Would you buy Hanger 9 Sukhoi again
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Would you buy Hanger 9 Sukhoi again
Page: <<   < prev  1 [2]
Login
Would you buy Hanger 9 Sukhoi again - 7/31/2003 9:44:49 AM
JohnVH
Status: offline
Mike, what about our deal on the remants and the cowl/wheelpants? Change your mind without telling me?
LMK
_____________________________
---AIR VH---*FURY FLYER* www.3DFoamy.com
(in reply to Falcon-RCU)
       Post #: 26
Would you buy Hanger 9 Sukhoi again - 7/31/2003 10:11:48 AM
DrScoles
Status: offline
I have not forgotten john I tried to bring you some of that stuff last weekend....
I will also entertain trades...particularly a DA50...
Mike
       Post #: 27
Would you buy Hanger 9 Sukhoi again - 7/31/2003 1:29:53 PM
bobknudsen
Status: offline
Hi Falcon,
I love my Sukhoi. You can check it out on page 16 in the Giant Scale Forum, it is about the 5th one down titled, "H9 Sukhoi BME 105 report with pics." It balances a 1/2" behand the wing tube with no added weight. It does 3D very well, but the only problem it seems to have is that it does rock the wings and harriers. I haven't spent any time trying to solve the problem, McConville gives some possible solutions that I have never yet tried. It is very solid in the IMAC manuvers. I went to my first IMAC contest in Molalla, OR last week and won the Sportsman Class. The DA Engine does have more power, but if I put the DA in my Sukhoi my 24 lb. airplane would be 25-1/2 lbs. and I don't think it would fly as well. The BME gives it unlimited verticle and pulls strong out of a hover. It is a great combination and with the price of the Sukhoi it is a good bargain.
Big Bob Knudsen
       Post #: 28
Would you buy Hanger 9 Sukhoi again - 7/31/2003 4:20:29 PM
Crash90
Status: offline
bobknudson.
What modifications did you make to achieve that cg without adding weight?
       Post #: 29
Would you buy Hanger 9 Sukhoi again - 8/2/2003 10:26:28 AM
bobknudsen
Status: offline
Crash 90
go to page 16 in giant scale, it's near the bottom now,
''h9 sukhoi bme report with pics'' it shows and tells all
       Post #: 30
Would you buy Hanger 9 Sukhoi again - 8/2/2003 9:53:54 PM
Falcon-RCU
Status: offline
To anyone who has a DA-100 in the Sukhoi how did it balance did you move the rudder servos to the front and use a pull pull setup?
       Post #: 31
Would you buy Hanger 9 Sukhoi again - 8/3/2003 1:34:46 AM
Randy-RCU
Status: offline
[QUOTE]Originally posted by Falcon
To anyone who has a DA-100 in the Sukhoi how did it balance did you move the rudder servos to the front and use a pull pull setup? [/QUOTE]
I started out with my rudder servos in the tail, was way to touchy and moved the two servos inline under the canopy hatch.
Randy
Randy Brown
http://www.Iflyrcairplanes.com
       Post #: 32
Would you buy Hanger 9 Sukhoi again - 8/3/2003 4:57:11 AM
JohnVH
Status: offline
Was too touchy with the servo's in the tail and a DA100?????????
Did you try some expo or reduce the throws? Should balance perfect with that engine
       Post #: 33
Would you buy Hanger 9 Sukhoi again - 8/3/2003 5:30:36 AM
wdratsloper
Status: offline
Hey Bob,
Did you use any of the manuvers that are on the video at the Rogue-Eagles webpage?
CYA JOE
       Post #: 34
Would you buy Hanger 9 Sukhoi again - 8/3/2003 9:23:53 AM
bobknudsen
Status: offline
Hey Joe,
No, but I used the ones on the CD you made for me.
Thanks again.
Big Bob
       Post #: 35
Would you buy Hanger 9 Sukhoi again - 8/7/2003 12:45:01 AM
Falcon-RCU
Status: offline
Has anyone else used a DA-100 in their Hanger 9 Sukhoi and have an opinion on putting the servos in the tail or to use a pull-pull system.
< Message edited by Falcon-RCU -- Aug 9 2003 11:37PM >
       Post #: 36
Would you buy Hanger 9 Sukhoi again - 8/10/2003 4:44:57 AM
Falcon-RCU
Status: offline
No more opinions on the balance with a DA 100.
       Post #: 37
Would you buy Hanger 9 Sukhoi again - 8/10/2003 6:30:33 PM
jelaird
Status: offline
I personally have heard of maybe 2 instances where the DA was used in the Sukhoi. You might try an advanced search here on RCU and connect the 2 up. I doubt many went that route due to the cowl width issue.
Jack
Chaos, panic, & disorder - my work here is done.
       Post #: 38
Would you buy Hanger 9 Sukhoi again - 8/10/2003 7:31:25 PM
JohnVH
Status: offline
Ill tell you about it in a couple months. Mine is getting one.
       Post #: 39
Would you buy Hanger 9 Sukhoi again - 8/11/2003 12:59:37 AM
Randy-RCU
Status: offline
I have run into 5 other guys that have put there rudder servos or servo under there canopy that are running the DA 100
Also,, This weekend after my motor has broke in abit more I put my Mezlick 25-12 3blade back on my Suk-31
I am in shock,, my suk flew great before it but I can tell you specially if your into IMAC or that style of flying the Suk with that prop is AWESOME, it does alot of stuf way better then the 2blade by far.
Randy
Randy Brown
       Post #: 40
Would you buy Hanger 9 Sukhoi again - 8/11/2003 1:02:23 AM
