Maisto Rock Crawler    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Toy-Grade RC Products >> Maisto Rock Crawler
Page: [1] 2 3 4 5   next >   >>
Login
Maisto Rock Crawler - 9/2/2010 7:06 AM
stw9495
Score: 100
Last Login: 8/30/2011
Status: offline
 After I saw these in my local Wal-Mart I had to have one.
I made a video review, but I don't have it up yet.
Basically, it's a good buy for the money, it has adequate torque, probably more than you'd expect. Speed is about right, steering is alright, seeing as there are no diffs, but none of it is proportional, and when you turn while driving it slows down. Dual motor setup is ok, but I worry when one set of wheels stops, it seems like it's killing the motor. Tires aren't the greatest, just thin and squishy, compound is stiff. But all in all it will climb a lot more than anything else in that aisle at wally world, an rightfully so, the simple ball and socket suspension setup work really well. Pretty much what it can get it's tires on, it will climb.
It's (of course) not something pro, but it's not meant to be. It's well designed for what it's meant for, very mild crawling and offroading. $30 is a great price, so I'd highly recommend one. My only big pet peeve is the 6 AAs it takes to power the truck.
I'll have my review videos edited and up asap. Until then, here are some pictures of the truck, and yes, it has climbed over these obstacles with relative ease... (they're screenshots from a video) steepest I've seen it go was probably more than a 45 deg. angle.
Hide Signatures
       Post #: 1
RE: Maisto Rock Crawler - 9/5/2010 4:19 AM
zman5000
Score: 102
Last Login: 2/6/2013
Status: offline
i've got 2 of those and i concur with all you said, the motors look the same as a new bright crawler( maybe dyno time) and i think a 2cell 800mah lipo will fit the battery box, that would give it much more power. the aa's don't have punch like the lipo's do.
Hide Signatures
(in reply to stw9495)
       Post #: 2
RE: Maisto Rock Crawler - 9/5/2010 7:21 AM
stw9495
Score: 100
Status: offline
well the rear motor is weaker...but it's a 130, so anything would drop in. I've put this thing through stuff I'd never expect it climb. just need some GOOD batts tho
also, anyone notice it has smaller summit tires?
Hide Signatures
(in reply to zman5000)
       Post #: 3
RE: Maisto Rock Crawler - 9/5/2010 8:50 PM
zman5000
Score: 102
Status: offline
i did install a 2 cell lipo in the thing and what a difference. it's an old losi 800mah and i had to take the top off the crawler to get to the wires and had to dremel out the battery tray so the hatch cover would close. doing this almost got rid of the clod stall, and the steering is much quicker also. the next thing is the wheels look like they might fit 1.9 tires, i'm going to the lhs to find out.
Hide Signatures
       Post #: 4
RE: Maisto Rock Crawler - 9/5/2010 10:15 PM
stw9495
Score: 100
Status: offline
Wow dude you got some initiative! I'd really like to see what you find out, and I'll bet a lipo would make it talk. Really it needs to be proportional, geared down, and with better tires...so I really gave up on trying to mod it. But thats awesome.
stock trim on some 35 or so degree waterfalls
<meta http-equiv="content-type" content="text/html; charset=utf-8" /> http://www.youtube.com/watch?v=UBWGohQHhe8
Hide Signatures
       Post #: 5
RE: Maisto Rock Crawler - 9/6/2010 12:58 AM
zman5000
Score: 102
Status: offline
nice video, i did put some proline 1.9 chisels on mine with some lead behind the front skidplate and it's even better. i don't have terrain around here like you have, so i have to go to piles of rocks, and the chisel's have so much traction the maisto speed control can't supply enough power to the motors. i'm just going to run it until it melts down and then maybe put a fxr in it.
Hide Signatures
       Post #: 6
RE: Maisto Rock Crawler - 9/6/2010 2:26 AM
stw9495
Score: 100
Status: offline
hahah! do what u gotta do!
