RE: tf dc3    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: tf dc3
Page: <<   < prev  1 [2]
Login
RE: tf dc3 - 12/3/2010 6:47 PM
peternj
Score: 103
Last Login: 5/21/2013
Status: offline
TEBerg,
I know that spectrum makes a sensor for a rev limiter that you can mount on the back of the engine. Also most newer engines have a magnet in the crank shaft. Do you know of a radio system that can use two channels and rev limiter sensors to sync engines through the curve? Although it would seem like a lot of work to transmit back and forth to do that... just a thought....
The one feature I like about the synch is if one motor dies, the sync throtles back the running motor to idle to minimize control loss. So in reality I was contaplating the sync system and a rudder gyro to minimize spiral nose plants if an engine fails.....
Hide Signatures
(in reply to TEBerg)
       Post #: 26
RE: tf dc3 - 12/3/2010 7:08 PM
TEBerg
Score: 113
Last Login: 5/17/2013
Status: offline
Peter,
You have all the same questions and thoughts I've been going through - laughing...
I also looked at the spektrum technology, but it is only set up to monitor RPM on one engine. However, Airtronics can monitor twins. I was not even thinking about using any limiter function.
If the Twin-Sync has the feature to reduce the running engine, if you can monitor the RPM without the separate magnet (using the back of the engine) that may be a great option.
I am also planning a gyro for the tail... Mostly to help with take off. Looking at dual-rate, non heading-hold gyros that I can have a higher rate for take off and switch to a low rate for flight. The trick was matching the power system between 2.4 (which wants a higher voltage) to a gyro. I'm planning on using the Century PG2000R gyro that is dual rate and rated up to 7 volts. I didn't want a 4.8-volt heading hold gyro to just make matters worse for this project.
I have a bunch of books for documentation and picked my topic for making the DC-3 a scale C-53. Next, I need to make a list of the servos I want to run throughout the plane and work out how I'm going to run the Robart retracts (air, servo, or electric retro-fit)...
Photo of the "real" plane I'm going to model...
Click to see fullsize image.
Click for fullsize
_____________________________
Blue Skies,
Tom B.
Hide Signatures
(in reply to peternj)
       Post #: 27
RE: tf dc3 - 12/3/2010 7:31 PM
peternj
Score: 103
Status: offline
Nice,
I'm thinking one of these
http://wp.scn.ru/en/ww2/t/53/5110/0/1
http://wp.scn.ru/en/ww2/t/53/29/0/1
than again if I can figure out how to cover it with aluminum (FliteMetal) or tin cans, I'd make it a passanger plane.....
Where did you get your documentation? And is it only for the C53?
There's a guy www.rcdon.com that has a nice write up and video of a TF DC-3 as C-47 build, and I read onother thread on RCU that someone wants to build the turbo conversion with 2 WREN turbo props ... that thing would be a rocket...
Hide Signatures
       Post #: 28
RE: tf dc3 - 12/5/2010 5:59 AM
TEBerg
Score: 113
Status: offline
Those marking choices look cool.. This project is going to be a learning process for me.
I have found references on the acution sites and at the air museum.
The best two I have are: "C-47 Skytrain in Action" and "C-47/RD4 Units of the ETO and MTO".. Good history of all the different varients. I also have "Sixty Glorious Years, A tribute to the Douglas DC-3 Dakota" and "Gunships, A pictorial History of Spooky." One of my choices was to model the "Puff" gunship. But found a local plane that I could document and photograph.
I saw the RCDon site, he had some good photos of his build... I'm still looking at options for my build and will probably start putting sticks on the board in a cople of months.. After I get my Skyraider updated with a few mods I can get moving on the DC3
Blue Skies,
Tom B.
Hide Signatures
       Post #: 29
RE: tf dc3 - 2/2/2011 7:51 PM
Fili
Score: 100
Last Login: 5/24/2013
Status: offline
Dorked mine many years ago, finally got her off the rack and back in the workshop... (before and now pics)
Click for fullsize
Click for fullsize
Click for fullsize
Phil
CORSAIR Brotherhood #20
Hide Signatures
       Post #: 30
RE: tf dc3 - 2/2/2011 8:26 PM
peternj
Score: 103
Status: offline
That looks really nice! Great worksmanship....
Hide Signatures
(in reply to Fili)
       Post #: 31
RE: tf dc3 - 2/28/2011 10:52 PM
Fili
Score: 100
Status: offline
Almost done with the painting.... I'll need to clean her up a bit, then fuel proof
Click for fullsize
Click for fullsize
Click for fullsize
Phil
Hide Signatures
       Post #: 32
RE: tf dc3 - 3/1/2011 11:10 PM
aaflyer
Score: 100
Status: offline
Very nice rebuild..Still flying mine!!
Click for fullsize
Hide Signatures
(in reply to Fili)
       Post #: 33
RE: tf dc3 - 3/11/2011 1:58 AM
Fili
Score: 100
Status: offline
Darn close to putting the guts in....
Click for fullsize
Click for fullsize
Click for fullsize
Phil
Hide Signatures
(in reply to aaflyer)
       Post #: 34
RE: tf dc3 - 3/16/2011 6:07 PM
jaka
Score: 158
Status: offline
Hi!
If you want a civil variant of the DC-3 I can recommend using Oracover Chrome!
I used it on my Marutaka DC-3, but first I wet sanded each strip of plastic, using 1200 paper, on a piece of glass to get that alumium look.
Must mention that I first covered the fuselage with 24 hour epoxy and 25g glassfiber before covering with strips of Oracover.
Power is two OS FS.26 engines.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 35
RE: tf dc3 - 11/12/2012 4:20 AM
barry wetherell
Score: 100
Last Login: 5/23/2013
Status: offline
OK guys, the conversion to E/P ... some say to keep the thrust angles in and others say no need for them... What is the general consensus ????
I will use the props in opp. directions
Barry
everyday you wake up is a good day
Hide Signatures
(in reply to jaka)
       Post #: 36
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
