RE: TopFlite DC-3/C-47 questions    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: TopFlite DC-3/C-47 questions
Page: <<   < prev  1 2 3 4 [5]
Login
RE: TopFlite DC-3/C-47 questions - 8/21/2007 9:56 PM
Mustang Fever
Score: 112
Last Login: 6/13/2013
Status: offline
Yeah. Maybe a pair of .40 LA two strokes would be a better way to go.
_____________________________
Bob Hunt
Hide Signatures
(in reply to fliir)
       Post #: 101
RE: TopFlite DC-3/C-47 questions - 8/22/2007 12:34 AM
Michel
Score: 123
Last Login: 6/19/2013
Status: offline
Greetings
Well I ve thought about it a lot and this is what I ve come out with : If I put in Saito 56s , its overkill , if I put in OS 46ax s , its overkill . Ive thought about the OS LA-40s , but theses engines are bushings and I don t want less than better in a $2000 plane , so this is what I ve decided I will be putting in OS 32sx s . This makes more sence than any , and its a very reliable engine . What I would of loved is to put in Saito 30s , but they are no longer available
I won t be starting the build for another year or two , but I do have the kit and the retracts and lots of time to change my mind
Happy flying
Mike
Hide Signatures
(in reply to Mustang Fever)
       Post #: 102
RE: TopFlite DC-3/C-47 questions - 8/22/2007 1:22 AM
Mustang Fever
Score: 112
Status: offline
Choosing the right power is always such a process, but I think I've made a start on developing a formula that works. It goes like this: Always overpower. Always. But prop for a realistic speed.
Examples:
I have a 4 Star 60 on floats. I'm running a Magnum 91 two stroke, but with a 15x6 prop, so top speed is only about 60mph, and there is all kinds of thrust available for playing games.
I have a Great Planes DR-1 arf that calls for a maximum 75 four stroke, and I have a Magnum 91 four stroke. With a 14x6 prop, top end is around 55 mph, but the thrust is incredible.
It's almost a truism that most planes build tail heavy. Putting in a heavier engine means less lead in the nose. The real bonus, tho, is when you get in trouble. Power can get you out.
< Message edited by Mustang Fever -- 8/22/2007 1:24 AM >
Bob Hunt
Hide Signatures
(in reply to Michel)
       Post #: 103
RE: TopFlite DC-3/C-47 questions - 8/24/2007 12:03 AM
fliir
Score: 100
Last Login: 6/1/2013
Status: offline
Mike and Bob:
I think you two are BOTH on the right track. Those engines are about the same weight and power (32SX, 40LA) and I think that they will serve you well.
I know the .40LA is just a bushed motor, but I have had 2 of them and they are easy-tuning, good-running engines, especially for the money. They will also turn good diameter props giving good thrust for water takeoffs.
david
On the board: Torres 20% T-34C
Future: Navy N3N, Aeronca 402, Blohm&Voss BV-141, Heinkel HE111Z, Dornier 335
Hide Signatures
       Post #: 104
RE: TopFlite DC-3/C-47 questions - 12/11/2007 5:38 PM
jaimefernando
Score: 100
Last Login: 12/12/2012
Status: offline
Hi guys,
a question for you related to the construction of the T/F DC-3. I am on page 28 of the Instructions Manual, but I'm stuck on Point 3. It is asking me to build the Bottom Corner Filler from blasa. The problem is that there is no reference to this part in the drawing.
Any suggestions?.
Thanks...Jaime
Hide Signatures
(in reply to fliir)
       Post #: 105
RE: TopFlite DC-3/C-47 questions - 12/11/2007 7:57 PM
jaka
Score: 158
Status: offline
Hi!
OS FP .40 are exellent engines in a twin,anything bigger is going to make the DC-3 fly like pattern plane or racer! But even the OS FP or LA .40 are way too powerful in a DC-3 of this size.
I have two OS FS .26 four strokes in my Marutaka DC-3 (span 211cm, weight 3,6kg)and it flies best on under half throttle and do so very realisticly. Take of is so easy and swift that I can't imagine what would happen if you used more powerful engines. It would just leap into the air and fly like a pattern plane which is certainly not what I would like to see my DC-3 doing.
My recommendation to all pilots that have a desire for the Marutaka or the Top Flite DC-3, is to use either the .20-.25 OS FP/LA engines swinging 10c4-10x5 APC props or using OS or any other .30 four stroke engine, swinging 10x5 or 10x6 APC props.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 106
RE: TopFlite DC-3/C-47 questions - 12/13/2007 6:13 AM
br549
Score: 100
Last Login: 4/27/2013
Status: offline
Will (2) OS48 FS Surpass engines be too much for this plane? This is what I have. What about CG and prop clearance issues? I do have access to (2) OS .25 FSR two strokes. They seem a bit light in power for such a big plane.
BR549
The quality of a man's life is in direct proportion to his commitment to excellence
Hide Signatures
(in reply to fliir)
       Post #: 107
RE: TopFlite DC-3/C-47 questions - 12/13/2007 2:21 PM
Mustang Fever
Score: 112
Status: offline
Page 3 in the Instruction Manual, "Engine Selection", is very specific on this point. If you want it to handle well in an engine out situation, use the largest engines recommended. It also specifically states that if you use the largest engines recommended, you'll have to throttle back some for realistic flight.
