summerwind -> RE: H9 Jackal 50 Prop Jet (9/8/2010 6:08 AM)
quote:
ORIGINAL: bbrundle Mike, designed the original kit version and unless I am mistaken the overall aeodynamics of the kit vs the ARF are the same, but the ARF has some slight tweaks to make it more mass production friendly. You might find this little fact interesting. Back when the Patriot was being developed, Mike had the opportunity to race Dave Ribbe who was flying developing the then new P-51 sport from Great planes. Both were using the same power setups and you would have thought that the Patriot would have been faster, but nope THe P-51 was faster by a fair margin. Mike thinks the main reason was the fact that the Airfoil % cross section is pretty high(thick) which gives great handling at slow speeds, but you sacrifice a fair amount of speed. This is just one of the main areas that the Jackal is so fast as the wing is rather thin and yet the airfoil(designed by George Hicks) is very fogiving in slow flight resulting in a very easy to land sport model. You do have to fly the bird down to the ground , but there are no unusual tenencies on approach. I hope this helps yeah the Patriot does bleed off speed quickly. i'm building a new one right now with a much thinner airfoil, high point is moved forward about 7%. the first one landed like a trainer, so this version will need some attention. i can see the Jackal as being very friendly just by watching the video, and it looks like it drops down just like the Sundowner. i also see that spare parts are priced reasonbly too......another plus for H9 kits[:D]
