me in the grass. Then I risk a prop strike. Just curious if anyone has tried brakes and what brand was used.
Terry
Hide Signatures
(in reply to djay)
       Post #: 1396
RE: H9 Jackal 50 Prop Jet - 11/20/2012 5:42 PM
jet22b
Score: 110
Status: offline
Hi Darryl,
Glad to hear that you are back into the air with another Jackal 50!! I know one good thing you have going, you get to fly all year round!!! Lucky you!!!
Sonny
aka
jet22b
Hide Signatures
(in reply to djay)
       Post #: 1397
RE: H9 Jackal 50 Prop Jet - 11/22/2012 8:57 PM
flycolorado
Score: 100
Last Login: 6/17/2013
Status: offline
Hi guys,
I've got one of these birds almost ready to go but I'm wondering about the CG. If I add enough weight to balance per the manual it barely keeps the nose gear on the ground. As it is, it takes very little effort to lift the front wheel... I'm using the 60nx with the blue pipe and eflight 46 retracts, I've also got a 2100mAh LiFe stuffed as far back in the tail as it will go. Are all you guys flying this at the middle of the recommended CG? Thoughts on throws would be great as well.
Thanks, and Happy Turkey Day!
Perfection is purely perception
Hide Signatures
       Post #: 1398
RE: H9 Jackal 50 Prop Jet - 11/23/2012 1:54 AM
tlj125
Score: 104
Status: offline
Mine is also very light on the front wheel. If you lift the nose to the point the tail rest against the ground and let go, the nose will go back to the ground- just not real fast. The aircraft flies very well this way and if anything feels just a little nose heavy in flight. I was considering putting a 5 cell battery in the plane to replace the 4 cell to move the balance point back a little bit. One thing I have notice about the light nosewheel is that taxiing at slow speed is not the best.
Terry
Hide Signatures
(in reply to flycolorado)
       Post #: 1399
RE: H9 Jackal 50 Prop Jet - 11/23/2012 4:15 AM
jet22b
Score: 110
Status: offline
flycolorado,
My Jackal 50 is a tad nose heavy, but I like it that way and it fly just great!! I was always told to start at the CG that come in the manual and then find the one that work for you and the way you fly.
As far as the control throws, I found out on the maiden flight, that they was way to much and I have 35% expo mix in!! You don't need much to fly this bird. After the first flight I cut the throws in half of what the manual call for and then adjust to my liking. I have the same engine that you have in your Jackal 50. The last time I flew my Jackal 50 I fill the tank with 30% heli-mix fuel and was happy I did!!! The engine just love it!!!
I hope this info help and please let us know how your maiden went!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 1400
Jump to:
Google
SITE MAP!   : :   FORUM RULES
5.241RCU1
