RE: Carl Goldberg Ultimate 10-300 Brotherhood.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Carl Goldberg Ultimate 10-300 Brotherhood. Page: <<   < prev  43 44 [45] 46 47 48 49 50 51 52   next >   >>
Login
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 1/30/2013 4:22 PM
mattnew
Score: 110
Last Login: 6/18/2013
Status: offline
Very cool, *thumbs up*
quote:
ORIGINAL: jglemba
quote:
ORIGINAL: jglemba
I would like to join the Ultimate Brotherhood. Restoring a 15 year old 1300
Thanks, Joe
[image][/image]
Bill started to make some templates to make a few backup planes after working on the restoration. He's been cutting out parts for the fuselage sides and tops along with some formers. He has been busy! He also made a nifty little dremel tool type router table to help make the lite ply sides!
_____________________________
Carl Goldberg Ultimate Brotherhood #103
Ultra Sport Brotherhood #148
Hide Signatures
(in reply to jglemba)
       Post #: 1101
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 1/30/2013 11:19 PM
trippergreenfeet
Score: 100
Last Login: 6/19/2013
Status: offline
Ultimate kit for sale on RCTrader if anyone is interested (not mine).
www.rctrader.com/category/341/GasPetrol/listings/6175/Carl-Goldberg-Ultimate-10-300-Kit.html
Hide Signatures
(in reply to mattnew)
       Post #: 1102
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 1/31/2013 8:21 PM
mikmerl
Score: 100
Last Login: 3/13/2013
Status: offline
Having selected to re-engine the Ultimate, it became necessary to modify the cowl.
The previous engine (YS) was side mounted and the new DLE will be mounted inverted.
The hole in the side of the cowl needed to be covered and a new hole opened in the bottom for the new installation.
First step was to use a Dremel tool to “clean” around the existing hole removing all paint etc. and thinning the material to avoid a ridge where the old glass will mate with the new glass.
The glass cloth and epoxy resin need a mold to cure against, the large opening where the cowl has a slight curve was covered with a section of a soft plastic bottle and the flatter sections were simply covered with clear packaging tape.
Three layers of diagonal weave glass cloth were laid down and saturated with laminating epoxy resin. When this cured the “mold” was removed to revel the blocked off hole where a bit of TLC filling and sanding is needed.
I will soon be in position to start priming and preparing for final finish.
mike
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Nothing is foolproof because fools are so ingenious.
Hide Signatures
(in reply to J.Paul Saure)
       Post #: 1103
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 1/31/2013 8:44 PM
Twin_Flyer
Score: 108
Status: offline
Mike, great timing as I am doing the same with a CG Ulti I picked up used. Converting it form a Como .90 to a DLE 20.
I may try what you did to save a few bucks but this one has the stock plastic cowl, so I may end up spending the $$ and get a nice 'glass one instead as there is a large portion missing on the bottom from the Como's muffler as well.
Bill S.
Carl Goldberg Ultimate Brotherhood #56
Ultra Sport Brotherhood #135
http://radiocontrolhobbies.freeservers.com
Hide Signatures
(in reply to mikmerl)
       Post #: 1104
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/1/2013 10:55 PM
ktmfrank
Score: 100
Last Login: 6/16/2013
Status: offline
Hello brothers!!!!
i got my plans printed out for my own bipe!!! Now i will need to find a landing gear! and sort out all the wood and ply required to build my bipe.i found the cowling and canopy at Fiberglass specialties.
The easiest to find will be ultracote!
Kinda nervous about this project cause it will be my first scratch built.
Anybody has some blue hawk stickers for sale?
Carl goldberg Ultimate brotherhood # 104
Hide Signatures
(in reply to Twin_Flyer)
       Post #: 1105
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/2/2013 2:16 AM
mnmopar
Score: 100
Last Login: 6/6/2013
Status: offline
A lot of the parts for the older Goldberg stuff is still available through Hobby Services. I've been ordering from them over the last year. Do note that the prices have gone up from what is on the site. The "Blue Hawk" decals are part number 2283.
Goldberg Parts
Limited quantities - call or e-mail for availability
Great Planes Product Support (217) 398-8970, option 3
partssupport@greatplanes.com
Carl Goldberg Ultimate Brotherhood #97
Hide Signatures
(in reply to ktmfrank)
       Post #: 1106
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/2/2013 3:01 AM
weazel1
Score: 100
Status: offline
well guys is great to see so much about this ship here this ship was my first biplane while learning to fly and now i got a 100cc ultimate great ships no matter what size
Hide Signatures
(in reply to mnmopar)
       Post #: 1107
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/2/2013 4:51 PM
peternj
Score: 103
Status: offline
ktmfrank, let me know if you're going with the wire landing gear, if so i can bend you up a set when my shoulder heals or
http://www.fibertechnmore.com/index.php?crn=234&rn=461&action=show_detail
Hide Signatures
(in reply to weazel1)
       Post #: 1108
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/2/2013 6:51 PM
thnilsen
Score: 100
Last Login: 6/14/2013
Status: offline
quote:
ORIGINAL: ktmfrank
Hello brothers!!!!
