aurora 9 battery    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> aurora 9 battery
Page: [1]
Login
aurora 9 battery - 8/27/2010 2:42 PM
yak-54
Score: 100
Last Login: 5/22/2013
Status: offline
what will be a good lipo battery for this TX also do i have to solder a new connector for this battery or they come ready for hitec like futaba and JR
also do i have to change anything in the program
thanks
ilan
Hide Signatures
       Post #: 1
RE: aurora 9 battery - 8/27/2010 6:19 PM
TigerI
Score: 100
Last Login: 12/28/2011
Status: offline
I'm using a Zippy or Turnigy 2200mah battery fits well in the A9. I cut the connector off of the stock battery pack & soldered on a new connector on the other end to fit the new lipo battery. Works for me.
_____________________________
Greg
May You Be In Heaaven A Half Hour Before The Devil Know You''''re Dead...
Hide Signatures
(in reply to yak-54)
       Post #: 2
RE: aurora 9 battery - 8/27/2010 6:23 PM
Brendan Lugo
Score: 100
Last Login: 3/30/2012
Status: offline
You will also have to go into the power management screen and change the setting to Lipo.
Hitec RCD
Multiplex USA
Hide Signatures
(in reply to TigerI)
       Post #: 3
RE: aurora 9 battery - 8/27/2010 6:41 PM
yak-54
Score: 100
Status: offline
thank you very much for quick answer
Hide Signatures
(in reply to Brendan Lugo)
       Post #: 4
RE: aurora 9 battery - 9/2/2010 3:34 AM
JIMF14D
Score: 104
Last Login: 5/24/2013
Status: offline
You must fly very long days! My A9 Tx goes 4-5 hours and still has 30% left.
Hide Signatures
       Post #: 5
RE: aurora 9 battery - 6/4/2011 3:57 PM
wkevinm
Score: 100
Status: offline
I was searching posts for installing a LIPO into my Hitec A9 TX. Saw your note. I have a spare Turnigy 7.4 V 2200 MAH battery and would like to modify for my TX. Is there a way to get rid of the large wire on the LIPO, or can I come off of the balancing jack to hook into my tx, any pictures help full.
Hide Signatures
       Post #: 6
RE: aurora 9 battery - 6/4/2011 11:01 PM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: wkevinm   I was searching posts for installing a LIPO into my Hitec A9 TX. Saw your note. I have a spare Turnigy 7.4 V 2200 MAH battery and would like to modify for my TX. Is there a way to get rid of the large wire on the LIPO, or can I come off of the balancing jack to hook into my tx, any pictures help full.
Never use the balancing tap for connection other than the intended purpose - a very weak link in the chain...
Aurora & Optima RX - Battery Compartment Size, Alternate Batteries and 2S Lipo
Best to use an adapter, using plug off original battery (unless kept as a back up) and a Deans plug or for your Lipo as attached.
This also facilitates easy removal/replacement for charging on your standard Lipo charger.
 (and prevents polarity reversal when in a hurry at a later date.)
Hitec Aurora, Eclipse, Flash, Optic, Prism series - Lipo and Field / Fast Charging (also has detail of battery plug)
When fitting a 2S Lipo or alternate battery.
Increase or decrease the thickness of the rubber pad attached inside the battery cover. This to ensure a snug fit which
a. Holds the battery in place to prevent damage to wires or connector.
b. Ensures battery cover does not slip off during use.
[A123 pack cannot be used due to both size and the lower voltage]
ex Hitec USA Support Forum Sticky:
Aurora 9, Spectra Modules & Optima Transceivers - FAQ & Undocumented Features
- Mixes, Setups,Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Click to see fullsize image.
Click for fullsize
< Message edited by A.T. -- 6/6/2011 10:15 PM >
R/C hobby consultant for various companies
Hide Signatures
(in reply to wkevinm)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.201RCU1
