Is This Normal???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Is This Normal???
Page: [1]
Login
Is This Normal??? - 9/1/2010 8:00 PM
MarkShapiro
Score: 100
Last Login: 5/20/2013
Status: offline
I have installed new Hitec 7955 digital servos on my new 3W Bearcat. The flap servos are making noise and cuaing the surface to "jitter" as if it is straining. Now the flap servos does have some weight to it, but there is no real stress on the servos. No binding of any kind, either. Is this normal for these high powered digitals?
Hide Signatures
       Post #: 1
RE: Is This Normal??? - 9/1/2010 8:17 PM
exeter_acres
Score: 116
Last Login: 9/24/2012
Status: offline
yes....digitals continually are trying to stay at center so they normally buzz a bit,
_____________________________
Extreme Flight RC tech support
IMAC SE Regional Director|IMAC Sequence Committee|IMAC Judging Instructor|Team Futaba
Hide Signatures
(in reply to MarkShapiro)
       Post #: 2
RE: Is This Normal??? - 9/1/2010 8:23 PM
MarkShapiro
Score: 100
Status: offline
Thank you sir.
Hide Signatures
(in reply to exeter_acres)
       Post #: 3
RE: Is This Normal??? - 9/1/2010 8:33 PM
All Day Dan
Score: 151
Last Login: 5/25/2013
Status: offline
Mark, The use of digital servos does come with a price. The constant jittering around neutral that you are observing means an increase in current consumption. It’s more than what you get with regular analog servos. Make sure your battery pack has enough capacity to account for this. By the way, unless you really need the digital servos, for some reason, you should stick with the regular ones. The average sport flyer can live without them. Dan
Dan
Hide Signatures
       Post #: 4
RE: Is This Normal??? - 9/2/2010 12:02 AM
prop wash
Score: 100
Last Login: 5/24/2013
Status: offline
Mark I have TFGS planes and don't have a single digital servo in any of them.Unless your doing 3D with your WRBRDS I don't think you need them. Have fun. Tom
pain is just weakness leaving the body
Hide Signatures
(in reply to All Day Dan)
       Post #: 5
RE: Is This Normal??? - 9/2/2010 12:08 AM
MarkShapiro
Score: 100
Status: offline
I hear what you guys are saying on digitals vs. analogs. I have them on a 3W Bearcat which has huge torque specs requirements. Only teh digitals have the torque recommended. I am using twin 4500maH NiMH batteries. I may switch out to Lipos if the NiMH do not last long.
Hide Signatures
(in reply to prop wash)
       Post #: 6
RE: Is This Normal??? - 9/2/2010 12:54 AM
G-Pete
Score: 359
Last Login: 1/21/2013
Status: offline
4500mah and 10 Hitec servos buzz.......takes a few hours before silence. I run last year (developing a new flap system), four 5645 MG for 3 hrs and never quit on me. The batteries were 2800mah NiMH.
The buzzing is normal - nothing to worry about.
The nice thing with digital is, the high resolution - this makes a smoother flight possible. Much more precision, that what you want for the Bearcat...
G-Pete
Owner of WERK77 and Fritzdezings
Hide Signatures
       Post #: 7
RE: Is This Normal??? - 9/2/2010 1:56 AM
grbaker
Score: 115
Status: offline
The only way your flaps can have no load on flaps is to set them up as seen in the pics below on a T-33 with internal linkage. 180 degree from full up to full down. These 5645s don't buzz at all.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Gary Baker
Hide Signatures
       Post #: 8
RE: Is This Normal??? - 9/2/2010 3:53 AM
MarkShapiro
Score: 100
Status: offline
Thanks for the info G-Pete.I feel alot better about my battery situation after your posting. Nice flap set up grbaker.
Hide Signatures
(in reply to grbaker)
       Post #: 9
RE: Is This Normal??? - 9/2/2010 5:10 AM
G-Pete
Score: 359
Status: offline
Mark here are two of four at work...
G-Pete
Hide Signatures
       Post #: 10
RE: Is This Normal??? - 9/2/2010 7:49 AM
MarkShapiro
Score: 100
Status: offline
Thanks Pete. That is exactly what mine sound like. Won't be hearing much of anything over the smooth sounds of the Moki 250 when she is running.
Hide Signatures
(in reply to G-Pete)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.047RCU1