I traced the Bluehawk text logo myself and had it reprinted by Callie Graphics. Did both the side lettering and the top wing lettering. I still have the SVG vector file if you want a copy. Excellent and reasonable service from Callie. I also posted somewhere in this thread the front cowling/tail graphics which you could reprint on your own printer using water transfer paper.
If you want a carbon landing gear you could use on of the ones sold by http://www.graphtechrcshop.com/. Fits well too. I can dig out the details of the one I ordered and mounted on my own bluehawk.
- Thomas
Carl Goldberg Ultimate Brotherhood # 92
Hide Signatures
       Post #: 1109
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/4/2013 6:30 PM
mattnew
Score: 110
Status: offline
Well... I got mine!... now to finish off this RV-4 so I can have a place to build it.
Hide Signatures
(in reply to thnilsen)
       Post #: 1110
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/4/2013 6:32 PM
peternj
Score: 103
Status: offline
Matt,
NICE!!!!
the RV4, is it the great planes one?  i got one in my build list
Hide Signatures
       Post #: 1111
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/4/2013 6:40 PM
dmarusa
Score: 100
Status: offline
Matt - That's really funny.  My procrastination on my GP RV-4 is what's holding up my Ultimate build too.  I'm actually building two at the same time.  One's by the plan and the other is a scratch with lots of modifications like a turtledeck, surface trim tabs and small winglets.
Carl Goldberg Ultimate Brotherhood #84
Hide Signatures
(in reply to peternj)
       Post #: 1112
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/4/2013 6:43 PM
mattnew
Score: 110
Status: offline
The great planes .40 size version. I started it thursday and only working 1-2 hours a day have 2 wings the tail and halfway through the body done... so to say it builds fast is an understatement... That being said I don't really love the kit/instructions. Experienced builders would be fine, but there are a number of trip-ups that have left me dissappointed with the kit that could so easily be fixed. For example the top of the fuselage should really be made out of 1 piece aircraft ply... instead its 4 peices that get butt jointed together... I don't have a lot of faith in butt jointed plywood joints.... the other gripe is they updated the parts lists but not the booklet so you spend a lot of time looking for pieces that don't exist b/c they  have been swapped out.
I guess the speed of the build makes up for it. and from what I have heard its a wonderful flying plane.
btw, haven't forgotten, I'll get on those templates here and get them sent out to you to add to the .zip file.
quote:
ORIGINAL: peternj
Matt,
NICE!!!!
Hide Signatures
       Post #: 1113
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/4/2013 7:19 PM
mattnew
Score: 110
Status: offline
i actually was contemplating a turtle deck.. I've always loved the look of the cap-21 and doing that would make this plane look very similar.... i want to just get it done though so its likely coming out with a stock look so I can get flying this spring and get to building the ultimate, which honestly is really what I want to be working on.
Sorry for getting this thread off topic :-)
quote:
ORIGINAL: dmarusa
Hide Signatures
(in reply to dmarusa)
       Post #: 1114
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/6/2013 11:48 PM
jglemba
Score: 100
Last Login: 2/25/2013
Status: offline
Getting the CG restoration project closer to completion. Bill finished the fuse. We put it together to test fit the wings, landing gear, mount the CFG 20cc motor, etc. We checked the cg and it looks like with two servos in the rear for the elevator and an 8 oz. tank, it worked out perfect. He also has his fuse built for his. Now he is getting started on the wings. He's moving right along!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
EZ-Hang
PAFreeAds
Hide Signatures
       Post #: 1115
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/7/2013 2:31 AM
alfredbmor
Score: 113
Last Login: 3/5/2013
Status: offline
Neat, congratulations jglemba
Saito Club Member # 531; Ultra Sport Brotherhood #63
Carl Goldberg Ultimate Brotherhood # 07
Hide Signatures
       Post #: 1116
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/7/2013 2:02 PM
maekju
Score: 105
Last Login: 6/17/2013
Status: offline
Is a 8 oz tank going to be big enough?
Crash, what crash. This is my new kit.
