RE: H9 Jackal 50 Prop Jet    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: H9 Jackal 50 Prop Jet Page: <<   < prev  51 52 53 54 55 56 [57] 58 59 60   next >   >>
Login
RE: H9 Jackal 50 Prop Jet - 12/4/2012 1:45 AM
GiMsAcE
Score: 105
Last Login: 5/24/2013
Status: offline
Hi all Is this plane faster than the Great Planes Patriot 45?.
I have a NIB YS45 SE and also a Picco 60 re black head slide carb and I wanted to find a great planes Patriot 45 kit and build it for some high speed fun.But it looks like everyone is very happy with the Jackal.
Thanks for the feedback!.
Hide Signatures
(in reply to jet22b)
       Post #: 1401
RE: H9 Jackal 50 Prop Jet - 12/26/2012 4:43 AM
supertoyz
Score: 100
Last Login: 5/18/2013
Status: offline
Just bought myself and new Jackal for Christmas and was wondering what you guys have found the best setup to be. Interested in the best retracts, wheels, servo's, motor, pipe and any other tips you guys are willing to share.
Hide Signatures
(in reply to GiMsAcE)
       Post #: 1402
RE: H9 Jackal 50 Prop Jet - 12/26/2012 3:46 PM
tlj125
Score: 104
Last Login: 5/21/2013
Status: offline
Built mine per the instructions and I am pretty happy with it. The wheels that come with the kit aren't the best. But I am using them anyway. Could use better wheels with brakes in them. Haven't done it yet. I got rid of the nose cone or spinner. It kept flying off anyway. Got a tru-turn and no problems since. Its a great practice plane if you haven't flown one of your other jets in a while. It is significantly quicker than the Patriot by at least 20-30 mph.
Terry
Hide Signatures
(in reply to supertoyz)
       Post #: 1403
RE: H9 Jackal 50 Prop Jet - 12/26/2012 8:35 PM
jet22b
Score: 110
Last Login: 5/25/2013
Status: offline
quote:
ORIGINAL: supertoyz
supertoyz,
I went with the JR 821 servos, Evo 60NX with the JETT Blue pipe, went with the Robart gear that was made for this bird. No problem with this setup. For fuel, I am running Cool Power 30% heli-mix. This engine just love it!!!
Hope this help!!!
Sonny
aka
jet22b
_____________________________
Spitfire Brotherhood #12
P-40 Brotherhood #52
Hide Signatures
       Post #: 1404
RE: H9 Jackal 50 Prop Jet - 12/28/2012 2:45 PM
supertoyz
Score: 100
Status: offline
quote:
Supertoyz,
Hope this help!!!
Sonny
aka
jet22b
Glad to hear about the fuel since that's what I use in the Heli's. I was more interested in idea's for engines and retracts. I wan't as much speed as possible without sacrificing reliability, I want something that isn't finicky...is the Jett 56 a good option or just stay with the 60NX. And go with the Robart Mechanical or Pneumatic retracts? Also wanted to use the robostruts unless there is some reason not to. Any other tips or tricks you guys learned from building your Jackals?
Hide Signatures
       Post #: 1405
RE: H9 Jackal 50 Prop Jet - 12/28/2012 3:12 PM
Headhunter70
Score: 100
Status: offline
one tip from my side, if you decide to go with the Jett .56 get yourself the engine mount from Jett too...the original black plastic engine mount I had to replace twice
http://www.youtube.com/watch?v=8koNJvC2fe0
cheers
Hide Signatures
       Post #: 1406
RE: H9 Jackal 50 Prop Jet - 12/28/2012 3:49 PM
tlj125
Score: 104
Status: offline
Nice video. Good flight.
Terry
Hide Signatures
(in reply to Headhunter70)
       Post #: 1407
RE: H9 Jackal 50 Prop Jet - 12/28/2012 6:13 PM
Krasherjack
Score: 100
Last Login: 5/16/2013
Status: offline
Supertoyz,
I'm using the Evolution 60 and Jett pipe, the engine performed well, then seized, (Too lean I guess) I picked up a replacement Evolution, from one of the other Jackal crew, and now I run it rich... It's still Fast....
I Have E-flite .60 Electric Retracts, but the nose wheel steering has been problematic, Push/pull wires keep getting hooked... I fly off grass so landing the plane on the jett muffler on the grass, has'nt caused any problems, I just have to remember to cut engine on flair..(witch switch is that again)
Make sure your nosewheel shaft is long enough, for the prop to clear, especially if you fly off grass...Your plane will be green if not..
Post some pics..
Jack
Hide Signatures
(in reply to tlj125)
       Post #: 1408
RE: H9 Jackal 50 Prop Jet - 12/28/2012 6:25 PM
Krasherjack
Score: 100
Status: offline
More Jackal Video..
http://www.youtube.com/watch?v=0Ls3-4GUkkI
Hide Signatures
(in reply to Krasherjack)
       Post #: 1409
RE: H9 Jackal 50 Prop Jet - 12/28/2012 7:56 PM
tlj125
Score: 104
Status: offline
Nice flight Jack. Put a piece of thin foam under the front of the canopy and the vibration will go away. Mine was doing the same thing. At first I thought it was flutter.
Hide Signatures
       Post #: 1410
RE: H9 Jackal 50 Prop Jet - 12/28/2012 8:15 PM
Krasherjack
Score: 100
Status: offline
Ok, Will Try..
Hide Signatures
       Post #: 1411
RE: H9 Jackal 50 Prop Jet - 1/1/2013 7:14 AM
Wingspam
Score: 100
Status: offline
I have read this entire thread now, and was still suprised at how long a plane this is. I am planning on putting a jett 50 in it, I have it laying around as well as a 55 ax. I think the jett will produce more overall power.