Hide Signatures
       Post #: 7
RE: Maisto Rock Crawler - 9/21/2010 2:54 AM
redneckabbott
Score: 100
Last Login: 1/18/2011
Status: offline
Can u give a link for the batteries u installed? Thanks
Hide Signatures
       Post #: 8
RE: Maisto Rock Crawler - 9/21/2010 3:09 AM
phmaximus
Score: 632
Last Login: 6/19/2013
Status: offline
Hey guys, if u are after more speed ive found by replacing the Toy grade ECS with a Proportional one it make one hell of a diffrence. something like the tamiya TEU-103BK would work a treat.
I fitted on of those to a massive Nikko hummer, on its stock battery my 2yo could sit on it & get a ride, but the only thing way it was not very strong, i crashed it into a poll & it ripped the from diffhousing apart
ive still got it but it needs a hole new chassis
_____________________________
Losi Micro SCT,5IVE,8IGHTe
Tamiya BajaKing,TA01R,TL01B
Hide Signatures
(in reply to redneckabbott)
       Post #: 9
RE: Maisto Rock Crawler - 9/21/2010 3:32 AM
redneckabbott
Score: 100
Status: offline
I played with it the night my buddy bought his son this crawler. His son was asleep so me and his dad "tested" it for him lol. We was happy with speed. I didn't like that the back tires wouldn't pull while the front spun or other way around. The batteries seem to really hold it back and replacing them gets expensive if you don't have rechargeable.  The suspension articulates nicely. I was able to get it to crawl ontop of 2 power wheel batteries that was stacked. (i have video of it i'm going to post on youtube) It looked like the front bumper and body keeps it from flexing as much as the rear does. That's about all of my thoughts on the crawler
Hide Signatures
(in reply to phmaximus)
       Post #: 10
RE: Maisto Rock Crawler - 9/22/2010 4:35 AM
zman5000
Score: 102
Status: offline
that's why i installed a 2 cell lipo to help with the clod stall(that's what they call it when the front axle pulls and the rear axle stalls) a 2 cell lipo 800 mah is only about $25 at the lhs, and it's really not that difficult to in stall if you have a dremel tool, just hog out the battery compartment until the battery fits and you can close the hatch. i'm no genious and i did it.
Hide Signatures
       Post #: 11
RE: Maisto Rock Crawler - 9/22/2010 5:19 AM
phmaximus
Score: 632
Status: offline
tru about the Lipo been cheap, but the expencive part is the charger my Imax B5 was $70. ummm just wondering are u running a Lipo Saver/low voltage cut off?????
Seriously Guys dont play with LIPO's if u havent done your Research. It will end in tears.
this is what happens to them after a hard crash
This is from incorrect charging
All this can happen if the battery is to flat when charging, Never charge a Lipo inside a house or with out a fire bag.
If any of the cells are below 2.7v dont charge, dispose of battery proplary
I still believe that a Proportional ESC would solve the cloging, but then u would need a proper radio gear & make the steering Proportional. could end up costing a bit tho
Hide Signatures
       Post #: 12
RE: Maisto Rock Crawler - 9/24/2010 5:12 AM
zman5000
Score: 102
Status: offline
an 800mah lipo in the maisto crawler will give about 1 hour run time. and for a charger go to hobbyking.com and get a do all charger for 25 bucks. i've had a turnigy accucell 6 for 3 years and paid 28 bucks for it,  and now they are cheaper and they charge anything. and if i ever decide to get nervous about a lipo i'll get one of those $4.00 lipo cutoffs.
Hide Signatures
       Post #: 13
RE: Maisto Rock Crawler - 9/24/2010 5:09 PM
phmaximus
Score: 632
Status: offline
ok cool i was worried that u dident know about the dangers of lipo's
i use a Yeah racing 2c 4000mah & 3c 2200mah & 4200mah batterys for my cars & a plane & i use a novak low voltage cut off for the brushed ones & the brushless have it built into the ESC. with the cost of how much my r/c cars are worth & the replacement of the battery I would be stupid not to use them, & I use the yeah racing fire bags because ive had forum buddies that would of lost there house if it was not for these bags. US$28 sounds cheap for ya charger but 3 years ago that would of nearly been AUD$60 so it kinda works out i gess. Just be carefull using cheap Lipo's & cut off's.... u get what u pay for
Hide Signatures
       Post #: 14
RE: Maisto Rock Crawler - 9/26/2010 12:59 AM
zman5000
Score: 102
Status: offline
yes i understand about the lipo bags, but that presumes that everyone handles their lipo's the same. i don't even balance mine, from my experience the only time you have to balance a lipo is when it is fully discharged. i just top them up between heats, or have a spare for the heli, and top up the one that just ran. no problems in 3 years.