Carl Goldberg Ultimate Brotherhood #102
Hide Signatures
(in reply to alfredbmor)
       Post #: 1117
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/7/2013 2:04 PM
ktmfrank
Score: 100
Status: offline
 With my dle 20 10oz was giving me 8 min with a reserve of 2 mins
Hide Signatures
(in reply to maekju)
       Post #: 1118
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/7/2013 2:33 PM
maekju
Score: 105
Status: offline
Ah yes, gas! Gotta try that one day. I have way too many glow engines and glow fuel isn't getting any cheaper.
Hide Signatures
       Post #: 1119
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/7/2013 2:53 PM
mikmerl
Score: 100
Status: offline
I too am preparing my Ultimate with a DLE 20 and a 8oz DuBro tank.
My YAK 54 with an Evolution 26cc GX engine and a 9oz tank gives me a 10min with 1-2min reserve and that engine is 30% larger.
Logically 8 oz should be enough for a small 20cc gas engine.
My Zenoah 20cc engine manual states 1000ml fuel for 1 hour running at WOT. That is around 1/2oz a min. Is it possible that the DLE 20 consumes double that?
mike
Hide Signatures
       Post #: 1120
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/7/2013 3:20 PM
jglemba
Score: 100
Status: offline
quote:
ORIGINAL: alfredbmor
Thanks, Bill is doing most the work on this. I just recovered the wings so far. He made a bunch of templates and cut out enough to make him two of these and I got my new kit still in the box. He is going on my word that this is a great flying plane.
EZ-Hang
PAFreeAds
Hide Signatures
       Post #: 1121
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/7/2013 3:57 PM
Twin_Flyer
Score: 108
Status: offline
Rereading the last few posts about servo location. As I am converting a once nitro powered Ulti into gas with the DLE,I take it I will need to relocate the servos to the rear?
Anyone have a pictures of their install so I can get an idea of what and how it was done?
Bill S.
Hide Signatures
       Post #: 1122
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/7/2013 6:55 PM
jglemba
Score: 100
Status: offline
quote:
ORIGINAL: Twin_Flyer
Bill S.
What we found out from my brother who designed and built planes, it isbetter to move the heavier motor aft a little to make CG than to have to add weight in the rear to compensate for it. What Bill and I did on the gas conversion is move the the firewall back 3/4". We had to rebuild the front of the plane anyway because it was fuel soaked and needed redone anyway. That little bit made it cg perfect with 2 standard servos, one for each elevator and the pull/pull rudder mounted below the cockpit! If everything works out, we should only come in 100 grams heavier than with the glow as that was the weight difference between engines including muffler and ignition. We have to add some light ply to the rear fuse to mount the servos under the horizontal stab. What we add, we will cut away the difference to keep weight down and the same. This is our "Test Monkey" plane. It was flown for 15 years by me and was a true "Feather"! It just got "mushy" in the front from the glow fuel! In 30 years of flying, it is the only plane that I could take off and fly a kife-edge for the entire 10 minutes. Kife edge circles, figure 8's, even knife-edge loops. I don't know what will happen with the 100 gram heavier motor. I had many 50cc ultimates and different others. Nothing flys like the Goldberg. I have been flying for years and The Goldberg Ultimate is a freak! Still have my original ama # from the 70's AMA# 2997.
The Goldberg ulitmate was built "ahead of it's time". It incorporated cut lite ply for weight like the newer models that are extremely light and strong like the "AJ Slick" and others like "Extreme", etc. Wish someone would kit this plane. We reasearched the cost of wood and kitting the plane and it would be to "pricey" to make using USA wood, covering, hardware, etc. Too bad!!!
EZ-Hang
PAFreeAds
Hide Signatures
       Post #: 1123
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/7/2013 8:06 PM
Twin_Flyer
Score: 108
Status: offline
While kitting them again would be great, somehow I doubt Great Planes (who owns Goldberg now) would let you.
Interesting solution you did with the nose, but as the one I am working on has no oil/wood issues I'm not going to go that route.
Bill S.
Hide Signatures
       Post #: 1124
RE: Carl Goldberg Ultimate 10-300 Brotherhood. - 2/7/2013 10:01 PM
jglemba
Score: 100
Status: offline
Bill S.
Our motor has a rear carb and the distance from the firewall to where the prop backplate should be was 3/4" too long according to the plans, even with the carb touching the firewall.. We either had to cut a big hole in the firewall to slide the carb back into it or cut the firewall back. WE didn't really have a choice. Since you have a DLE, it might fit perfect. Good luck. You picked a good motor as 2 members in our club use them and can't believe the power they make!
Later, Joe
EZ-Hang
PAFreeAds
Hide Signatures
       Post #: 1125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.728RCU1