Wingspam
Hide Signatures
       Post #: 1412
RE: H9 Jackal 50 Prop Jet - 1/2/2013 5:41 PM
Wingspam
Score: 100
Status: offline
Overall a great looking arf, only compliant is the hing slots in the elevator are horribly crooked caught this after glueing it all togather..
Wingspam
Hide Signatures
(in reply to Wingspam)
       Post #: 1413
RE: H9 Jackal 50 Prop Jet - 1/3/2013 11:14 PM
jet22b
Score: 110
Status: offline
A lot of people ran into that!!! Make sure you check them all.
Sonny
aka
jet22b
Hide Signatures
       Post #: 1414
RE: H9 Jackal 50 Prop Jet - 1/4/2013 5:39 PM
Krasherjack
Score: 100
Status: offline
Watch out for the Elevator and rudder control horns jamming together, also...
Hide Signatures
       Post #: 1415
RE: H9 Jackal 50 Prop Jet - 1/5/2013 8:28 PM
Wingspam
Score: 100
Status: offline
Maiden flight today,
Perfect ssw wind straight down the run way, taxied out and lined it up. Started roll out took almost full elevator to get it air born. Some quick trimming and all was good, running a Jett 50 on a 10x8 prop, ran it fairly rich and its still a quick plane. Lined up on the runway managed a minor flair, perfect rear wheel touch then the main touch, rolled out about 10 feet and motor hit the turf, the nice plastic landing gear mount shattered.
Wingspam
Hide Signatures
       Post #: 1416
RE: H9 Jackal 50 Prop Jet - 1/5/2013 10:01 PM
bob62
Score: 100
Status: offline
That's better than a belly flop at 100 miles per hour
Hide Signatures
       Post #: 1417
RE: H9 Jackal 50 Prop Jet - 1/6/2013 6:10 AM
Wingspam
Score: 100
Status: offline
That's true, but why use such cheap gear?
I have grown to expect better materials from H9, but when you expect the best from someone they usually let you down..
< Message edited by Wingspam -- 1/6/2013 2:05 PM >
Wingspam
Hide Signatures
(in reply to bob62)
       Post #: 1418
RE: H9 Jackal 50 Prop Jet - 1/6/2013 3:36 PM
tlj125
Score: 104
Status: offline
Your kidding, right? You used the plastic (fixed) gear that came with the plane?
Terry
Hide Signatures
       Post #: 1419
RE: H9 Jackal 50 Prop Jet - 1/6/2013 11:51 PM
Wingspam
Score: 100
Status: offline
Yep sure did,
Wingspam
Hide Signatures
       Post #: 1420
RE: H9 Jackal 50 Prop Jet - 1/11/2013 12:36 AM
jimm
Score: 100
Last Login: 5/23/2013
Status: offline
From people's experiance, what works better in this plane, the OS 55 or the Evo 60NX?
Thoughts?
Thanks.
Ultra Sport Brotherhood #143
Spitfire Brotherhood #118
Hide Signatures
       Post #: 1421
RE: H9 Jackal 50 Prop Jet - 1/12/2013 3:23 AM
jet22b
Score: 110
Status: offline
quote:
ORIGINAL: jimm
Thoughts?
Thanks.
jimm;
I have the Evo 60NX with the Blue Jett Pipe. Running on Cool Power 30% Nitro Heli-Mix. Turning a APC 9/7 prop and it move!!!
Sonny
aka
jet22b
Hide Signatures
(in reply to jimm)
       Post #: 1422
RE: H9 Jackal 50 Prop Jet - 1/13/2013 3:54 PM
tlj125
Score: 104
Status: offline
I have been using an Evo 60NX and Blue Jett Pipe as well. I have been running 15% nitro and a 10-7 APC prop. The engine would idle well and run at full power well as long as you kept it rich. Transition was always a problem though. In the air if you dropped the throttle back to idle for more than a few seconds and then tried to go back to full power, the engine would die and dead stick landing would follow. I learned to never pull back to idle except on final and forget trying a go around. Not a problem as the airplane lands extremely easy.
Yesterday my Evo 60NX stopped running in flight. Before it stopped running, I noticed it not running quit right. It was a bit slower but trailing a normal amount of smoke and the engine sound was normal. Then it just lost all power and the rpm slowed. I throttled back but the engine died before getting the plane on the ground. Black oily exhuast residue was all down the side and bottom of the plane. The engine didn't feel particularly hot. The glow plug was good. I still had good compression. But rotating the prop felt rough and tight. It would restart but not run properly or for more than a second or two. Didn't seem to want to draw any fuel. So I think it is time for a replacement.
I too would like to know what engine others would recommend? I would not recommend the EVO 60NX due to my experience. Though for the money, it is not bad. It just didn't hold up for me. I have other engines, Rossi, OS, YS, and Webra that are all over 15 years old and still run perfectly with hundreds of flights each. My current thinking is the Rossi 53 or the OS 55 would be a nice replacement.
Terry
Hide Signatures
       Post #: 1423
RE: H9 Jackal 50 Prop Jet - 1/13/2013 4:49 PM
särpet
Score: 100
Status: offline
west eurotech 52V1 high speed
http://www.westonuk.co.uk/westonuk2_021.htm
I have used two season west combat 25 with minipipe,15%nitro 18%oil synt/castor.
engine is great,easy to use and very powerfull apc 8.5x5.5 17800rpm
plane is. http://www.svida.cz/horrido/index.php?id=103
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1424
bob62
Score: 100
Status: offline
I have a flying buddy who runs these engines and has had the same problem. He sends them in and they either repair or send him a new engine.
Hide Signatures
       Post #: 1425
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