Bob Hunt
Hide Signatures
(in reply to br549)
       Post #: 108
RE: TopFlite DC-3/C-47 questions - 12/13/2007 9:38 PM
jaka
Score: 158
Status: offline
Hi!
It all depends how light you build the model! Mine weights 3,6kg. 4kg is no problem for a pair of OS .26 four strokes turning good propellers
If you just put a model together,following the manual ...it will most of the time be heavy and this requires larger engines,l arger tanks and larger engine mounts....see the negative spiral.
If you on the other hand don't accept the manufactuers metods all the time and instead carv away balsa and plywood where it's not needed you get a ligthly built model that flies real good and scale like and not behaves like a pattern plane. But to always do this takes experience.
As I said before...anything bigger than OS .26 four strokes will be to much power and will make the model fly real bad! That's a fact!! Sorry! But that's my 32 years flying experince from flying pylon racing (still do)and buiding and constructing all kinds of R/C airplane models.
The opinion that one should be able to fly a twin on one engine in case of an emergence is is just not relevant !
You don't fly a scale twin on one engine! You land immediately if one engine fails!!!
Of course I can fly my DC-3 on one engine ...there is power to spare using those OS .26 engines (fuel 15% Motul Micro all syntetic oil and 5% nitro). But why risk it ??
Hide Signatures
(in reply to br549)
       Post #: 109
RE: TopFlite DC-3/C-47 questions - 12/13/2007 11:07 PM
Robby
Score: 100
Last Login: 6/18/2013
Status: offline
If any of you know someone who might be interested I have one about 70% built
that I am not going to finish as I have other interest now.
(Please excuse the colored arrows on wing pic..
I was showing someone wing mounting
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Robby -- 12/13/2007 11:12 PM >
You won't find Nirvanna if you don't have any nerve ...
Hide Signatures
(in reply to jaka)
       Post #: 110
RE: TopFlite DC-3/C-47 questions - 8/26/2008 6:08 PM
thisoldman
Score: 100
Last Login: 2/8/2013
Status: offline
starting to build one mysef. Have the retracts and saito fa45 engines. Building to scale as much as can be done with the top flight.. Also have ziroli DC3 retracts if anyone interested in them. Have been watching the builds on the dc3. Won't be long and fall will be here.. Time to start building again..
al ryan
Hide Signatures
(in reply to jbflier)
       Post #: 111
RE: TopFlite DC-3/C-47 questions - 1/7/2013 1:42 AM
n6iap
Score: 100
Last Login: 6/14/2013
Status: offline
Is this thread still active? I'm starting the TF Kit to build it as a C47 tow aircraft.
Thank you for any comments.
The two most useless things a pilot has; the runway behind you and the altitude above you.
CORSAIR Brotherhood # 71 / Club Saito Member #704 / Waco Brotherhood#205
Hide Signatures
(in reply to thisoldman)
       Post #: 112
RE: TopFlite DC-3/C-47 questions - 1/7/2013 1:01 PM
cstevenpeterson
Score: 105
Status: offline
I guess it is now . I have one in the box and probably will not get to it anytime soon, but I like to follow what others are doing. Unfortunately, I cannot answer any specific questions for you, but I think if you start posting progress, you will probably get responses from those that have already built one. I did order fiberglass cowls, nose and tail pieces along with the Robart retracts for my kit...
Steve
Hide Signatures
(in reply to n6iap)
       Post #: 113
RE: TopFlite DC-3/C-47 questions - 1/16/2013 5:18 AM
n6iap
Score: 100
Status: offline
Almost 10 years after the thread was started I am going to list my progress and ask for help while I build this C-47 Dakota. I have unpacked the mass of wood and materials, as well as inventoried the content. This thing is huge! When you open the plans and book to find yellowing of the pages, it is a reminder of how long this kit has been around.
I am building the Dakota as a tribute to the WWII Airborne. Another local club member is building the WACO glider and we hope to demonstrate the TOW capability of the Dakota as well. Here is the stabilizer framed.
Please feel free to leave comments and ask questions. I know this is a build time for the rest of the world but it is fly time here in Florida so progress may be slow at first.
jimm
Click for fullsize
Hide Signatures
(in reply to cstevenpeterson)
       Post #: 114
RE: TopFlite DC-3/C-47 questions - 1/16/2013 1:06 PM
cstevenpeterson
Score: 105
Status: offline
I'm tuned in....
Hide Signatures
(in reply to n6iap)
       Post #: 115
RE: TopFlite DC-3/C-47 questions - 1/17/2013 11:42 PM
TBonez
Score: 100
Status: offline
I plan on building one this coming fall. I know it's a long time away, but my Chipmunk needs to be finished first.
Keep posting your progress Jim, and good luck.
Hide Signatures
       Post #: 116
RE: TopFlite DC-3/C-47 questions - 1/21/2013 1:47 AM
TEBerg
Score: 113
Last Login: 5/31/2013
Status: offline
I'm building this kit as a C-53. I have a write up going on the other scale site...
I'll be watching your progress here. I've been on hold for a couple months, so you may catch up to me soon. It will be cool to follow your ideas.
Blue Skies...
Blue Skies,
Tom B.
Hide Signatures
(in reply to n6iap)
       Post #: 117
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
