Heavily Upgraded Axial SCX10 Pro-Line Jeep Cherokee 2WD/4WD RC Truck w/8ch Radio
My Feedback: (28)
Heavily Upgraded Axial SCX10 Pro-Line Jeep Cherokee 2WD/4WD RC Truck w/8ch Radio FREE SHIPPING!
Includes Detailed Interior with Scale Driver, Full Floor Pan, Radio Controlled Selectable 2WD/4WD Transmission and Light System. Ready to Run!
This Truck is a Matching design to a similarly equipped Comanche in another of my listings.
This truck has over a hundred thousand views on YouTube so you may have seen it before, along with my other rigs.
They were used to film these videos and were then placed in an enclosed glass case for display.
Each truck is suspended on stands (included) at each axle to keep the tires from flat spotting.
They all have added weight to the inner wheels for better traction while climbing. Front having more weight than the rear.
Link to 2WD/4WD Upgrade Video.
(9 min 21 sec)
Link to YouTube Videos. https://www.youtube.com/playlist?lis...0C1CFB94F82983
The following is a list of just some of items used in the build:
Axial SCX10 4WD RC Truck Kit
Axial Racing Aluminum C Hub Carrier Upgrade AX30495
Axial Racing Aluminum Knuckle Upgrade AX30496
Axial Front Axle Shaft Universal Set Upgrade AX30464
RC4WD R2 Enclosed DIG Tranny Silver Z-U0023
Robinson Racing Pinion Gear Absolute 32P 22T 1722
RC4WD Axial SCX10 R2 Tranny Conversion Plate Z-S0298
RC4WD R2 Tranny Sideway Servo Mount Kit Z-S0566
Pro-Line 1992 Jeep Cherokee Body with Custom Four Color Paint Job
PL-C Floor Pan for SCX10, 11.4in(290mm) Wheelbase 3338-00, Painted
Pro-Line PL-C Interior 1/10 Crawler 3337-00, Painted
NECA "Gale" Action Figure from The Hunger Games
Tekin FXR ESC/35T Crawler Motor Combo TT2109
Turnigy T5000.2S.20/16206 5000mAh Lipo Battery
W.S. Deans 2-Pin Ultra Plug 1300 (2)
FlySky FS-GT3B 2.4ghz R/C Transmitter Controller. Upgraded (hacked) with Custom Version 0.6.1 firmware (8 channels),
Voltage Regulator, Ball Bearings, 4-Pin flash header & Lipo battery mods.
FlySky FS-R6B 6ch 2.4ghz Receiver
Turnigy 1450mAh 3S 11.1v Transmitter Lipo Pack T1450-TX-3
Hitec HS-5646WP Digital Waterproof HV MG Dual BB Servo
Axial Aluminum Servo Horn 24T AX30835
RC4WD Mud Thrashers 1.55 Scale Tires Z-T0100 x2
RC4WD Stamped Steel 1.55 Stock White Beadlock Wheels Z-W0035
RC4WD 1.5 & 1.7 Steel Wheel Hex Hub with Brake Rotor (Front) Z-S0529
RC4WD Stamped 1.55" and 1.7" Beadlock Wheel Hex Hubs (Rear) Z-S0737
RC4WD Scale Wheel Lugs for 1.55 Wheels Z-S0104
RC4WD Scale Front Locking Hubs Z-S0194
RC4WD Scale Rear Hubs Z-S0175
RC4WD Mega Truck Universal Shaft (80mm to 110mm) VVV-S0038 (Front)
Gmade Hardened Universal Shaft for Axial SCX10 (Rear)
RC4WD Scale 100mm White Shocks with Internal Springs
RC4WD Ultra Soft Spring Set for 100mm White Shocks
RC4WD Red Scale Shock Boots
RC4WD Super Bright Scale Light System 2 Z-E0019
Ram Rectangular HeadLights 84 (Tungsten filament like full scale)
Rcexl Optio on/off switch (for light system)
All aluminum links including:
RC4WD 80mm (3.15") Internally Threaded Aluminum Link (black) (2) (front lower) Z-S0257
RC4WD 70mm (2.75") Internally Threaded Aluminum Link (black) (2) (rear upper) Z-S0259
Rear 4-Link setup.
3Racing AX10-31 Upper 3-Link Mount (Front)
Over $1350.00 Invested, not including substantial labor.
FREE SHIPPING!
Other trucks not included.
Tags: Axial scx10 scx-10 scx Dingo Honcho Cherokee scaler 1/10 scale 4WD RC rock crawler rock Crawler truck car RC4WD Tekin motor rpp hobby junfac vanquish proline Pro-line masher hot racing rccrawler tsccrawler tsc 3racing twenty1eleven rcsparks wraith xr10 sx Radio Electric Control Nitro gears Savage Baja Team Race Cars 2.2 1.9 1.55 clodbuster clod mud-slingers stamped steel wheels tamiya tires wheels bead locks bead lock radio control lipo mud thrashers
Rear 4-Link setup.
FREE SHIPPING!