Hide Signatures
       Post #: 15
RE: Maisto Rock Crawler - 9/26/2010 8:18 PM
phmaximus
Score: 632
Status: offline
come on thats like saying im not going to get car insurance because i havent crashed in 3 years.
The chances are u wont have a problem, but the thing is, when it goes wrong..... it goes wrong
Do u at least check the cells?
Hide Signatures
       Post #: 16
RE: Maisto Rock Crawler - 9/26/2010 11:13 PM
zman5000
Score: 102
Status: offline
actually i don't check them i only run 2s and 3s lipos, in r/c cars, the thing with the cars is that you have a 5000mah lipo and you only use 1250mah in a 7 minute heat race. in the crawler you can run 6 courses and use up only 40% of the battery. the heli i only fly it for 5 minutes at a time usually as the wind around here hasn't stopped blowing all summer, so i don't abuse my batteries so i have no problems.
Hide Signatures
       Post #: 17
RE: Maisto Rock Crawler - 9/29/2010 8:18 PM
redneckabbott
Score: 100
Status: offline
Thought I'd share the video of me playing with his toy....
Hide Signatures
       Post #: 18
RE: Maisto Rock Crawler - 10/1/2010 3:29 AM
zman5000
Score: 102
Status: offline
yes nice vid,and at least 10 times more fun than a losi micro rock crawler and 1/4 the price. this is what the 1.9's should have been.
Hide Signatures
       Post #: 19
RE: Maisto Rock Crawler - 10/15/2010 2:22 AM
zman5000
Score: 102
Status: offline
and today i see the maisto crawler on ebay for $56.99! what a ripoff as they are 30 bucks at wally world. those retailers probably go to wally world, buy them and mark them up.
Hide Signatures
       Post #: 20
RE: Maisto Rock Crawler - 10/25/2010 3:17 AM
traxxas_guru
Score: 100
Last Login: 9/12/2011
Status: offline
meh, i have one of these and i like it however it has like no torque. it just stops when the boing gets tough.
i think the motors are 130 size, am i right?
if so could i use two of these?
130S
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=4194
or this
130L
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=4203
and two of these esc's
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6456
Hide Signatures
       Post #: 21
RE: Maisto Rock Crawler - 10/26/2010 5:12 AM
zman5000
Score: 102
Status: offline
just do like i did and put a small 2 cell lipo in it and it transforms the thing. those 800mah batteries cost only about if i remember $25.00 and an hour of run time.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to traxxas_guru)
       Post #: 22
RE: Maisto Rock Crawler - 11/17/2010 12:52 AM
nitrosportsandrunner
Score: 296
Status: offline
i have seen these sold on ebay for over $60!!!
LOL, they only cost $30 at walmart!
maybe i should buy a bunch and sellem
SC10 brushless, Thunder Tiger Phoenix XB Brushless, 1/5 custom rock crawler, Slash 4x4, Atomik Barbwire
Hide Signatures
       Post #: 23
RE: Maisto Rock Crawler - 11/17/2010 3:12 AM
zman5000
Score: 102
Status: offline
i was at wally world yesterday and they can't keep them in stock. and they still are 30 bucks, tower has them at 40 bucks. so apparently everyone is buying them from wallyworld and reselling them, the greedy people never sleep.
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 24
RE: Maisto Rock Crawler - 11/17/2010 10:05 PM
volkstony
Score: 100
Last Login: 1/25/2013
Status: offline
i found these at the nellis afb bx for 29.95 and no tax i was wondering are they fun i also have a redcat rs10 i know it would not compare to that but the maisto looks really neat. i would upgrade to a nimh battery pack if i get one.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.063RCU1
